Question about Numatic James JVH180 Wet/Dry Vacuum
I accidentally vaccuumed up some wet items with my James so the white cloth filter became wet and suction was lost. It was making a sort of vibrating noise as if there was something stuck in the tubes. I have bought a new white filter but still have no suction. Any ideas?
    Genius:
  • 1,672 Answers
Did you check the impeller fan that sucks air?
Sometimes the motor runs and the suction impiller don't move at all!
It doesn't go with the rotation of the motor itself!
or
Something stuck in the fan!
Posted on Nov 06, 2010
Vax mach air reach suction problems
Thanks to N3FAR. It was very helpful, i have been callinv Vax and they are asking me to do all sorts of other things. Thanks you again
Dec 31, 2012 | Vacuums
I have a Dyson dc21 ... it has low suction... never happened before approx 4 years old
try completely cleaning it out and clean the filter or get a new one. sometimes when my vaccuum has low suction theres dirt clogged in the hose or the vaccuum itself. try cleaning it out and if that doesnt work try and see if the settings are messed with (if there are different settings of course)
May 23, 2011 | Vacuums
My bissell lost its suction...
My Bissell upright Pet vaccuum lost suction but the brush is still working...help
Dec 29, 2010 | Bissell 1770 Quicksteamer II Upright...
My vaccuum cleaner is an EVERSTAR 1200. I turned it on - everything appears OK until I realize that it is not suctionning. I cleaned out the canister - made sure the vacuum was not obstructed. Still no...
First clean the filter on top of the canister, do not wet it, blow it and get all the accumulated dust out. Then check the hoses for obstruction. There should be an emergency valve on the rear part, if it is open, you better ck the hoses.
Aug 29, 2010 | Vacuums
My Rainbow has no suction
Your Rainbow E series has lost suction power, because you need a new hepa filter, or your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
If it is an earlier model, everything applies, except for the filter. They do not have filters, on any of the earlier models.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Jan 27, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Do I take the filter off when I am vacuuming up wet things?
If it's a paper filter, take it off. If it's a cloth filter that can be washed and dried, leave it on. Your machine will have a float to close off the suction when the tub needs emptying. Anyway, air from the tub only goes through the turbine, not through the motor itself, so you need not worry. It's good practice to run the vac dry for a few minutes after using it wet, just to make sure the turbine's dry.
Aug 15, 2009 | Craftsman 17026 Wet/Dry Vacuum
Dry/Wet vac is blowing instead of vaccuum
Check to see if the plastic ball is stuck . There should be a ball under the motor , make sure it moves freely. Make sure your vacum lines are not plugged . Best of luck Ed.
Jun 18, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Hose is not getting any suction
when vacuums shut off randomly it usually means they are overheating. this can be caused by a clog somewhere in the line of suction, or, perhaps due to a very dirty filter - either way, the motor is working hard and getting too hot.
try removing all the various tubes and parts along the suction route and checking for clogs (a flashlight might help too). also, have you rinsed out your two pre-filters lately as recommended in the Dyson manual? it might help.
Apr 26, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Wet dry vac suction not woking
The wet and dry vaccuums should normally have the dust filter removed when used for wet work. If the filter was left in, it will certainly be clogged and useless. I would suggest trying the unit with no filter, just to check there is good suction. If there is, a replacement filter is required. If there is still little or no suction, then it is possible that there is a blockage within the impeller area somewhere. Wet dust/dirt tends to stick really well to the impeller blades, reducing their efficiency to point of almost no suction. I'm not sure if you can get that far into your unit, if you can, it would be worth using a stiff brush to remove and adhered debris.
Dec 17, 2007 | Vacuums
Numatic James JVH180 Wet/Dry Vacuum Logo
130 people viewed this question
Top Numatic Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Numatic Vacuum Expert? Answer questions, earn points and help others
