Question about Microwave Ovens
Need a SERVICE manual link for a GE Advantium SCA2001KSS01
  • 9 more comments
  • gooface Nov 06, 2010
    Thank you for the service manual! I got the cavity TCO replaced but don't see any instructions for location of replacing the magnetron TCO. Could you send that?
  • gooface Nov 08, 2010
    Ok, getting closer but not fixed. The microwave was shutting off by itself (like the breaker was flipped) and then would turn back on by itself. Finally, it went completely dead. I replaced the cavity TCO (one connector melted) and the magnetron TCO. Now it lights up but won't start. The thermal fuse (if that's the one behind the control panel) check ok with ohm meter. Maybe the second fuse is blown? I can't find the second fuse. Do you know where it is located? Any other ideas? Thanks!
    See the other fuse in the diagram? Could that one being out cause the problem?
    Well thanks for the bad news! Bummer, i was hoping i could fix it cheaply. Thanks for all your help!
    Thanks for the tips and the information!
  • gooface Nov 16, 2010
    Hello, asking for your help again. I ordered and replaced the control panel and was so happy when it all lit up, programmed, turned on, etc. I thought it was fixed! I reinstalled and hooked up the venting and went to cook something tonight, low and behold, microwave does not get hot. Something i may have left unplugged? Any ideas? Thanks, James
  • gooface Nov 18, 2010
    Hello, i need more of your help. Please read the last post i sent you. Thanks!
    which fuse is for the magnetron? The thermal fuse or the other fuse?
    where is the fuse on there?
    where is it located though? If that one is out, will everything work normal except the microwave does not heat?
    I appreciate your help and all your comments! You are one of the most thorough techs i have dealt with on this site and most helpful. Thank you for all you have done so far. I really appreciate it! I will remove the microwave again and take it apart and check connections and the fuse.
  • Microwave Ovens Master
  • 4,737 Answers
Here it is (Click Here), it's a pdf file of 7.7MB. You'll need a pdf reader like adobe reader or foxit reader to open and view/read the contents on your computer.
Click Here to download Adobe Reader.
You can also find more troubleshooting tips here (click here).
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Nov 06, 2010
  • 6 more comments
  • Lebanon Raingam
    Lebanon Raingam Nov 06, 2010
    I am sorry, this is the only service manual available on the internet. But if I am right, everything is mentioned with little differences. Try again on page No. 50, 53 and 57, it's labelled as "Mag. TCO", I think this made you confused.
    Let me know if you still need further help. For now, I have to retire.
    Good luck.
  • Lebanon Raingam
    Lebanon Raingam Nov 08, 2010
    The problem is because I don't have this same Unit to try myself. But when I checked the circuit diagram, there's no other fuse inside the "Thermal Fuse" i.e. from thermal fuse to varistor :
    If this is the one you've checked, Red Arrow, then the faulty must be on the Smart Board, likely one or some capacitors are blown out. This circuit diagram is on Page No. 53 (Manual), If it was the one with that 20 ampere (20A), then please recheck...
    For your reference, the Smart Board is on Page No. 52.
  • Lebanon Raingam
    No, if that fuse is out, then the the machine shouldn't boot as it connects the main components. I would suspect the capacitors or the Relay Board.
  • Lebanon Raingam
    Lebanon Raingam Nov 18, 2010
    Sorry for the delay. I am not very sure which part might have missed or which connection/component could be the cause, but with heating issue, you need to check the Inverter, switch (micro-switch) and magnetron. These are the only three components related to heating issues (if you've correctly reassembled the unit). Check the inverter board for damaged or bad capacitors or resistors, if you find a suspect, replace it/them. Check the Magnetron fuse and make sure it's not burned or the tip is clean. Verify that the switch is working. These are the things you need to take notes of.
  • Lebanon Raingam
    Well, let me simply show you a picture, it's like this :
  • Lebanon Raingam
    Sorry it's my mistake, i thought you were asking about the tube, the other fuse i.e. FUSE(20A) [look at the circuit diagram] is the magnetron fuse.
