Question about Garden
Red lite on the straight blade indicator plug (PS5266XGCMCCV4) This is a line that runs under ground to an outdoor chicken coop. I'm sure the wiring is correct, if black plasticed wire to brass screw and white plasticed wire to the silver screw is correct., The ground wire was not individually coated at all, so I hooked to green. assi . Now what? If reversed polarity is indicated, does that mean switching white and dark is indicated? Thanks. Will ythd
    Brigadier General:
  • 4,088 Answers
You have the connections correctly done. I hope that you ran the wires through plastic conduit for the under-ground run. What is connected at each end? Is the circuit causing the source breaker/fuse to trip? Are you making direct connection to your house service panel or just plugging the extended wiring into a socket in the house? The hot black wire should go to the breaker/fuse, the white wire should go to the neutral bar, and the ground wire should go to the ground bar. Hope this makes sense and helps!
Posted on Nov 07, 2010
Top stich perfict but bottom stich too loose on vivo singer machine 1004
Your bobbin tension needs adjusting, and although it is not hard to do and doesn't require that you take the machine apart, you MUST do it systematically. If you don't, you'll make things worse.
First, download the user's manual from the Singer site if you don't have one. On page 20, you'll see a discussion regarding tensions, and what improper tension looks like. Tension is a balance between the top and bobbin.
Then, using scrap fabric, set your top tension on Auto and make sure your needle is all the way up in the clamp. Run a line of straight stitches, and next to it, run a line of zigzag stitches, maybe four inches, and examine it. The illustration on that page will show you what your straight stitches SHOULD look like. If your zigzag stitches show one side that looks like "chicken tracks" but the other side looks like it should, the chicken tracks side is too tight. In your case, if the bobbin is too loose, the top will look like chicken tracks. It helps a lot to use two different thread colors, as well as a third for the fabric.
To adjust the bobbin tension, you will need a tiny straight blade screwdriver. If you have an indication that the bobbin side stitches are too loose, take the bobbin case out of the machine and locate two screws on the side. One is a Phillips--don't touch it. The one on the left of the Phillips is a straight-slot screw--that's the one you want. The saying is "lefty loosey, righty tighty." If your test indicates the bobbin tension is indeed too loose (which can happen over time), you need to tighten it by turning the screw 1/4 (ONLY) turn to the right (righty-tighty). Test again. You should see at least some improvement to indicate you're on the right track, and repeat--turning ONLY 1/4 turn--until your top and bottom tension are balanced. Don't forget to also test with a zigzag; I have adjusted bobbin tensions in the past that looked OK on the straight stitch, but the zigzag indicated I wasn't quite there yet.
Jun 25, 2014 | Singer 2638 Mechanical Sewing Machine
City ordinances farm animals
you might try contacting city hall and see if they can help you
Oct 22, 2013 | Computers & Internet
The mechanic says it's about $800 to do the water pump in an 04 tiburon. is this a typical price to pay?
It's kind of an arbitrary question. It depends on what type of mechanic, what kind of shop he works for, and your geographic location. That being said, it's actually a fair price for a reputable mechanic. However, I'd be a little leery if it's a guy working out of an old chicken coop. (Anyone working out of an old chicken coop...please don't take that personally...I'm sure yours is a very nice chicken coop.) Thanks for using Fixya.
Sep 10, 2011 | 2004 Hyundai Tiburon
Setting up a jig saw to cut a straight 1/4 inch
You will need two C clamps and a straight edge,I use a metal yard stick.Whatever you use look down the edge a make sure it's true.
Set up on the line and make sure the blade is going to cut on the waste side of the line.Measure the distance from the edge of the wood to the other side of the jigsaw glide plate and make a mark.Transfer the measurement to the other end.I move the blade up just above the surface so I can set the jig saw on the wood while I get the measurements.The last step is to clamp the straight edge down.Make sure to have the clamps with the handles down.Check under to make sure you won't run into any thing and do a dry run to check for cord hang ups.This is the best way as long as you keep the edge of the bottom jig saw plate against the straight edge.^^^^ Well that's how I do it. good luck
You can all so use the T bar attachment that slides through the bottom plate and clamps down with thumb screws.Personally I like the straight edge.
May 10, 2011 | Skil 94500 Jig Saw Rip Fence
How do I set a plug in timer GE 24 hour Model 15075? There are tiny switches for every hour and can be pushed towards the inner circle or pushed outward. And there is a turning arow near the center and a...
Following link has a close-up photo of on-off pins on GE 15075 timer
http://waterheatertimer.org/GE-timers-and-manuals.html#15075
Pins are located around timer dial
The pins divide 24-hour day into 1/2 hour segments
Pins are out for ON
Pins are inward for OFF
Notice that numbered dial is divided into dark and light areas ... the dark areas are PM, light areas AM.
