Question about ValuSoft MasterCook Deluxe 9.0: Windows
When using Mastercook Deluxe 9.0, I can enter recipes but when I try to enter a note about the recipe, I get a screen that says Mastercook application has encountered a problem and needs to close. We are sorry for the inconvenience. Send/Don't send. Then I get a screen-The instruction at "0x74e7708e" referenced memory at "0x00000002". The memory could not be read" Click to terminate the program. Then Mastercook totally shuts down. How can I repair the program? Seems to be related to Windows Security Update for 10/12/2010.
  • 2 more comments
  • scottie_saum Nov 06, 2010
    I am running XP SP3 - thanks! I don't believe I have a restore point though.
    Well, I restored to 10/08 (10/12 Windows update was evidentally the issue with Mastercook), but restoring has introduced problem with McAfee (repeatedly getting alert that realtime scanning is turned off) - trying to figure something out now.
    Thanks for the help, micromatical!
    I have multi-user McAfee on home network.
    Here's what I had to do to fix all . . .
    I restored to my 10/08 checkpoint. (which fixed glitch wih Mastercook 9.0)
    I installed McAfee updates since 10/08 restore point. (which fixed 'real time scan' error introduced with restore).
    I also re-installed all Windows security updates since 10/08 except for KB2387149 (which seems to be causing the glitch with Master Cook 9.0).
    I also disabled Windows auto-update so that KB2387149 doesn't re-install.
    I will follow-up with Microsoft concerning KB2387149 and I will follow-up with Value Soft (for what good it will do, as they do not have a rep for good customer service).
    Thanks again!
    Excellent help, I really appreciated the time it saved me. Thanks, again.
    President:
  • 2,777 Answers
If you believe it is related to that security update your best bet is to try and roll back to an earlier time - before you applied that update. To do that you will want to go back to a previous restore point on your computer, hopefully they are enabled. They are enabled by default on almost all computers though..
To find out if you can do this I will need to know, what version of Windows are you running? Windows XP, Vista, 7...?
Please let me know and I can walk you through removing that security update or just restoring to a previous date so we can get it working again.
Just reply to my answer here and I will be right back with you...
Tim
Posted on Nov 06, 2010
  • 1 more comment
  • Tim Grayson
    Tim Grayson Nov 06, 2010
    Well let's check for sure here...
    Click START then go to ALL PROGRAMS then ACCESSORIES then SYSTEM TOOLS and finally SYSTEM RESTORE.
    Select restore my system to an earlier time and click next, it will let you chose a date if you have restore enabled and working..
    Go to a date prior to when you installed that "fix" or when you know for sure it was working. Walk through the process and it will restore your computer back to that date. Then of course avoid installing that "fix" that you believe caused this.
    l
    Thanks, let me know!
    Tim
  • Tim Grayson
    You should be able to just right click on McAffee and re-enable real time scanning. Is it the free edition of McAfee you are running, or one you installed from a CD? I assume you have rebooted against since restoring, it could just need a reboot / restart to get the issue to go away.
    Thanks
    Tim
  • Malainie Nov 20, 2010
    This is caused by a recent Windows Microsoft security update KB2387149, which can be removed through the Control Panel>Add or Remove Programs. Scroll down to Windows XP - Software Updates and look for Security Update for Windows XP KB2387149. Highlight it and then click Remove. After the removal your computer will reboot and the problem will be gone with Master Cook. It's not necessary to go back to an earlier restore point, which could affect other programs.
2 Suggested Answers
SOURCE: When using Mastercook Deluxe 9.0, I can enter
Go here on the Value Soft web site:
http://www.valusoftsupport.com/KBArticle.asp?kbid=6196
They have a patch to fix it, thankfully. I just spent about a half an hour with my brain exploding because I was having the same problem you're having! You have to download the patch, unzip it into the 'program' folder of the MasterCook folder, then launch MasterCook. If you don't get the patch unzipped into the right place, it doesn't work. Thankfully, if you put it in the wrong spot (as I did) you can just drag and drop it into the 'program' folder.
Posted on Dec 12, 2010
Testimonial: "Yay it worked! Thanks so much. I'm a personal chef and use this software daily so this fix was a lifesaver. "
When using Mastercook Deluxe 9.0, I can enter recipes but when I try to enter a note or select a category (any of the tabbed options), I get a screen that says Mastercook application has encountered a...
Nov 12, 2010 | ValuSoft MasterCook Deluxe 9.0: Windows
The following appears whenever I try to print a recipe MASTERCOOK APPLICATiON HAS STOPPED WORKING A problem caused the program to stop working correctly. Windows will close the program and notify you if...
If you have the install media (cd or dvd) uninstall it and try a fresh install.
You may get it working by using system restore to turn your pc back to when it last worked.
Start / programs / accessories / system tools / system restore
Sep 21, 2010 | ValuSoft MasterCook Deluxe 9.0: Windows
I have the cosmi 20,000 recipies perogram in my old computer and the hard drive went out. I got a new Acer with Windows 7 and cannot get the old disk to load. The former computer was running Windows XP...
i think u are probably out of luck. this software looks like it came from the late 90s and will work with anything up to xp, but vista & win7 are a whole different ballgame. best solution, buy an old laptop with win98 or 2000 or xp super cheap on ebay, or beg one from a friend, and use ur software on it there in the kitchen. that's what i do with my old laptop. works great if u have room in the kitchen lol
also transfer ur fave recipes from 20,000 recipes to a recipe organizer program like mastercook, it's much much better for searching plus u can enter 1000s of new recipes from anywhere. u can get older versions of mastercook for $5 on ebay. version 8 works just great for me with winxp. (WARNING if ur interested in mastercook on ur NEW computer, get version 11, the older ones DON'T work w/Vista or win7.)
Jan 22, 2010 | Cosmi 20,000 Recipes with Party Planner...
Unable to open recipes
Are you getting any errors? If yes, kindly post it in here.
Sep 22, 2009 | ValuSoft MasterCook Deluxe 9.0: Windows
Using MasterCook to print my own cookbook
Have you checked for a software patch update? If a patch does not fix the issue, you could print 1 category at a time, instead of the whole cookbook.
Apr 16, 2009 | Computers & Internet
Wanting to upgrade old Mastercook program to meld to new computer
ValuSoft says that MasterCook 9.0 is only supported in Windows 98-XP. Specifically not Vista compatible. What's wrong with these people? I have Vista and didn't realize until tonight that some of MasterCook doesn't work right. So, buy XP.
Jan 15, 2009 | ValuSoft MasterCook Deluxe 9.0: Windows
MASTERCOOK
removing Clutter from work que and and forumn boards
Jun 25, 2008 | ValuSoft MasterCook Deluxe 9.0: Windows
ValuSoft MasterCook Deluxe 9.0: Windows Logo
207 people viewed this question
Top ValuSoft Computers & Internet Experts
Mike
k24674
Edwin
Are you a ValuSoft Computer and Internet Expert? Answer questions, earn points and help others
