Question about Whirlpool GS470LEM Gas Kitchen Range
Have a model SF195LEKT0 SN :RL4710391 range. The oven will not ingnite. clicks twice and then no ignition. I'm assuming it is the oven igniter gone bad. I tried to lite the broiler and still the same thing although we never used the broiler part. Is here a way to test Igniter itself? If the oven igniter goes bad will it also keep the broiler igniter from lighting? if so then it must be a bad Oven igniter if not there could it be a more serious problem like spark controller.
catriver
  • 878 Answers
SOURCE: Oven/Broiler Igniters for KitchenAid range KGST307
Guy, your missing some letters at the end of the model but I compared 4 different gas slide in's starting with KGST307 and the part numbers are bake ignitor 9751123 and broil 9751784. Catriver..post back
Posted on Apr 02, 2007
SOURCE: my GE XL44 gas range ;the broiler will light but my oven won't
it's time to replace the oven ignitor.
Posted on Dec 09, 2008
SOURCE: I don't seem to be getting gas to the oven and broiler.
top of stove work but the oven dont work the igniter come on and glows but no gas
Posted on Jan 26, 2009
jumptrout51
  • 3361 Answers
SOURCE: Have a GE gas range. Broiler doesn't work while
First clean the terminals at the control and check for tight wires at the incoming terminal block. Check the neutral wire for a good conection. If the ignitor reads less than 3 amps it does not have enough resistance to open the gas valve. Turn the gas off. Put a clamp on amp meter on the broil ignitor wire. Turn the broiler on. If less than 3 amps.replace the ignitor.
Posted on Sep 30, 2009
  • 160 Answers
SOURCE: oven won't
if you can hear gas when turned on then its likely to be a faulty/dirty burner. No gas flow then its the thermostat or dependant on model a faulty gas relay/valve
Posted on Dec 22, 2009
Brown gas range auto ignition not working
If the problem is with all the burners then the igniter module may be defective. If this is happening only with some burners then the cable to the ignition point has become loose or is shorting with the body.
I am assuming the model number is correct but I am not finding any details for this 24 inch freestanding gas range. If the oven is electric and if it is running that means at least the electric power is reaching the unit.
Brown Stove Works INC
The oven parts are available here
Brown Range Stove Oven Parts
Sep 03, 2014 | Brown Stove Works TM110-3 Gas Kitchen...
I have a GE range JGB290MEN2BS. I relaced the broiler igniter p.n. WB13K21 My question is: should the ingniter continue to glow after the flame ignites. i assumed it would go off when the flame came on...
No, the igniter continues to glow. Current has to flow through the igniter to allow the main valve to open and allow the gas to flow. So the igniter will be on all the time while the broiler is operating.
Dec 25, 2010 | Microwave Ovens
I have a kenmore gas oven/range model 362.752.6190. The oven will not ignite but the range burners work great. I assume that means its the ignition system on the oven. Do you know where I can get a new...
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Dec 01, 2010 | Kenmore Ovens
I have a GS773LXSQ O modle Gas range that is a little ove 4 years old. After baking a pumpkin pie on Thanksgiving, I wanted to broil the crust. The broiler would not come on and after turning off the oven...
If it is only 4 years old then yes it has electronic ignition and you should hear a clicking as the oven electronic igniter starts. If not the igniter module is most likely defective. Contact this website (at the link) for repair help and parts. Appliance Parts Accessories Repair Help
May 17, 2017 | Whirlpool Kitchen Ranges
I replaced the ingniter and the oven still doesn't work. The stove top does. The igniter doesn't glow or anything. The model number is JGBC15GER6WH. Its a GE XL 44 oven.
Better take a look at a service manual to see if their could be a fuse before ordering a control.
I have one HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 20, 2010 | Kitchen Ranges
Dynasty range - oven feature has stopped working
it's very possible that the mice may have gotten in but i would say it's the ingnition electrode.
i would have a technician come and take a look. check you local authorized repair shops. shouldn't cost you more than $150.00 to repair it.
Sep 13, 2008 | Dynasty DGRSC 48-6G Gas Kitchen Range
Oven stop working
In many cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. The igniter has probably gone bad. ($50.00 to $90.00 for igniter)
May 21, 2008 | Maytag Ovens
Oven won't lite but broiler/burners do
The oven will not light MANUALLY. It has an electronic igniter that (if it is bad) will not open the gas valve in order for gas to flow. This is a built in safety feature that prevents free flowing gas from accumulating your home without ignition. The igniter has to be replaced. The part costs about $50 - $60 and is fairly easy to replace. If you can provide me with your COMPLETE model number (located somewhere around the oven door opening or lower drawer opening), I can locate a part number for you. I can also give you guidance on how to replace it. It is not recommended that you try to defeat any safety features on your range, either. Post back with comments if you need further assistance. I hope this helps you.
Feb 09, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Gas oven igniters
  If it is also a round ignitor it's the same.
Oct 24, 2007 | GE Spectra JGBP30 Gas Kitchen Range
Oven Blows Igniters
sounds like you have a short somewhere. you may need an expert.
Feb 02, 2007 | Dynasty DGRSC 48-4GCB Gas Kitchen Range
Whirlpool GS470LEM Gas Kitchen Range Logo
60 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Archie Ferrarini
Archie Ferrarini
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
