Question about Sony Handycam DCR-TRV530 Digital Camcorder
No sound records sony dcrtrv530
Everything seems to work except no sound is recorded on the tape sound works on tapes recorded before
  • Sony Master
  • 2,794 Answers
I reviewed the owners manual to your camera.
On page 126 it says this:
1)The stereo tape is played back with HIFI sound set to 2 in the menu settings.
Set it to STEREO (see page 79)
2) The volume is turned to a minumum.
Press Volume + (see page 27)
3) Audio Mix is set to ST2 side in the menu settings.
Adjust the audio mix (see page 79)
If one of those 3 options doesn't work, try using an 8mm tape head cleaner.
Posted on Jun 15, 2008
My vcr plays commercially-recorded tapes fine, but tapes recorded on it or another VCR play with the sound distorted. The picture seems fine.
Sounds like its mechanism need some alignment. Guide pole alignment. Contact any service technician. This is technically skilled work. http://electronicshelponline.blogspot.com/
Jul 18, 2015 | Panasonic Televison & Video
I want to begin converting music from my computer onto cassette tapes using a device i've just bought. Can i use this device to firstly, override tapes? And Secondly does my record button even work?
check the top of the tape cassette if plastic removable tabs missing it will behave like a read only cassette if missing sticky tape can be used to cover the holes to make cassette recordable.
Jul 11, 2015 | Audio Players & Recorders
Tascam 488 Tape Recorder
Have you tried playing the tape in another device? Adjusting the recording volume if that is an option? Look for the user manual pdf online and also try a brand new or different brand tape to ensure that is not the problem.
Nov 16, 2013 | Tascam Audio Players & Recorders
HI when I use my cam (sony handycam D8) in the play mode to read videos the tape turns but there is no vids and the time counter is --:--:-- means not counting even if I can hear the sound of the...
Try to use cleaning tape there is must be dust on video head. First use cleaning tape for 5 secound then play you tape if its not ok then use more 5 secound. After that check your recording tape hope fully it will work.
Oct 28, 2010 | Sony DCR-TRV270E Digital-8 Digital...
Sony handy cam Hi 8 ccd trv308
Sony has a recall on some of these ccd imager problems. Contact Sony to see if your model applies, but it sounds like an imager problem on your pal format camcorder. Larry
Apr 19, 2010 | Sony Handycam DCR-SR220E HDD Camcorder
Tape Wont Play
My advice is that you should by a cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
May 10, 2009 | Sony Handycam CCD-TRV58 Camcorder
DSR 11 won't record DV tape to its end
You need to use longer tapes. The DER-11 is a DVCAM deck which when recording, uses a faster tape speed then mini DV. Think of your older VCR's. They had SP, two hours, and EP or SLP, which would be six hours. The SP speed would give a better picture. DVCAM is more like an SP recording except digital and a lot better. More information is laid down on the tape.
You'll have to jump up to the full size DVCAM tapes in order to record the full hour.
Apr 10, 2009 | Sony DSR-11 DV / Mini DV VCR
Pixelated recordings
clean heads and tape transport with head cleaning tape, worked for me. had to run the tape 3 times at 10 second intervals with a 30 second cool down between runs. Dont clean for more than 10 seconds at a time as the cleaner tape heats up head and will fuse dirt onto head if overheated.
Jul 07, 2008 | JVC GR-D290 Mini DV Digital Camcorder
DV Cassettes vs Memory Stick
Well, I went to The Sony site and what I found out was that currently this camera is only ceritfied for a 512mb stick. It does say what the qualiy is the memory stick is E-mail mode with a resultion of 160x112 pixels. The TAPE mode is DV quality or 740X480 pixels. Try recording both ways and see what looks better when you play it back on you TV or PC then decide.
Sep 14, 2005 | Sony DCR-PC350E Mini DV Digital Camcorder
Sony Handycam DCR-TRV530 Digital Camcorder Logo
132 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
