Question about RCA Audio Players & Recorders
RCA audio system,and three disc. autio radio works , but the three dicc player will not play any audio discs. I think the tuner is out of programing. Haveany suggestions. it is a am fm radio and compact disc player&duel cassette recorder. thanks in advance. f.bugyi@att.net Model#rp-9328a--sept.1998
  • 2,071 Answers
I always encountered that kind of problem,the audio works but discs player not working.This kind of a problem of a disc player had three causes,first the lense is busted already secondly the MPEG MEMORY IC is busted,thirdly the roller that's moving back and port bringing the lense set stock up full of dirt this is most common problem.That why whateveryou did is not functioning.If you know how to open your unit it's better. First you do is to clean the roller with the use of a lighter fluid to take the old greases that already harden with dirt. After that all is clean put a first class greases type-A only little to the roller and wipe the lense with a cotton buds. If all this procedure nothings happens,you better change the lense with desame code number, to avoid conflict.If the lense is change still not functioning that's the time you change the MPEG memory IC.I assure it to you it's works 100%.
Posted on Jun 15, 2008
Dvd allows dicc in but fails to read,monitor stetes no disc,
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Take care.
Jan 26, 2011 | Televison & Video
Rca rtd155 dvd player continues to read no disc with a disc in it.
Try to play a CD audio. If it plays OK then the video laser is bad in the player. If it doesn't play, open the player and inspect the lens for dust and clean carefully with a "Q" tip with alcohol. If these remedies don't work, then replace the drive.
Nov 01, 2010 | RCA RTD155 System
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
May 01, 2009 | RCA Audio Players & Recorders
CDs won't play RCA RS2651
I think the laser is mis-aligned or the laser unit needs replacing. If you are able to check this for yourself otherwise find a competant technician. Hope this helps.
Oct 06, 2008 | Audio Players & Recorders
Disc player does not work
Try using a cleaning disc, run it for about 20 to 30 seconds. If that does not help you do not really have any other options, RCA does not sell parts for the audio equipment anymore. They stopped about a year ago or more. I work at a authorized RCA service center and we can not repair any of the RCA audio equipment because of this.
The problem with your CD player is most likely the laser pick up, when it goes bad it can not read the disc's so it thinks there is no disc in it. The laser pick up is the most common reason for your type of problem.
If it is under the RCA warranty still you can send it to them and get a free replacement, if not under warranty you may as well trash it and buy a new one from a different manufacturer. The RCA audio equipment is not very good quality. That is the reason they no longer offer parts for them, it is cheaper for them to give you a new one than to pay a service center to fix it.
Jul 12, 2008 | RCA RS2650 Shelf System
CD Player will not play all CD-R discs only ones it chooses. But if the CD is bought from a store it will play it.....if it is burned it usually will not.....even if the cd was just brned and plays on...
It might be an older system that can't read computer-made discs, or it could be a disc incapability. Most old players can't read CD-R discs, even if they can play normal/original CDs. You can try another media but i wont think it will help. Sorry.
Jan 04, 2006 | RCA RS2044 Shelf System
Won't play CDs
It might be an older CD player that can't read computer-made discs, or it could be a disc incapability... If you sure that the system supports the disc's format.. And it won't play other discs... try to clean the CD lens. Sorry i cant help you more.
Dec 30, 2005 | RCA RS2650 Shelf System
146 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
