Question about Mitsubishi WD-65735 Television
Picture got progressively darker. This morning came on, had sound but no picture. Now has no sould or picture and makes "static" noise shuts off after a few minutes.
  • 3 more comments
  • rickgamble2 Nov 06, 2010
    Hi Taran:
    I did as you suggested and tv responded as you said it would.
    Yes. TV responded as Taran said. Now I need to know what to do next.
    Actual sequence:
    1. TV shutdown and red lamp light came on.
    2. I pressed menu and input as you said. Green Timer light blinked 6 times each in a series 10 reps
    3. Red lamp light still on.
    1. Manufacture date is May 2008. We bought it in the box in October 2008.
    2. The lamp has never been replaced.
    Thanks for your help. I think this is beyond me. I'll call a professional.
    Rick
  • 10,515 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems, to activate this turn the unit on let it shutdown then press the input/or device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times.
Let me know,so that we could Proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 06, 2010
  • 3 more comments
  • taran_2005
    taran_2005 Nov 06, 2010
    Thanks for your response!!
    Let me know the sequence of blinks?
    Is it 1 2 or 2 2 or .....
    Thanks!!
  • taran_2005
    There could be few probabilities.So, let me ask few details :-
    1. How old is the unit?
    2. Have you ever replaced lamp?
    Proceed.
    Hope i helped you.
  • taran_2005
    These lamps tend to go after two years or so (when the warranty is
    over). However, there are some other things that can cause the lamp to
    go.
    Also, If the door(s) and screws that hold the lamp
    inside are not placed back correctly the TV will act the same way. I
    know you checked this already. However, even techs have made the
    mistake of pinching a wire or not replacing a door screw on these.
    If you would like to make this a DIY project. You will need the service manual to go further.Some common problems with this type of technology is the loss of the
    ballast (which supplies power to the lamp). There is also a cooling fan
    that can fail causing the components to overheat, blow the lamp and/or
    ballast. Then there are other components related to the power supply
    area, that will cause too much voltage to occur and then....Lamp or Ballast......
    You will need a multi-meter, some electronic experience and some time to
    sort through troubleshooting the TV. We have had some tech savvy
    consumers diagnose and repair these TVs, so it can be done.
    Let me know,if needed further assistance.
    Hope i helped you.
  • taran_2005
    You are welcome and take care.
    Thanks and Regards
    taran_2005
  • David Garcia
    David Garcia Oct 17, 2013
    My Tv has no picture and only a static sound. I pushed the input and menu buttons and held for 5 sec. and the power led blinked 3 times then a pause then 2 times. what does this mean?
Our LG tv has started making a vibrating whistling sound when you first cut it on, you can hear it get faster and faster then slowly goes away.. Also over the past few months I've notices the picture
the picture getting darker means the lamp has aged and u need to replace it another thing u need ti replace the mirrors in the light tunnel of the light engine they have faded secondly the noise means the colour wheel has aged you need to replace it u will have to replace the whole light engine cos the color wheel comes inbuilt the light engine and u will be ok ontact lg dealer in your area
Jul 19, 2013 | Televison & Video
Black screen
Check its back-light inverter and back-light CCFL lamps.
Jul 12, 2013 | Sceptre X32BV-Naga 32 in. LCD TV
Tv picking up channels except its all static, colorless, and loud static noise..
If the set was purchased in the USA it has the USA format which is NTSC--unless the signal is NTSC picture will be in black and white and no sound.
If the signal format there is PAL OR SECAM you will need a converter that takes that and outputs NTSC for the set to work properly there.
May 16, 2012 | Panasonic Viera TX-32LX70 32 in. LCD TV
Pandigital pan 70-0 progressively got darker. now you can bearly see picture
Hello. your frame has a dial on the side which makes it brighter or darker. Just turn the dial to adjust it. Regards, Joe
Feb 17, 2010 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Picture has become progressively dark 27'' TV JVC AV-27320
disgaussing will not help this problem..i am scared your picture tube problem or try to change the crt socket first it is not cost much
Jul 01, 2009 | Televison & Video
N o picture just static noise
The symptom sounds like a dead tuner and the screen blanking may be due to missing video synchronization signals which may cause either blanking or 'blue screen' on some sets.
This could also still be because of a failing power supply although they will generally just cause no turn-on at all.
I would first substitute another TV just to be sure your signal source (cable or satellite) isn't causign the loss of signal.
May 25, 2009 | RCA R52WM24 52" HDTV Projection Television
Sound but no picture
hi
i think its a colour wheel problem...if there is led blink tell me how many times it will blink i will sort if there is error code and i will tell the solution
Feb 14, 2009 | Sony Televison & Video
Screen is messed up, getting worse
What your describing sounds like two differant problems OR the power supply is causing these two problems .. One would of course be the tuner and the other would be the vertical circuit .. Your going to need to seek out a profesional if you havent a clue about solid state electronicsand A tv is not a place to experiment! Good Luck
Jul 27, 2006 | Panasonic CT-36SX31 36" TV
Mitsubishi WD-65735 Television Logo
441 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
