Question about Brother DCP-7030 Digital All-in-One Laser Printer
I have changed the toner and drum in my Brother MFC 7320 printer but the message 'Toner life end, change cartridge' is showing and it wont print. Please help!
  • 13433 Answers
SOURCE: Message on Brother MFC
Open door
press Clear/Back key
press *00
press OK
Do not choose anything for drum replacement. when drum replacement menu comes up, just press the * and then 00, then just press OK.
that should clear the error message, the printer has a toner life counter that needs to be reset.
Posted on Oct 04, 2010
reedwaan
  • 14 Answers
SOURCE: Toner end life message
i solved the brother mfc8860 toner life end problem
hi guys my name is reedwaan. Im new at this site so please listen up
my brother toner i refilled with toner and inserted it. It said toner life end then i patched the windows close on the sides and still the same problem, then i removed the toner and loosened the two screws on the left by the gears then removed the cover of the gears.
Right at the back there is a funny looking gear with a spring behind it. All you have to do is pull the spring a little bit clockwise and push the gear back on hooking the spring into it so that the gear is spring loaded. close it up then test it, It took me a while to figure it out but i got it right.
NB*  The gear that you push on, is the toner reset gear and when you push it on make sure the teeth dont interlock with the second gear on the left of it. If you have any queries mail me on reedwaan@yahoo.com
glad to help out
Posted on Jan 09, 2009
SOURCE: Brother MFC-7820N Toner Problem
Open the cover, press Options and then *00.
Posted on May 22, 2009
the kowalski
  • 86 Answers
SOURCE: BROTHER MFC 7820N MACHINE PUT IN NEW DRUM, CHANGE
To manually reset the counters, do the following:
  • Open front cover, press "option".
  • Answer Yes (by pressing 1) to the question in the display.
  • Your drum counter is now reseted. Press "option" again.
  • This time, press *, 0, 0.
  • Your toner counter is now reseted too.
(If nothing happens when pressing option, try using the back/clear button instead.)
Posted on Jun 15, 2009
  • 4 Answers
SOURCE: how to get ride of Toner life end message
You could try resetting the toner cartridge settings. OPen the machines front door where you would replace the cartridges. On the top panel you will see a "clear/back" button. Press it and on the display you will see a reset menu come up. Arrow to each one and hit the OK button. Press "1" to reset. Once you have gone through all close the front door of the machine and press stop to bring the display back to normal.
Hope this helps.
Posted on Oct 21, 2009
How to reset brother mfc 7320 toner life end message
Remove cartridge. Place a piece of electrician's tape over the small circular translucent window on the right side of the cartridge. Reinstall cartridge.
Oct 09, 2014 | Brother Tn2110 Black Toner Cartridge For...
Drum Life Ends soon - Brother
The problem with this is the design. Each toner cartridge has a microchip on it, that counts the pages you print. The company has determined that you get x amounts of prints. Then you have to replace it, empty or not. This printers do not work the same way as an expensive professional business copier. In an pro style there is a spent toner cartridge that collects all of the wasted toner that is on the drum. On a small business/home style this spent toner goes back into the cartridge. There is no level indicator, even on the inkjet printer. They too, have a chip that says you have x amount of prints/cleaning cycles they can go through. Look up inkjet refill kits or inkjet cartridge programmer.
Mar 31, 2014 | Brother Mfc-7340 All-in-one Laser Printer...
Does the 'Drum Near End' message for MFC 8460N mean to indicate the toner cartridge needs replaced?
Same with our Brother 8640N, drum near end means toner is nearly to end but sometimes even you replace bew cartridge is appears this message. TONER LIFE END message need to replace cartridge.
Dec 17, 2010 | Brother MFC-8660DN All-In-One Laser...
Brother MFC-9440CN Laser Printer is saying toner life end and I just put a new cartridge in.
If you want to reset your Brother MFC 9440N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 9440N should be reset and the Toner End of Life message should disappear. Warning, this may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Nov 11, 2010 | Brother MFC-9440CN Laser Printer
Replaced toner cartrige and the error message saying that the toner life is ended. any ideas
Try this.. It worked in my Brother MFC 7320.. SO it May work.. Open the cover. Remove Drum and Cartridge. Look inside. There are 2 LENS ON both sides. Cover the lens with a tape. Replace Drum and Cartridge. Click cancel. then click 1 for replace drum.. close cover.. Let me know if it works
Sep 20, 2010 | Brother MFC-7420 Printer
Brother MFC 7820N Toner life end with new toner
I found the following post on another site. It appears to work. If you want to reset your Brother MFC 7820N machine so you no longer have the error message: Toner End of Life, do the following:
The Brother MFC 7820N should be reset and the Toner End of Life message should disappear. WARNING: This may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Sep 07, 2010 | Brother MFC-7820N Printer
Installed new cartridge and comming up machine won't regognise it saying tonner life end install new cartridge
To reset the sensor after installing a new toner cartridge follow these steps. 1. With unit powered On, open the front cover. 2. Press the “Options” key. Display will show “Replace Drum?” 3. Press “Start” key. 4. Press 1,0 . 5. Display will show “Accepted” for approximately 2 seconds. Then display will change to “Cover Open”. 6. Close cover and see if Toner Life End error message has gone.
