Question about Nintendo Monopoly Here And Now Worldwide Nint. Wii Pal for Wii
How to set up 4 players for wii monopoly with only 2 remotes
3 Suggested Answers
  • 3 Answers
SOURCE: player 2 wii will not register? (bought new remote same problem) batteries good
try opening the back of the wii remote you should see a little red button then go to your wii and open the little sd compartment and there should be another red button press both the buttons at the same time and dont touch any other buttons and it should sync to you wii
Posted on Apr 19, 2009
  • 11 Answers
SOURCE: LEGO Batman: Player 2 remote unresponsive in 2-player mode
It's probably because you have two diferent brand remotes and the wii doesnt know which one your using
Posted on Jul 02, 2010
OK, i got a new wii remote, set it up, and now none of my wii remotes are working including the one i just set up.
Try these two synchronization processes and if it still doesn't work than contact me:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. This procedure must be followed for each additional Wii Remote added to your system.
    One Time Mode Synchronization
Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  1. Select the Wii Remote Settings option from the Home Button menu.
  2. Select the Reconnect Option.
  3. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
PCHELPSTER007 from youtube. If I helped you than please rate me up and if you have any other problems please feel free to contact. Thank you.
Jul 06, 2011 | Video Game Consoles & Games
Wii hand will not show up we tried syncing, taking out batteries, unplugging and plugging sensor bar and nothig works
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
    Standard Mode Synchronization
    Note: Make sure you have placed batteries in the Wii Remote (how to).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
    Go to the Next Step (Playing Game Discs) >
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Jan 27, 2011 | Nintendo Wii Console
We can only figure out how to play with two human players. Are we missing something or is it because we only have two Wii remotes? We'd like for 4 to play.
You can only play as many players as how many remotes you have. So if you only have 2 remotes you can only play 2 players. If you have 3 remotes then you can play 3 players ETC.
Nov 28, 2010 | Monopoly Streets for Nintendo Wii
How do i set up a second wii remote to my wii console
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
Hope this helps!
Feb 02, 2010 | Nintendo Wii Console
Can you use more than one stick??? i want to play four players with two sticks.
My experience from other games tells me that you cannot use one controller for 2 people.
Nov 17, 2009 | Nintendo Monopoly Here And Now Worldwide...
My wii counsel turns on fine, my remotes are with new batteries and flash when pressed the red light, but yhe remotes don't seem to be able to connect to the screen?
if your Wii Remote is not responding It may need to be synced up. I have given you both ways of syncing your Wii. After doing this Please don't forget to rate me as " Very Helpful" & feedback is appreciated - thanks
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please read below.
Standard Mode SynchronizationNote: Make sure you have placed batteries in the Wii Remote
Sep 22, 2009 | Nintendo Wii Console
My wii cant connect the 2nd remote at the opening screen why?
Yes, when you're at the menu, click the home button, at the bottom it should say something like "Wii Remote settings," click it. Now click "Reconnect," hold down 1-2 buttons simultaneously on all the remotes you wish to connect. If they won't connect, then you need to sync them, behind the battery cover on the back of every remote is a little red button, hold it down while holding down the red sync button on the wii, located next to SD card slot. Then try connecting again.
Hope this helps!
Aug 26, 2009 | Nintendo Wii Console
Multi player
Well: first. press the home button then go down and click wii remote setting s then click disconnect wii remote then both of you press the 1 and 2 buttons until it recognizes your wii remotes.
Feb 25, 2009 | Sega Sonic Riders: Zero Gravity for...
We have been playing gutar hero band and now our remotes only work on side how do i fix
  2. Select the Wii Remote Settings option from the Home Button menu.
  3. Select the Reconnect Option.
    1. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
  • this may reset the remotes for you
    info from nintendos customer service
    Jan 01, 2009 | Nintendo Wii Console
    Can't play with 2 players
    Make sure you have paired both remotes to your Wii console.
    Open the little door on the front of the Wii (under the disc slot), and open the battery cover of the Wii remote (but leave the batteries in).
    Push the red button on the Wii (next to the SD card slot), then push the red button on the Wii remote (next to the batteries). You should see the Wii remote's lights blink.
    Do the same for your other Wii remote.
    Now on the bottom row of 4 lights on the Wii remote, one should have the first light lit, and the other should have the second light lit. You should also be able to see a cursor for each remote on the Wii Menu.
    Apr 03, 2008 | Nintendo Wii Console
    Nintendo Monopoly Here And Now Worldwide Nint. Wii Pal for  Wii Logo
    488 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
