Question about GE 35GT695 TV
Width and Height adjustment help
The picture is too large for the screen....please help
Jay
  • Anonymous Mar 31, 2014
    Too large for my screen
Dsaf
Posted on Oct 15, 2008
Picture adjustment on a samsung ue40f8000
Hi
You cannot choose individual width and height but in Tools > Picture Size you will find Auto Wide, 16:9, Wide Zoom, Zoom and 4:3
Hope this helps
Nov 07, 2013 | Samsung Cameras
I have a Sylvania 6427 17
It sounds that the width of the picture to your TV is more than normal. There are two reasons for this fault. If the width adjustment data value in its service menu mode has been misaligned or the output DC voltage from the main power regulator is more than normal. You can determine which among the condition stated above is now effected to your TV
Just look at the picture. If the width and height of the picture is seem to be more than normal, make sure that the power regualtor section circuit has the fault. If the dimension of the picture is affected to its width only, [excess than normal] the data value with service mode should be checked.
Also note the position of the picture. If the picture position has moved so much than normal, ether towards left in this case, you have to adjust the picture position. Anyway, it will be best to contact any experienced service technician, since, service mode entry and data adjustment are skilled work.
Jul 31, 2012 | Sylvania 6427GG 27" TV
Picture to large for the tv screen, some of the picture goes off the screen
Some sets and some boxes used for signal have adjustments for width and height of picture---another possible reason is set has a problem.
If it does not have this issue with a DVD etc hooked via rear inputs it is a signal related issue.
May 01, 2012 | Televison & Video
My TV picture keeps stretching beyond the screen. Can I adjust it?
Some sets and some CABLE OR SAT BOXES also have a feature where you can adjust height or width of the picture--look carefully in both units menus to see if you have it.
Mar 30, 2012 | Televison & Video
How to enlarge a picture that is scanned or copied? When i scan or copy a picture it is too small and I want to enlarge it in order to view it better.
hi
Open an image. Go to the Image Menu and select Image Size. This is where you can change an image’s resolution and print size (width and height). The following Image Size dialog box will appear:
Notethat the width and the height of the image as you view it on yourmonitor is not necessarily representative of the image’s actual widthand height—i.e., the size it would print out at (print size).Average monitor resolution is 72 dpi. If you view a 72 dpi image at100% in Photoshop, chances are that it will appear on your screen inits actual print size. However, this is not true when viewing a 300 dpiimage. A 300 dpi image viewed on-screen at 100% will be enormous. Don’tget tricked into believing that what you see on your monitor is whatyou’ll get when you print or place the image into another application.The best way to determine what your image’s actual print size will beis through the Image Size dialog box.
When the Resample Imagebox is checked, any changes you make to an image’s width or height willnot change the image’s resolution, and as such, any changes you make toan image’s resolution will not affect the image’s width and height.Keep in mind, however, when you increase width and height, orresolution, with the Resample Image box checked, you are adding pixelsto your image. These pixels don’t actually exist so Photoshop mustcreate them. As such, you will succeed only in degrading the quality ofyour image.
If you want to increase an image’swidth and height, or resolution, then uncheck the Resample Image box.Now any changes you make to the image’s width and height will changethe image’s resolution, and vice versa:
  • If you decrease resolution, the width and height will increase.
  • If you increase resolution, the width and height will decrease.
  • If you increase the width or height, the resolution will decrease.
  • If you decrease the width or height, the resolution will increase.
Thebest way to increase the width and height of a scanned image is to scanthe image in at a high resolution (about twice what your finalresolution should be), and with the Resample Image box unchecked, decrease the resolution. Once the image width and height is where you want it, you can then check the Resample Imagebox and type in the resolution you want if the resolution is too high.At this point, as long as you don’t increase resolution, or width andheight, your image quality will not suffer.
Aug 07, 2010 | HP Officejet 5610 All-In-One InkJet...
Picture is out of line
One of the following may be misaligned. i) Aspect ratio of your TV may be wrongly selected. i.e. select 4:3 in place of 16:9 or vice versa with your Remote . ii) Picture Width or Height may be wrongly adjusted. With the help of Remote, select MENU go to PICTURE option, reduce height or width which ever is needed.
Have a nice day Rating the solution is highly appreciated.
Mar 07, 2010 | RCA HD52W58 52" TV
My lg 14 inch crt desktop monitor pictue become
The CRT has screen adjustments, there is a screen adjustment button on the monitor that will allow you to adjust the width of the image as well as the height etc.
Jan 21, 2010 | LG Studioworks 775N 17" CRT Monitor
Picture too big for screen.
go to menu and adjust screen size(picture size)
Jul 29, 2009 | Hitachi FDX Series 43FDX10B 43" Rear...
Lg flatron 775ft screen size problem
Hi Edit123,
U can chane output width and height from buttons given on LCD panel manually
Sep 19, 2008 | LG Flatron L1750S 17" LCD Monitor
Televison & Video Logo
60 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