Try this. We are Brother authorized.
Apr 15, 2010 | Brother MFC-7420 Laser Printer
The toner tray will not pull out from the machine
Replacing the Toner Cartridge
The MFC can print up to 6,000 pages using a high yield toner cartridge. When
the toner cartridge is running low, the LCD shows TONER LOW. The MFC is
supplied with a standard toner cartridge that must be replaced after
approximately 3,000 pages. Actual page count will vary depending on your
average document type (i.e., standard letter, detailed graphics).
Discard the used toner cartridge according to local regulations. If you are not
sure of them, your local Sanitation Department. Be sure to seal the toner
cartridge tightly so toner powder does not spill out of the cartridge. When
discarding used toner cartridges, keep them separate from domestic garbage.
We recommend that you clean the MFC when you replace the toner cartridge.
1 Open the front cover and pull out the drum unit.
Place the drum unit on a drop cloth or large piece of disposable paper to avoid
spilling and scattering the toner.
2 Hold down the lock lever on the right and pull the toner cartridge out of the drum
unit assembly.
Caution
Handle the toner cartridge carefully. If toner scatters on your hands or clothes,
immediately wipe it off or wash it with cold water.
3 Unpack the new toner cartridge. Place the used toner cartridge into the
aluminum bag and discard it according to local regulations.
 Wait to unpack the toner cartridge until immediately before you install it in the
MFC. If a toner cartridge is left unpacked for a long period of time, the toner life
is shortened.
 You can use only a genuine Brother toner cartridge (TN-430 or TN-460), which
is specially formulated to ensure top print quality. Using another brand of toner
cartridge may void your MFC’s warranty. Warranty coverage does not apply to
problems caused by the use of 3rd party Toner, 3rd party Toner Cartridge or 3rd
party Drum unit.
4 Gently rock the toner cartidge from side
to side five or six times to distribute the
toner evenly inside the cartridge.
5 Remove the protective cover.
6 Insert the new toner cartridge in the
drum unit until it clicks into place.
7 Clean the primary corona
wire inside the drum unit by
gently sliding the blue tab
from right to left several
times. Return the blue tab to
the Home position ( )
before reinstalling the drum
unit assembly.
Reinstall the drum unit and close the
front cover.
Replacing the Drum Unit
The MFC uses a drum unit to create print images on paper. If the LCD shows
CHANGE DRUM SOON, the drum unit is near the end of its life and it is time
to purchase a new one.
Even if the LCD shows CHANGE DRUM SOON, you may be able to continue
printing without having to replace the drum unit for a while. However, if there
is a noticeable deterioration in the output print quality (even before CHANGE
DRUM SOON appears), then the drum unit should be replaced. You should
clean the MFC when you replace the drum unit. (See page 21-18.)
Caution
When removing the drum unit, handle it carefully because it contains toner. If
toner scatters and your hands or clothes get dirty, immediately wipe or wash
with cold water.
WARNING
Just after you have used the MFC, some
internal parts of the MFC are extremely
HOT! So please be careful.
The drum unit is a consumable item, and it is necessary to replace it periodically.
There are many factors that determine the actual drum life, such as temperature,
humidity, type of paper and how much toner you use for the number of pages per print
job. The estimated drum life is up to 20,000 pages. The actual number of pages your
drum will print may be significantly less than these estimates. Because we have no
control over the many factors that determine the actual drum life, we cannot
guarantee a minimum number of pages that will be printed by your drum.
Oct 02, 2009 | Brother MFC-9840CDW Laser Printer
Toner life ends
There are two units in the machine, a toner cartridge and a drum unit. The toner clips into the drum and then is inserted in the machine. If you changed the toner and you still get this message, you may have a bad or damaged toner detection sensor.
Jun 30, 2008 | Brother MFC 7420 All-In-One Laser Printer
Change of toner
I have a brother mfc 7840w
I first used the electrical tape trick and that worked for a while. Then got the toner low message again. I then tried the *00 trick, which works as follows:
1. lift lid and open front cover
2. press clear/back. "Replace Drum?" will appear on the screen.
3. Press "*00" it will then read accepted and the toner low error (End of Toner Life) should go away.
4. close it all up and your done.
Jun 08, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother DCP-7030 Digital All-in-One Laser Printer Logo
828 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
