Question about Ingersoll Rand Ingersoll-Rand IR 315 Heavy Duty Air Twin Piston Inline Sander
I disasembled to clean and replace seals. I can get the two pistons set in unison but the center gear that drives the sanding board im having problems getting it set where it goes. I went to try it and the board goes forward and stops and does not come back. Ingersol rand model #315 board sander
5 Suggested Answers
  • 2309 Answers
SOURCE: what type of oil do you use for this compressor
1962?? if memoryserves me right the call for a 30w oil non detergent
Posted on Apr 21, 2010
thepot
  • 188 Answers
SOURCE: where to get parts for
go to your nearest engineering shop and they can order them for you
Posted on Dec 04, 2010
SOURCE: ingersol rand p185wir blowing compresor oil out air inlet
I'm not sure which model that is but if you have a separator element that may be a good place to start.
Posted on Nov 29, 2012
  • 37 Answers
SOURCE: 175 ingersol rand compressor putting a lot of oil out with air
It could be a failed air / oil separator filter or the steel pick up tube that goes down through the center of the oil separator (it is about the size of a pencil) could be clogged. Un screw it out of the top and see if you can blow air through it. Also check the hose leading off of it going back to the pump. If it is plugged it wont allow the oil to return and will push it into the air.
Posted on Feb 16, 2014
NEED DIAGRAM FOR LOCATIONS OF CRANKSHAFT PULLY,OIL SLINGER AND SPRING.FOR 1983 MAZDA 2.2L DIESEL
Here is the procedure:-
  1. Remove setscrew from side of cylinder block.
  2. Remove oil pipe attaching bolts.
  3. Remove oil pump and strainer.
TIMING GEAR COVER
  1. Remove timing gear cover to case attaching bolts.
  2. Remove timing gear cover and gasket.
CAMSHAFT, CRANKSHAFT, IDLER & INJECTION PUMP GEARS
  1. Remove oil slinger and washers from crankshaft snout.
Using puller set 49 0839 425C or equivalent, remove crankshaft timing gear, Fig. 3.
  1. Position a clean rag between camshaft and idler gears, then remove cam gear lock bolt and washers.
  2. Using puller set 49 0839 425C or equivalent, remove cam gear from camshaft, Fig. 3.
  3. Remove idler gear to spindle retaining nuts and washers, then remove idler gear and spindle assemblies.
  4. Remove injection pump drive gear.
  5. Remove timing gear case to cylinder block attaching bolts, then the timing case.
CAMSHAFT
  1. Remove tappets from cylinder block.
  2. Remove camshaft thrust plate to cylinder block retaining bolts and washers, then pull camshaft from block.
PISTON & CONNECTING ROD
  1. Remove connecting rod bearing cap retaining nuts and bolts, then separate bearing cap from connecting rod.
  2. Using the wooden handle end of a hammer, push the piston and connecting rod assembly outward until piston rings clear cylinder bore. Remove piston and connecting rod assembly through top of cylinder block.
  3. To separate piston from connecting rod, remove piston pin retaining clips, then press pin from piston using a suitable driver.
CRANKSHAFT
  1. Remove rear oil seal cap retaining bolts, then the cap and seal.
  2. Remove main bearing cap to cylinder block retaining bolts, then the main bearing caps and thrust washers.
  3. Lift crankshaft from cylinder block.
I’m happy to assist further over the phone at https://www.6ya.com/expert/uttamjeet_2f3adc18600f8ede
Mar 26, 2015 | Mazda Cars & Trucks
Hoover windtunnel V2 Brushes Not Turning
There is a worm gear that turns the brushes, it may be damaged
Aug 18, 2017 | Vacuums
TRANSMISSION SLIPS GOING INTO 2ND GEAR. IF I LET OFF THE GAS PEDAL FOR A MOMENT IT WILL GO AHEAD AND SHIFT. IM A SINGLE WOMEN WHO DOESNT HAVE ALOT OF MONEY BUT SERIOUSLY NEED MY TRUCK.
This is a solenoid piston seal problem. Use a transmission additive, Tranx is best, then Lucas. This will recondition the seals. I used it in my truck 3 years ago and no problems. A $10.00 fix.
