Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Kenmore 16039 - "Clean" light is flashing & dishwasher won't start
We have a Kenmore 16039. I washed a load of dishes and when the cycle completed, the "Clean" light blinks. The dishwasher will not start when I press the Start button. Any thoughts? Thanks.
  • Bordelon Jun 15, 2008
    Seems to have worked! thanks!!
  • robreal3 Aug 05, 2008
    my son opened the dishwasher before it was finished. Now the green clean light blinks and the dishwasher will not start.
  • 413 Answers
Watch the light closely. If it blinks 7 times then pauses, this indicates a heater or door latch issue.
Press the following buttons in sequence: Hi Temp Wash, Heated Dry, Hi Temp Wash, Heated Dry.
If this doesn't work, check the tech sheet. (should be stuck to inside of the bottom toe panel)
All lights should illuminate then a diagnostic sequence will start.
Listen carefully, as soon as you hear the water begin to fill, open the door and feel the heater. if cold, check the heater for continuity (should be around 10ohms)
Also, bend the door catch on the dishwasher tub downward, this will engage the door latch better. Don't bend too far as it will hit the door while closing.
Posted on Jun 15, 2008
I had the same problem .I fixed it by unpluging the strip that goes to the buttons from the circutboard and pluging it back in.
Posted on Dec 18, 2011
Clean light is blinking, when you shut door and push start cycle nothing happens
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Mar 21, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
Dishwasher will not start. The clean light is flashing on and off. If I push the cancel button it appears to be draining but there is no water in the tub and it just continues. When I push the start...
Kevin
Jan 20, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
Flashing green ''clean'' light and will not start a wash cycle.
the computer senced that the heater did not work last cycle. Push your sani clean, energy saver button s back and fourth a few times. It will run a self diag cycle. let it run for a few min. If it happens again your heater may have burned out.
Nov 11, 2009 | Kenmore Elite 45986 Front Load Washer
Green light on kenmore dishwasher is flashing
I actually had to change the steps a little and this is what I did:
press heated dry
press normal wash
press heated dry again
press normal wash again
wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Started a cycle and began washing.....Thx
Dec 31, 2008 | Kenmore 24 in. 16039 Built-in Dishwasher
Clean light keeps blinking and I can't start a new cycle
That is a comon problem with that model. It is not sensing a temperature change in the water.
Push i believe it is heated dry and sani rinse going back and fourth between the two to clear the code and see if you can get it to complete a cycle. If it doesnt call sears and schedule service there is a service flash repair that should not cost you anything to repair the unit.
Nov 13, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Turning on dishwasher
although the light may be a true indication of a pending problem, try this test: Find the circuit breaker and switch it off to remove power to washer for 30 minutes. Then power back up. Any changes? If light still on, then threat of trouble is real and must be fixed. Not sure what to CLEAN, though. Search for manual online...I'm sure Kenmore put that light on for a real purpose.
Jun 14, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
277 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
