Question about GE Profile DPSR473EW Dryer
I have a GE DPSR473EWOWW Electric dryer that has great ventilation pressure and heat is at 135-140 on cotton regular heat settng. The timer portion (20, 30, 40, minutes setting) works fine, but if you put it on the more dry setting, it runs forever and does not shut off when dry. When a load goes in, it will take 2-3 80 minute cycles to dry. What can I do?
    Problem Solver:
  • 26 Answers
Hey richn14, I have a dryer idnetical to yours and bought it from one of my friends, and the guy that owned it before them was/ is a total idiot ( i know him, unfortunatly) and have had to do quite a bit of wrok to my dryer.What im thinking it is, is a loose connection on the timer, ive dealt with that or the timer itself is bad/going bad. When I was working on my dryer I was amazed at all the electrical connections on the timer, and the connections on the motor, well, blew my mind. If you are going to check this out yourself and need to know how to take any part of the dryer apart let me know and ill post it on here or can email you, either one.
Posted on Feb 01, 2011
Electric Dryer Shuts Off
During the auto-drying cycle, the moisture sensor could be the problem.
If it also shuts off prematurely during the timed cycle, the operating thermostat could be turning the heaters off before the machine reaches operating temperature. Another possibility is that the operating thermostat does not turn off the heaters at all. When the machine heats up, it gets too hot and the high limit thermostat turns the dryer off.
Apr 20, 2010 | GE DWSR483EB Electric Dryer
My mother-in-law is having a GE electric dryer
Hi, This has a 2 piece heating element. One possibility is the half for regular heat is broke and shorts out on the housing. This would cause the element portion that is shorting out to stay hot and not cycle with the thermostat. Does the dryer try and heat while the timer is off? Have her open the door with the dryer off and look through the back of the drum and see if there is any glow. Then set the timer without starting it and look inside to see if there is a glow. This happens at times when the element shorts out.
Without being there.. this is my theory. She might need a repairman because to get to the elements is a job.
I hope this helps. Please let me know if I can assist you further.
Vic
Jul 11, 2009 | Dryers
Tumbler spins, heat won't go on, timer won't work
It is your operating thermostat. It controls the heat and runs the timer down.
Jul 07, 2009 | GE DVL223GB Gas Dryer
My dryer works but no heat
If your dryer runs, but does not heat the following link will explain how to troubleshoot:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
The majority of dryer heat related problems are caused by poorly installed, improper, kinked, or clogged ventilation exhaust ducting. Pay particular attention to the section that discusses ventilation. Failure to ensure the dryer is properly ventilated will result in repeated failures of any components you may replace. In addtion, this can become a fire hazard.
If you have any questions, please let me know. I hope you find this information helpful.
Jul 07, 2009 | Whirlpool LER5636P Electric Dryer
Dryer will not heat up.
The following link can give you some more advise on troubleshooting a dryer no heat problem:
Begin by verifying your input voltage at the wall receptacle. You should read 220-240 VAC across the two hot leads (the left and right slots in the receptacle). If good, remove the back cover over the terminal block of the dryer (where the power cord is installed) and plug the dryer back in. Take a reading across the RED and BLACK wires at the terminal block. If good, your problem is in the heating circuitry. If bad, you have a bad power cord.
The reason I mention the input voltage is because many people assume it is good if the dryer drum is still spinning. The drive motor which turns the drum, however, only uses half the input voltage because it runs off 110-120 VAC. The heating circuits require the full 220 service in order to operate. If you are missing a portion of the source voltage, the dryer will exhibit the same problems you describe.
Read through the link I provided and pay particular attention to the section that discusses proper dryer ventilation. Most dryer heat related problems are actually caused by poor ventilation causing the dryer to overheat to the point of failure. If you haven't cleaned your ventilation ducting anytime recently, now might be a good time. Leaving a dryer in a clogged or poorly ventilated condition will cause repeated failures of any components you might be replacing.
If you have questions along the way, let me know. I hope you find this information helpful.
Jun 11, 2009 | Whirlpool LER5636P Electric Dryer
GE Profile dpsr473ewoww timer doesn't work and heat level is low
We should address the heat problem first. If your dryer complaint is "heat seems low" or taking "too long to heat", this is commonly confused for other problems. When in fact, you may really have a "ventillation problem". Do you feel (with hand) alot of hot air pressure coming out the back of the dryer or house vent-line (for dryer)?
I would disconnect and clean the dryer exhaust vent/duct (at wall and machine). Then, while leaving the vent-line disconnected temporaily, test and run your dryer. You may see an signficant improvement.
Does it heat up better?
Do you feel alot of hot air and pressure coming out the back of the dryer?
When connected; do you feel alot of hot air pressure coming out of your house dryer vent?
MaintenanceUniverse.com
Feb 01, 2009 | GE Profile DPSR473EW Dryer
Electric dryer intermittently doesn't heat
If your dryer has a timer with quick connects which easily plug into it then you can possibly fix this problem. Yank both connects off the timer and remove the timer. Take the 2 motor screws off and remove the plate carefully. Clean the contacts on each leaf switch with a file. Put it back and retry. Sounds difficult but it isn't. Remember only the timer with the 2 quick connects.
Dec 21, 2008 | Dryers
Timer only works on Timed Dry Setting
Check your heating element. If one coil of the heating element is burnt out the dryer will heat on the remaining coil, but the timer will not advance in automatic dry.
Nov 13, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
150 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