May 17, 2011 | Ford Explorer Sport Cars & Trucks
I have a 1986 yamaha 540 srv snomombile and when i throtle it up it bogs out and pops like a backfire do you have a suggestion on what is causing this and how to correct it?
You should purchase a gasket and seal set, pull your motor out of the sled, disassemble the motor, and replace all the gaskets and seals. You can purchase a piston kit on line that should come with pistons , rings , gaskets , and seals.The main problem you are having is an air leak on one or both of the crank end seals. Usually the clutch side seal leaks first. If you continue to drive you will probably score one or both of the cylinders.When you have the motor apart clean your carburetors and replace your spark plug caps. NGK has new plug caps for about $5 each. If your cylinders look good i would consider doing a light hone job and ring replacement. Again if you just buy new aftermarket seals pistons and gaskets you should be able to do a complete rebuild for about $150. Then your engine will be good for another 25 years. If you are limited on funds Just replace the crank seals , clean the carburetors, and put on new NGK plug caps (about $30).
Jan 18, 2011 | Yamaha SR 400 Motorcycles
My Bostitch nail gun just start the end of the gun don't return the start place please help .
remove the piston cover screws and slide the piston out by pushing back the firing pin clean and oil all seals and o rings this area tends to collect dirt and sand and should be cleaned periodicaly
Jan 09, 2011 | Stanley Bostitch Nail Gun
How to clean spark plugs on 2007 honda cbr
Replace the plugs, don't try to clean them. The proper way to clean plugs used to be to sand blast them. The problem was that bits of sand can remain deep inside the throat of the plug. When the sand breaks free it causes damage to the piston, rings, cylinder and valves. The only safe way to clean them is to blast them with dry ice particles. Cleaning plugs is not a big industry. The equipment required is hard to find and is expensive. You have a lot of money invested in your bike. Spring for a new set of plugs. Please rate my answer. Thanks.
Aug 11, 2010 | 2007 Honda CBR 1000 RR Fireblade
How do you remove the rear axle to change the axle seal, from a 2004 Coloraro?
remove the center cover facing the rear of the truck. you will see side gears with the shafts axle end at each side gear. a C clip will have to be removed from each shaft at the end of each axle. Then remove the wheels and pull out the axles
Feb 06, 2010 | 2004 Chevrolet Colorado
I need to know how to dis/reassemble a 1974 DT 360?
A service manual ( if you can find one ) is what you need. The second thing you need is repair parts. They are pretty hard to find. Babbitt's, a well known distributor, only has parts left in stock for the top end. Go to their website, www.babbittsonline.com/parts/viewbybrand/parts.aspx
and you can see what is left. There's also a diagram of the crankcase center halves. If you can't get the repair parts, spending hours doing an engine teardown is fruitless.
The teardown will require a flywheel puller, a case splitter, an impact driver, and a torque wrench (somewhat optional). Disassemble the top end then remove the left and right side case covers. Remove the flywheel and related electrics, the clutch, crankshaft drive gear, oil pump, kick starter, shift shaft assembly, shift drum end cap and index pins. Now remove the screws on the center case and you can then split the case. This gives you access to replace shift forks, gears, and bearings. Note that crank seals can be replaced without splitting the case.
I am not trying to be a smart *** here, but re-assembly is just the reverse of dis-assembly. This is why a manual would help. Another potential source for parts is to Google motorcycle salvage yamaha .
The normal things you would need to replace inside the center case would be bent shift forks (if shifting is the problem), busted gears, crank bearings and seals, and sprocket shaft bearing and seal. All else can be replaced by removing just the side covers.
Dec 10, 2009 | 1974 Yamaha DT 360
1988 yz 250 ,lacking power,spitting oil,possibly power valve?
More than likely the majority of the problem is related to poor compression pressure. When was the last time the engine was re-built (a new top end)?
I would suggest evaluating the condition of the piston, ring and cylinder. Replacing the piston and ring and won't set you back much if the bore in the cylinder is good and it will definately perk your bike back up.
Clean that air filter too - a plugged filter will cause the bike to run rich, too.
Jun 04, 2009 | 2003 Yamaha YZ 250
Ingersoll Rand Ingersoll-Rand IR 315 Heavy Duty Air Twin Piston Inline Sander Logo
90 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Eddie Tucker
Level 1 Expert
John Trevino
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
