I have a Maytag Brovos Washer (dispensers in corners). I get an F-51 error code from time to time. The Maytag help websight says how to reset from this code. My wife ends up resetting it 2 or 3 times per load. I would like to know how to fix it so it doesn't show the error code f-5. Any help would be appreciated. Thanks, Tim
  • timshebel Nov 06, 2010
    Once I get the stator out, do I clean the connections and re-install ?
    Appreciate the speedy assistance.
  • 10,515 Answers
F-51 is RPS (rotor position sensor) error. The rotor position sensor is located under the rotor and connected to the stator. To get the RPS out you will need to unplug unit and tip it back. Loosen screw in middle of rotor and pull rotor off. The screw will not come all the way out but you it get loose. The rotor will pull off hard (magnets). You will now have to remove the four stator bolts and remove the stator. Watch the metal spacer when you remove the stator.The RPS clips onto the back side of stator.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 06, 2010
  • taran_2005
    taran_2005 Nov 06, 2010
    Thanks for your response!!
    To
    correct this, remove and install the the connector at the rotor
    position sensor (plug and unplug) at least three times to clean off any
    corrosion build up on the connector or the rotor position sensor due to
    the intermittent connection.
    Confirm that the connector is fully
    seated onto the rotor position sensor upon final connection and verify
    that there are no damaged wires. The electronic control unit may have to
    be replaced, since the upgraded version is less sensitive to
    intermittent RPS connections.
    Hope i helped you.
Hello what does f-51 mean on my maytag washer
Tabi, the Maytag folks state the F51 error code has to do with incorrect resistance reading from the motor. Without getting too technical, this can be caused by a number of problems. However, don't get discouraged yet.
A common problem with these washers is that it is relative easy for socks or other small articles of clothing to get ejected from the main tub and end up falling between the metal wash tub and the plastic tub that holds the water. Ultimately this prevents the wash tub from sitting centered and that can cause the F51 error.
Fortunately, this problem is easy to diagnose and fix. If you use a very stiff putty knife, you can release the spring clips that are about 6 inches in from each corner of the front of the machine. Once you have done that, you can raise the top of the machine. You can now use a flashlight and look down between the wash and outer tubs to see if anything is caught in there.
Please let me know if this helps or if you need more information.
Jan 29, 2015 | Maytag Washing Machines
What does it mean f 51
http://forum.appliancepartspros.com/washer-repair/131926-maytag-washer-error-code-f51.html
Jan 30, 2013 | Maytag Bravos MTW6600T Top Load Washer
Maytag washer flashes f 51
You will need to replace the RPS sensor. There is a kit available that will update that washer to the current design. Here is the kit to order.
Nov 23, 2012 | Washing Machines
Washer does not work it goes into error code f51
F 51 error code means the computer cannot detect that the motor is turning properly. The most common cause of this problem is an article of clothing has gotten between the basket and tub and is stopping the basket from turning freely. There are several other possibilities but I have seen this cause an F 51 error code many times. Hope that helps.
Aug 29, 2011 | Maytag Washing Machines
Brovos Maytag Showing a Error F1 is this an easy fix?
The code is caused by a water sensor. You can temporarily just dump about a half gallon of water into the tub before adding the clothes, and then have another half gallon for mid cycle. This stops the code from popping up. Try the half gallon thing and you will see.
I would try to run a few loads of towels with just water (no detergent or anything) to try and flush out any excess detergent residue you may have. I don't know if you are able to set your own water level on this machine, but if you are, I would just run an empty load or two.
Hope this helps...
Jul 23, 2011 | Maytag Bravos MTW6600T Top Load Washer
Ddo
Hi
This ddo error code means Dispenser Drawer Open.Check to see if the Dispenser Drawer is open or the small tubular Magnet # 51 is missing. The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself, you will see snapping clips to unsnap, then you will see the magnet#8 in diagram#1 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=117979
reference
http://www.fixya.com/support/t2180388-code_ddo
Mar 29, 2010 | Frigidaire GLTF2940ES Front Load Washer
Olivia just emailed, got charged the $12.95, but did not get her question answered by Charlie. We have Maytag Model MDE 2400AYW clothes washer, and it stopped mid cycle. We can not open the door of the...
the nd error which is showing up in the unit is due to something blocking the motor.mostly its a blockage to the motor and rarely its a faulty motor.it can be anything like hairpin,socks,coins any metallic object this has to be checked and reoved the error will go.
washer has a latch and lock on the door. If this lock fails to open when the cycle is finished. You can rescue your clothes by:
1) Remove the bezel from the soap/bleach/fabric softener dispenser.
2) Locate the red cord near the right front corner of the dispenser opening. Pull on this red cord. This will unlatch the door so you can rescue your laundry. Then call for service.
Nov 28, 2009 | Maytag Washing Machines
My Maytag flash F 51 and ul error
Unbalanced load, open lid and redistribute the load, close lid and press START/PAUSE.
Oct 19, 2009 | Maytag Bravos MTW6600T Top Load Washer
Kenmore HE2 Plus 110.47512600 Error Code F30 = Dispenser System Error. Have reset CCU multiple times. When cycle starts, dispenser motor runs for 3 minutes (~11 revolutions) then stops with F30 error
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 19, 2009 | Kenmore HE2 Plus Front Load Washer
Code ddo
Hi
This error code appears in the frigidaire washer which means--
ddo error--- Dispenser Drawer Open
GLTF1670AS0
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 08, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