For example you are connecting chicken coop lamp to this timer.
Turn lamp on and make sure bulb is working.
Plug lamp into timer.
Set pins in and out as follows: all pins outward between 4:30 pm on light part of dial to 8:00 pm on dark part of dial. And then set all pins outward between 5:00am on dark part of dial to 7:00 am on light part of dial.
Plug timer into outlet
Move switch located on top to TIMER ON
Manually rotate timer dial clockwise to see lamp turn on and off.
Lastly, set current time: Manually rotate timer dial clockwise until current time lines up with arrowhead located on inner dial. So if current time is high noon, then rotate dial until 'sun' symbol located on light part of dial lines up with arrowhead.
As time passes, the timer dial rotates, and the pins click circuit on-off.
To override timer, move switch to outlet-on.
Jan 09, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
I have a roper dryer 4 cycle model # rex4625ew1..I recently moved into a mobile home and I changed my plug from a 3 prong plug to a 4 prong plug..I did what the instructions said on the back of the dryer.I...
First, I'm confused about your dryer cord change. The green ground wire should NOT be connected to the neutral terminal block - but rather stay connected to the dryer cabinet. Here's a detailed link the describes (with photos) how to change a dryer's 3 wire cord to a 4 wire cord. This work should be double-checked to make sure you've done it correctly and have a safe installation.
Since you're not getting the dryer to run (you didn't say if it spins but has no heat or if nothing works at all) and you've checked the components of the dryer; the only thing left is to make sure there is 240 volts at the dryer outlet.
Make sure the power is ON. You should have either a 2 pole 30 amp circuit breaker or two 30 amp fuses that provide power to this outlet. Make sure the fuses are good / circuit breaker is ON (not tripped).
Do not touch a metal probe at any time that one is connected to the outlet in the steps below.
With a meter set to 250 volts or higher range - or a wiggy tester, slip each of the probes into one of the two straight blade openings in the outlet (use of a test lamp is discouraged as there is not voltage reading provided - it should only be used to indicate the presence of power). You should have a 240 volt indication (an indication of anywhere between 220 and 250 volts is acceptable).
Remove one of the probes and press it into the ""L" shaped opening; leaving the other probe in the straight blade opening. A 120 volt indication should be present (an indication of anywhere between 110 and 125 volts is acceptable for this and the following 120 volt measurements).
Remove the probe from the "L" shaped opening and press into the "O" shaped opening. Again, 120 volts should be indicated.
With the probe kept in the "O" shaped opening, remove the other probe from the straight blade opening and insert into the other straight blade opening. A 120 volt indication should be present.
Remove the probe from the "O" shaped opening and press into the "L" shaped opening. Again, a 120 volt indication should be present.
Remove the probe from the straight blade opening and press into the "O" opening. There should be a zero volt indication. A value of one or two volts is acceptable - but zero is expected.
If you get results that deviate in any way from those listed above, there is a problem with the circuit. An electrician should be called if the circuit breaker can't be reset or if fuses blow. If the voltages are indicating correctly but dryer still won't operate, there may be an issue with cord wiring or internal controls or safety devices inside the dryer.
I hope this helps. Please rate this reply - thanks!
Jan 04, 2011 | Roper REX4634KQ Electric Dryer
HOW TO REMOVE CHICKEN CRACK FROM PSP 5.03
well, seeing as you will never run it under hot water, that stuff that is used to fix scratches in lenses of glasses, acryllic, should work. And how in the heck did a chicken get to your game system?! (don't answer that, it is a rhetorical question)
Oct 04, 2010 | Nintendo DS Lite White Console
Do not know how to wire aIntermatic T 1906 timer
is not so hard. go to www.electricsuppliesonline.com click on search/shop by brand, search for intermatic, select your device, one or two pole, and read the diagram .going in needs 3 wires, line (pr black) neutral (white) and ground. out also 3 wires line, neutral and ground. disconnect before wiring. good luck
Feb 14, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
How to cheat in farmville
There used to be a few ways to cheat, like getting more than one chicken coop. But they have patched many exploits including coop stuffing for golden eggs.
The closest you can come to really cheating is to use a program to take care of your farm for you.
Feb 02, 2010 | Facebook Social Network
Suzuki bandit 600 can i plug an led rear light/indicator straight into the same sockets that comes of factory standard ones
Howdy: Yes, the LEDs take a low amp to lite and doing it that way it will always have a fuse for protection in the line. Be sure to use a + volt tester to be sure you got the correct color wires. Ride safe - Doug
Dec 08, 2009 | 2004 Suzuki GSF 600 S Bandit
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
