Question about Hatco C 24 Compact Electric Booster Water Heater
Water heater water will not stay hot. You have to have the tap almost turned off to get hot water.
    Novelist:
  • 161 Answers
There are 3 or 4 elements in there. One or more are bad. Just disconnect the wires and check for continuity. Check the thermostats too. The most common problem is sediment build up. If it is really bad you have to take the elements out and flush out the tank. Use Lime Away or similar product. Sometimes there can be so much build up there isn't room for the water and it will burn out the elements. This only has a 5 gallon tank so it doesn't takd much.
Posted on Jul 07, 2008
My water in my master bath is not staying hot. How do I t6rn up thenhot water for my shower
Do you have consistent hot water from other taps in the house? If not, try turning up the thermostat setting to a higher temperature on the hot water heater. If it is hot and then the temperature drops, you may not be producing enough hot water and may have electric element burned out in your water heater, if indeed it it electric.
the last thing to check if your hot water is constant and strong at other taps is to replace your temperature regulating valve on your tub.
Jan 23, 2018 | Home
I have a Rheem Hot water heater that has a broken valve release. The part that turns on the valve. How can I drain it if I can not get this part to turn?
Turn off the main water to the house , turn off gas to heater open lowest hot tap to take pressure off .Undo union on hotwater tap outlet on heater more water will come out , open cold tap at sink that will take pressure out of main . you should be able to change valve with out getting too much wet .
Jul 12, 2017 | Rheem Water Heaters
I have a new Bradford white 40 gallon gas hot water heater. There are no single handle faucets. The hot water fluctuates between hot and cold. When I close both inlet and outlet shut off for the hot water...
Sounds like water leak.
For example, broken pipe... or water running out of TP valve.
That would explain variable hot-and-cold water at tap.
Turn off all taps, and observe if water meter is registering water usage.
Jun 15, 2014 | Water Heaters
The burner on the heater is working bu can't get water to stay hot at the faucets or showers water turns cold right away. whats the problem?
Test for crossover, where bad faucet cartridge or recirculation check valve keeps hot from reaching taps
http://waterheatertimer.org/Crossover.html
Add a comment and say what you find
Feb 28, 2013 | Rheem Water Heaters
Water won't stay hot long
1) Thermostat may be bad, or out of calibration. Set temperature higher, and/or troubleshoot by type of gas control.
Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Dip tube broken
http://waterheatertimer.org/Water-heater-dip-tube.html
3) Water leak running hot water out of tank.
Turn off all taps and put ear against pipe listening for water leak.
Dec 08, 2012 | Water Heaters
Puma 80 potterton hot water on and off
Boiler compartment ventilation will not stop you getting hot water . Its sounds like you have problems with a sensor or the water section on the boiler .
Apr 20, 2017 | Water Heaters
Our Infinity RX26 is cutting out soon after the hot water tap is turned on, we get a few seconds of hot water then nothing. We are cold! please help!
sounds like faulty thermostat controller disconect from hw unit and try the water again if it stays on the controller is faulty if you dont mind not having controll over the temp of the water you dont need a controller to opperate the hws
Jun 10, 2011 | Rinnai Digital Remote Water Heater Control...
Wont stay fired up
Bosch tech support will ask you to turn off the valve to the water heater and open a hot water tap. If you have water flowing it is likely from a shower valve. My experience is Price Pfister shower valves are usually the culprit. Let me know how this turns out.
Apr 09, 2010 | Bosch GWH 425 EF N Water Heater
No stop tap. cold water coming through cold taps in caravan but no hot water the carver cascade water heater is getting the water hot but it just wont come through the taps in the shower room or kitchen in...
your pipes are clogged, what if you were to not turn on the cold and turn on the hot does any water come out at all, with just the hot side turned on,, if not there could be a valve that has been turned off, or the pipes are clogged
Jun 17, 2009 | Reliance & 40 Gal Mobile Home Water Heater...
Hatco C 24 Compact Electric Booster Water Heater Logo
121 people viewed this question
Top Hatco Kitchen Appliances - Others Experts
Craig Butler
Craig Butler
Pat
Pat
Level 1 Expert
Tom Chichester
Are you a Hatco Kitchen Appliances - Other Expert? Answer questions, earn points and help others