  • Lebanon Raingam
    I am sorry, I can't make that specific since this machine isn't with me, I am only referring to the circuit diagram to assist you. If you prefer, I would opt out. Assuming a problem virtually without inspecting physically is a burden for me and I think you'd feel the same. As per the circuit diagram, if that fuse is out, half of the "Smart Board", i.e. bottom part will not receive any power and the oven will not heat up. Thanks.
  • Lebanon Raingam
    It's Ok and I should apologize to you too.. If reassembling isn't fix the issue, I would highly recommend you to call a local tech or take it to a local repair store, I think that'll be better for you and will not waste another more time and energy. But it's also not possible in some areas where repair shops/centers aren't available. For now, I wish you all the best.
GE advantium SCA2001 BSS 03 manual
GE has the user manual for the Advantium above-the-cooktop oven SCA2001BSS on the product page: https://products.geappliances.com/appliance/gea-specs/SCA2001BSS . You'll find the link on the right hand side of the page under the Manuals & Downloads header. The manual is the same for two digit suffix versions of the oven. The direct link to the manual is currently https://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003670653.PDF .
I hope this helps.
Sep 10, 2018 | GE Microwave Ovens
Ge advantium 120 manual
You can download GE owner's manuals and installation instructions here.
The service manual for GE Advantium microwaves is here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Apr 26, 2013 | Microwave Ovens
I have a ge advantium speedcook oven #SCA1000Hww01. The top vent is broken and has fallen off and I need to replace it but can't figure out from the manual what the part number is. I'm sure
The service manual (with exploded views, disassembly info, and part numbers) is here.
You can order GE parts from the Pros here, our favorite supplier.
Jan 16, 2013 | GE Advantium SCA1000H Convection /...
I have a GE profile advantium oven 120 that is just over 1 year old the turntable rotates but as soon as I put on the glass or mental tray it will not rotate what is the problem?
Either the coupler is cracked, the motor is defective, or the turntable support ("rotating ring asm") is worn or defective.
The service manual is here and you can find links to helpful exploded view diagrams and order parts here.
Sep 26, 2011 | GE Advantium 120 Convection/Microwave Oven
Handle on the front of our GE Advantium 120 broke off need to find a replacement. We live just north of Boston MA
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The actual Advantium 120 service manual is at our site here.
You can find handy exploded views and order parts by model number here.
Dec 16, 2010 | GE Advantium 120 Convection/Microwave Oven
My GE Advantium model SCA1000HBB01 was cooking on the oven setting and suddenly quit working. As if no power. The circuit is still good. I was advised it was possibly a blown fuse inside the MV on the...
When you take the top off and stare into the unit you will see a white fuse in a black plastic fuse holder. Look carefully. I had to replace the melted fuse holder as well. Radio shack has the fuses and holders.
Sep 14, 2010 | GE Advantium 120 Convection/Microwave Oven
GE Advantium won't heat
Actually, these have a 10-year warranty on the magnetron and on the halogen speedcook lamps.
GE will even send you the magnetron to replace it yourself. Call them at 888-239-6832.
The full service manual with installation instructions is here.
Part ordering help (if you need other parts) is here.
I'd recommend that your bookmark this link to your favorites.
If you or someone you know want to replace the magnetron yourself, you will need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward. Thewy are in the service manual.
You can also download GE owner's manuals and installation instructions
here.
If you prefer to replace it though, I would suggest doing Google searches to try to find 240V microwave ovens. They're the exception.
Jan 10, 2010 | General Electric Microwave Oven
Strang Metal flapping noise
Is it like the sound in the video?
If so, it may be a bad damper control switch or the damper assembly may be binding.
If it's new, then it should be fully covered under warranty and GE should send a servicer out at no charge. GE Customer Service is here.
If it is not under warranty, then w
e have the service manual for this model and have uploaded it for you here.
You can find links to helpful exploded view diagrams and part ordering help here. I'd recommend that your bookmark this link to your favorites.
If you only need a switch, you can order a universal type here for $5 postpaid.
Dec 12, 2009 | GE Advantium 120 Convection/Microwave Oven
Advantium 120 convection/microwave oven dead after power surge
The removal instructions are on page 34 of the service manual, and we have uploaded it to our site here to help you.
Jun 28, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
526 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
