Question about Logitech Cordless Optical Mouse
I bought this moused form Buy.com and it did not come with an installlation disk and the pointer will not operate. Is this a repairable issue?
Cursor not showing up
Well the touchpad driver could be erased or a virus may have damaged it.
You should go to Acers website and then support and download drivers and get the right touchpad driver.
Install it and see if it works.
Use TAB to navigate for now. or use mouse keys.
This means keep pressing shift really fast and accessibility option will show up.
Use tab and space bar to navigate to MOUSE TAB and select Mouse Keys and hit enter.
Done for now you can use the numpad to operate the cursor.
Second option is to go out and buy a USB mouse.
Worst case scenario: Touchpad is damaged and needs replacing.
Or simply a cable got disconnected and needs reconnecting by taking the laptop apart
Get Your Laptop Mouse to Show Up if It Disappears
Using a laptop is as efficient as a desktop computer to complete tasks, use the Internet and talk with friends on a daily basis.
If your laptop's mouse cursor disappears, there are various tricks and solutions available to help get your mouse pointer back to resume your work and current computer tasks within minutes.
And this can be accomplished without the use of software applications or advanced computer skills.
Press "Ctrl" + "Alt" + "Delete" and choose "Task Manager" if your mouse pointer becomes available, pressing the keys simultaneously.
This will allow you to close any open programs that may be causing issues with your mouse pointer.
Plug in an external mouse to allow the computer to attempt to find the device, prompting the mouse pointer to appear which may solve the problem or allow you to temporarily work with a mouse pointer.
Reboot your computer by pressing and holding the laptop's power button for a few seconds.
This will reset your laptop's current open settings and most often allow your computer's mouse pointer to reappear.
Upgrade your laptop's video and graphic card drivers (if available) to ensure the mouse pointer disappearing or flickering is not a hardware issue.
Select "Start" > "Control Panel" > "Hardware and Sound" > "Device Manager" to view your current graphic and video settings.
Visit your device manufacturer's official website to download the most current version of your drivers.
http://support.microsoft.com/kb/198614
Aug 05, 2013 | Acer Computers & Internet
My Microsoft arc mouse keeps freezing for no reason! Any idea on how to stop this?
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
make sure that the right type of mouse is selected it will be in the hardware tab or
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
hope this helps
click start control panel,mouse you can speed up the mouse
also under pointer options you can speed up the mouse you must click apply after you have made any adjustments
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Dec 28, 2010 | Microsoft ARC Mouse
How do I re install the pointer that I just accidently uninstalled
i am sure you got the disk for the drivers. Installl it from there or else go to support.acer.com
thanks
Nov 18, 2010 | Acer Aspire One PC Notebook
I just bought an hp nk527aa and I have no control of the mouse. It moves everywhere I don't want it too.
Try goin g into Control Panel, Mouse Properties, Pointer Options; slow down pointer movement to a slower rate. If this mouse came with an Install disk, there ought to be settings in it to do the same thing.
Nov 09, 2009 | Computers & Internet
Windows vista is froze at login mouse pionter stuck in middle of screen and key board doesnt work the cursor is blinking in the " enter password " spot tryed restore, repair and booting form disk
Hi..
Press fn+f9,it is the hot key for enabling or disabling the touchpad . it should enable the mouse.
all the best.
thanks for contacting fixya.com
Sep 22, 2009 | Computers & Internet
Need driver for Sakar (77253) Mouse
Go to this website: http://www.sakar.com/contactus.aspx
Fill out the form and request the drivers for your product. I was unable to locate them from my drivers source.
--Hope this helps!
May 01, 2009 | Sakar (77253) Mouse
Black screen with mouse pointer after lcd screen repair
If you can see a mouse pointer clearly, you have a software issue especally if see a post..
Apr 20, 2009 | Dell Inspiron 1525 Notebook
Logitech Cordless Optical Mouse Logo
50 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
