Asus uses the Award bios. When the bios detect an issue with a device like the video card, CPU & memory the bios lets you know there is a problem by sounding a series of beeps. Click on this link which will show what the bios beep sounds are telling you to check. http://www.bioscentral.com/beepcodes/awardbeep.htm
The bios beeping is telling you there is a problem with you're video card. Remove it. Use canned air & blow out the slot. Re-insert the card, firmly & evenly & make sure it is all the way into the slot.
Good Luck!
This should fix the beep error.
Mike
Check the memory or the harddisk..
Remove the memory modules clean them with an eraser . and put it back .
for smooth working of an AMD powerd system . u have to enable cool and quiet in advanced> cpu conf settings in bios ... then also enable asus Q- fan in h/w monitor tab in bios too ..
then surely intel can nver beat AMD
also check wether adeqaute heat sink compud in heatsink assembly
