Question about Brother XL-5500 Mechanical Sewing Machine
The feeddog does not feed the material. - Brother XL-5500 Mechanical Sewing Machine
3 Suggested Answers
  • 1788 Answers
SOURCE: When I lower the presser foot to sew, there is no
Check your book and read what the tension should be, and make sure that the feed dogs are up.
Posted on Sep 12, 2010
SOURCE: the feeddog pushes the material towards me,
has the sewing machine been used to sew in reverse?
Posted on Nov 18, 2010
Kenmoresewingmachine won't feed material
You may have accidentally lowered the feed dogs. Look for a toggle switch that will raise them up again. Mine is to the left of my power button.
Jul 22, 2014 | Sewing Machines
Material will not feed
Check under needle plate for lint holding feeddogs down
Mar 30, 2014 | Janome Sewing Machines
Feeds dogs are lowered even when in the up position
Check to see if there is a bunch of thread under the needle plate preventing the feed dogs from returning to run position.
This may mean having to take the needle plate off and really looking
Jul 29, 2012 | Brother CS-6000
Frozen feed gears singer sewing
the machine needs to be checked when the feeddogs don't move
but first check to see if the feeddogs are in the up position & if the
feeddogs are up, then the machine needs to be checked
Apr 28, 2012 | Singer Sewing Machines
Dog feeds not working
check the feeddog to see if there in the up position, you'll be able to see & feel the feeddog teeth with your fingers,, but if you can't feel them the check the feeddog knob or lever.
if the lever is in the up position & you can't move the lever or if you can move the lever up or down & the feeddogs don't move there position
then it's possible that there's something wrong with them & the machine will have to be serviced
Feb 07, 2012 | Janome Sewing Machines
The feed dogs will not move the material
check the feeddogs & see if there in the up position, if there not move the lever or knob to the up position
if the lever is up then there is something wrong with the feeddogs & it needs to be serviced
Jan 31, 2012 | Kenmore Sewing Machines
My sewing machine does not feed material through automatically. What specific problem would cause this?
your feeddogs are down or the pressure has been released on the foot. either problem sould be explained in the owners manual on how to reset either one.
Nov 06, 2010 | Brother Sewing Machines
Simplicity Serger pro 432-- feed dogs will not pull material through. They do not come up high enough to catch the material.
The most common troubles with feeddogs not working properly is either lint trapped in between the feed teeth...remove the needleplate and clean out the lint which may look like felt in extreme cases. or... the presser foot tension is too low, in which case, increase tension...there will be a knob of some sort at the top of the machine directly above the Presser Foot Shaft. It is a remote possibility that the feeddog height needs adjusting ...it will have been a major trauma of a severe jam or tugging etc to cause this. As it would almost certainly result in other timings being affected and particularly in the case of a Serger/Overlocker, the added risk of breaking loopers (expensive), I would recommend a service by suitably qualified technician to restore all to optimum condition.
Best Wishes Martyn
Bargain Box in Australia
Sep 07, 2009 | Simplicity Serge Pro SW432 Mechanical...
Feed dogs not feeding the material
Is this a second hand machine ?
Is the stitch length selector set to > 1
Remove the needleplate and clean between teeth of feeddogs if it has been a while since this has been done, old lint will impede feeding.
Presser foot tension for general work needs to be set at 3, or the chromed button pushed down to the grooved line, depending on machine.
If new, call the dealer where you bought it and speak to them.
Nov 24, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
Brother XL-5500 Mechanical Sewing Machine Logo
19 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
