Question about Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18"
No bar oil circulating... ran without the bar on and there is not enough bar oil coming out. checked the reservoir and cleaned bar- no gunk... how do i get the plate off to inspect the tiny compartment where the bar oil is let out at the chain? at the crank shaft i see that it is reversed threaded, but do i have to undo the spring clamp system or can i just unthread the breaking mechanism or whatever it is on the end of the crank shaft... if so do i have to use the trick with the spark plug and string to keep the shaft from turning while unscrewing the top part?
    Brigadier General:
  • 4,088 Answers
The item on the end of the crankshaft is the clutch (inner part) and also part of the chain brake (the outer part of the clutch drum). There should be an oil-volume adjustment screw located under the case near where the chain returns to the engine. Turn it CCW somewhat to increase oil volume. Be sure to clean the small oil passages that run from the large holes in the drive end of the bar out to the chain groove on each bar edge. The correct way to set it is have everything assembled, start the engine and run at speed for a few moments with the bar tip near some cardboard--it should throw off a thin line of oil. Hope this helps!
Posted on Nov 07, 2010
Chainsaw rattles when it stops
personally too much hassle prefer Stihl Chainsaw more reliable Seizing is caused by lack of lubrication, First check all level has oil pump seized or is it sump type when running oil circulates all way round, Still there has to be a oil reservoir if this is bone dry theres your problem the rattling is metal on metal with no protection and the damage is seizing caused by lack of oil I have two chainsaws both have oil sumps and are kept full, please check hope this helps
Feb 15, 2014 | Poulan Pro PP5020AV 50 cc Gas Powered...
Does this 2stroke engine need the chainoiler reservoir(hence oil circulation and lubrication)to operate a gokart or is the gas\oil mixture enough?its easier to mount less one chainoiler reservoir
One reservoir is just for the lube of the chain.if you don't use this ,your chain will get hot and stop working the other one is for the engine to keep it lubed, you need both
Jan 10, 2014 | Garden
How to replace chainsaw chain
The bar is usually clamped with two hex nuts, you usually need to remove them, this allows the chain cover to come away, then wind back the tension adjusting screw ( with a flat blade screwdriver on a Husqvana other brands may be different ) back until the chain is loose enough to come off, the bar will also come off at this point.
It is a good opportunity to give everything a good clean at this stage and make sure the oil ways to the bar are clean and not blocked with wood dust, check the nose wheel on the bar spins freely and maybe grease it.
Put the new chain over the drive pulley the same way as the old chain came off, line it up in the bar slot and if you have the tension adjust wound back far enough for a new chain the bar will just flop over the two clamp bolts, replace the cover, and just do the nuts up finger tight so the tension adjust can be wound up to take the slack out of the chain.... not too tight ! it should still spin by hand without too much friction and you should be able to lift a link up half way out of the slot in the middle of the bar with your fingers.
Check the oil is getting to the chain by running at full speed with the end of the bar held just above a flat piece of clean wood, it should throw off a faint line of oil from the chain onto the wood.
Keep your chain sharp...
Happy sawing !
Nov 26, 2013 | Garden
GX 11FF 270 10 Bar single stage Atlas compressor keeps going out on high temp, have done a full service and is still a problem
clean cooler fins and make sure the cooling fan comes on and it must get fresh air to run properly if it is in a small room without proper ventilation it will just keep circulating hot air and lastly if all the above are are met it maybe a bad temp sensor and make sure the unit has enough oil and the oil filter is not plugged and the thermo valve (thermostat) is not sticking best way to check this it to take the temp of each oil carrying pipe going into the cooler and the one leaving the cooler and see if there is a difference in temp using a ir temp meter
Jul 06, 2011 | Taylor Air Tools & Compressors
Poulan Pro Chain Saw Bar Chain Oiler Stopped Flowing
The filter can usually be caught with a hooked wire and drawn up far enough to deal with the filter. Oil filters are not prone to plugging unless the oil used is contaminated. If you run the engine without the bar and chain attached, oil should ooze out of the engine side port. If nothing, suspect problems with the oil pump. Some saws use a plastic gear in the pump and can strip the teeth of the gear. You should find it located behind the clutch assembly. Once you have oil flowing from the engine, clean the bar drive-end oil ports that go from the large holes out to the chain groove on each side. Finally, run the bar tip near some cardboard--it should throw off a thin line of oil. I have no idea what the plastic tube might be (a manual pumper perhaps?). Hope this helps!
May 23, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
No chain oil coming through
Remove the side cover, bar and chain. Clean the side oil port and any passages connected. Use compressed air to blow out the oiling passages in the drive end of the bar including the small ports that connect the chain guide slot to the larger holes in the bar. Run the motor for a short time without the bar and chain, there should be oil that oozes out of the side port. If not, then the pump, the filter in the oil tank, and the intervening oil line needs to be checked. When everything is back together, the far end of the bar should throw off a fine line of oil on a piece of cardboard after running for a little while. Hope this helps!
Feb 20, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
2150 2.1 cu super clean The chain and bar oil will not come out?
There are several things you can do. First, are you running standard bar oil in very low temperatures? If so, switch to winter formula or motor oil. Next, take the bar off and see if the hole that feeds the oil to the bar is obstructed. Other possibilities are sawdust getting in the reservoir while filling it and blocking off the tube, or it not being adjusted to feed enough oil. There is usually a screw on the bottom of the saw near the bar to adjust how fast the oil flows to the bar. When it's got enough oil, you should be able to spray a mist of oil onto a piece of wood while revving the saw.
Dec 31, 2009 | Poulan Garden
Chain oil is not oiling chain. Could it be clogged? First time I used machine.
Is it new (return it!)? Did you put bar and chain oil in the reservoir?
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw’s oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Providing a make, model & serial numbers help us help you. Without these we can only provide a general answer. There are in excess of 5000 different chainsaws.
Nov 24, 2009 | Poulan Garden
Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18" Logo
89 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Mike Squire
Jay Finke
Jay Finke
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
