I do not have the software to install after upgrading to windows 7 of the globe
  • 4,924 Answers
All the drivers for windows 7 will be on the support sites for each device (external ) and for your drivers you have to go on the manufacturer support site and download them ..
About other programs they are almost all available on the net if you search for free downloads..
for example almost any player that works on Vista will go for 7 ..
and its about the same with all software you might need..just search on Google for it by name and see downloads for windows 7
Posted on Nov 06, 2010
Is it possible to upgrade windows XP to windows 7
If you are asking could you upgrade directly from Windowx XP to Windows 7 as a direct upgrade, the answer is yes but it's not recommended.
The much better method is to use Windows Easy Transfer to move your important files from your computer onto an external hard drive. After all your files are backed up safely, it's best to start the Windows 7 install and when you get to the "Upgrade" or "Custom (advanced)" screen to choose Custom. This will open up the drive view. Click on "Drive options (advanced)" which will bring up the ability to delete the partitions.
If you find that you have more than one shaded area in the Drive 0 bar, you have more than one partition. Unless you have experience creating and modifying partitions, only delete the partitions on Disc 0 which are marked Drive (C:). Otherwise, you can decide what partitions you need to delete to make enough room for Windows 7.
I'm not sure if you've already done your homework or not but before you upgrade to Windows 7, run the update advisor to ensure your system and software is Windows 7 ready and make sure to collect the hardware drivers that work with the exact version of Windows 7 you are installing... 32 bit and 64 bit are totally different monsters!!!
Having all of your software install disks on hand, and all your backups (and a bootable copy of the backup software!!) and Windows 7 hardware drivers on an external hard drive is the best way to approach an upgrade.
Best of luck!! Hope this helps.
Mar 22, 2014 | Acer Aspire Computers & Internet
Tip
Upgrade Windows XP to Windows 7 - it can be done!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
on Nov 09, 2013 | Microsoft Windows 7 Professional for PC
Tip
Upgrade Windows XP to Windows 7 - it is possible!
The Prep:
The Process:
Test everything:
on Nov 09, 2013 | Microsoft Windows XP Professional
Upgraded from XP to 7 - paper size and type not showing in select paper window
After upgrading from Windows XP to Windows 7 you probably need to go to the Epson website look up the model printer and download the specific software and drivers for Windows 7 this should correct your problem install that new software
Feb 11, 2018 | Epson Stylus Photo R800 InkJet Printer
Can I install a 32-bit software Windows 7 Starter on a Dell Latitude X200 computer? Please clarify. Can I still upgrade my X200 to accomodate latest softwares.What is the optimum upgrade I can do on my...
After lookng at the base specifacation of this laptop, even if it was upgraded the laptop would not support windows 7. Windows XP would be the latest OS you could install.
Please take the time to review and rate our solution.
Rytech Computer Services Limited
Oct 12, 2010 | Dell Latitude X200 Notebook
After upgrading my pc to Windows 7,my webcam is not working
Windows 7 requires you to re-install all software once you upgrade to it. Windows 7 performs a clean install and all formaer programs are eliminated if they were aftermarket and some that were pre-installed.
Mar 27, 2010 | Toshiba Satellite L305D-S5881 Notebook
Can I install my software in windows 7
before you can install the windows 7 operating system, download first the windows advisor software that allows you the check your computer if the components of your system is capable for having a windows 7 operating system, it also checks your computer if you have incompatible programs and applications if your thinking of an upgrade from windows vista to windows 7.
if your planning to do an upgrade check the version of your vista OS to see the compatible version of windows 7.
i hope this helps
Feb 25, 2010 | Broderbund PrintMaster Platinum 16
Since upgrading to Vista and now windows 7 I cant
Start the "Program Compatibility Wizard".
Tell Vista that you want to install an 'XP' application.
Point the Wizard to the CD-ROM containing the software, and it will install.
Jan 15, 2010 | Adobe Photoshop Elements 2.0
My pc seems to have vireses. it has window xp and can it also be updated with windos 7
Microsoft does not recomend yo to upgrade fron windows XP to Windows 7. Fresh installation of Windows 7 on an XP machine is recommended.
Backup your User file, do a windows 7 readiness, and insert the windows 7 DVD into you systems fro a fresh installation.
However, there are third party application like PCMover software that could help you to upgrade from Windows 7
Jan 11, 2010 | Averatec 3200 Notebook
I would like to scratch-install the new WINDOWS 7 on the TOSHIBA P105-S6114. Is this okay? Are there any problems I may encounter?
ecommended Windows 7 Installation Method SelectionToshiba provides support for installing Windows 7 on laptops built since 2007. Depending on your model, Toshiba recommends using one of the following software tools as part of the Windows 7 installation process, to support ongoing use of Toshiba provided features and functionality:
  • Toshiba Upgrade Assistant for Windows 7, for upgrading from Windows Vista to Windows 7 on laptops made in 2009
  • Toshiba Software Installer for Windows 7, for performing a Custom Installation of Windows 7 ("clean install") on laptops made 2007-2009
Find your laptop's serial number on a sticker on the bottom of the laptop, note the second character in that serial number, then click on the matching link in the list below for instructions on Toshiba's recommended Windows 7 installation method for your model.
For all laptops made since January 1, 2007*
When upgrading from Windows Vista (not a Custom or "clean" Install)
  • if the second character of your laptop's serial number is 7 or 8, click here.
  • if the second character of your laptop's serial number is 9, click here.
When upgrading from Windows XP, or doing a Custom Install ("clean install") from any operating system
  • if the second character of your laptop's serial number is 7, 8, or 9, click here.
  • if the second character of your laptop's serial number is not 7, 8, or 9 then it was manufactured prior to 2007.*
* Installation of Windows 7 is not supported by Toshiba for laptops made prior to 2007.
Hope it helped.
Nov 21, 2009 | Toshiba Satellite p105-S6114 Notebook
Computers & Internet Logo
51 people viewed this question
Alun Cox
David Payne
David Payne
