Wiring diagram for invensys up2 programmer - Heating & Cooling
To reset the time on our UP2 central heating programmer to winter time I've bach one hour
Spring ahead fall behind. Fall set clock back one hour.
Hope this helps?
Oct 31, 2016 | Heating & Cooling
How can I download an installation guide for potterton ep6002 programmer
Unfortunately unless you are trained as an installer of Potterton equipment you will not be able to get any advice from Potterton, they don't even supply direct to trade, everything is supplied through nominated suppliers, ie; Plumbers merchants.
This programmer should be quite easy to install I would have thought, in general all remote programmers have a mini wiring diagram on the back of the unit, though this will only show connections for the programmer outputs, ie heating on/off and water on/off.
If you require a wiring diagram for a complete heating system, you need to know the type of heating plan you have/are installing.
Hope this helps, if you need any more info get back to me.
I have just googled this and you can actually purchase from Amazon (not that I would do myself, I would use the merchants) there is a wiring diagram on the site. Just google Potterton EP6002, it comes up straight away Good Luck
May 23, 2014 | Garden
I need timer motor for paragon mod# 7007-00
1) Open following link for Paragon timers and manuals:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#7000
2) 7007-00 is 4PST timer with 120Volt clock motor.
3) M3099-00 120Volt clock motor for 7000 series is available at Invensys for $32.24
http://www.energyequipment.com/p-88069-invensys-climate-controls-m3099-00.aspx
3 to 4 weeks lead time.
4) Intermatic replacement is T7401B
40 amp 7-day timer with 125 volt clock motor, 4 independent loads, each load turns on-off at same time
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t7401b%20-%20english.ashx
Intermatic at 1000 bulbs 135.52
http://www.1000bulbs.com/product/3377/ELEC-T7401B.html
Intermatic Amazon 122.00
http://www.amazon.com/Intermatic-T7401B-7-Day-Switch-Steel/dp/B000GHN9JG
5) If you want 30 amp electronic timer with 4 independent programmable circuits that can turn on-and-off with different schedules, then Intermatic ET70415CR for $700+
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 10, 2011 | Hardware & Accessories
I would like a circuit diagram for a Kleenmaid CH 14 Cooktop
Hi, I too have had a problem with the dual element on the Kleenmaid CH14. Likewise I was given an Invensys M82314 which as you will know is not configured in the same way. However, I assume that what they call"phase" is the active connection, the neutral is marked and are side by side like the old one, pilot is idicated and is the wire that bridges together with the other switches....you are only left with two...."load1" and "load2" whichever way around I apply those I can only get my inside burner to run. I am baffled !! My old switch operates both burners but keeps cutting in and out.
Nov 11, 2009 | Cooktops
Sir i need circuit diagram for ups for my mini project
use this link, it will help you a lot. http://en.wikipedia.org/wiki/Uninterruptible_power_supply rate it if you find it good enough, if not ill help furhter. goodluck
Jul 23, 2009 | Powerware Invensys FERRUPS 1400VA...
INVENSYS CONTROL FOR KENMORE ELITE SIDE BY SIDE
Hi, you can purchase replacement part on amazon, here: Amazon com KENMORE ELITE INVENSYS CONTROL I hope this was helpful. Cheers
Apr 27, 2009 | Kenmore Refrigerators
Changing boiler programmer
take digital pictures - label all wires and reconnect - you do not need manual.
Oct 27, 2008 | Water Heaters
Need a circuit diagram for ups
hello sir, i need a circit of ups and usb and other circuit.i am student of DAE in electroics this diagram need a project of DAE send me plz i shell be very thankful you.
Apr 02, 2008 | Powerware Invensys FERRUPS 1400VA...
Heating & Cooling Logo
337 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
