Question about Microsoft Xbox 360 Console
No picture on tv for xbox - Microsoft Xbox 360 Console
  • 767 Answers
The video feed pin under the G.P.U. has disconnected.
The best ( most durable repair) is to have a shop
Reflow ( resolder ) the G.P.U. and then properly clamp
it back to main P.C. board . A hardware up grade ( Google " C.C.A. conformal compression assmbley") is also
desirable to make the console durable .
If you have any questions feel free to ask
Rob
Posted on Nov 06, 2010
Xbox elite connected to TV thru HDMI works fine, but connected via bcs-fs500 receiver = no audio or video Cable tv through receiver works fine Have tried cable tv through receiver inputs HDMI 1 and 2...
Hook your Xbox to tv via HDMI, then hook TV to reciever through digital optical or composite cables. If you try to get your picture through receiver first, you may get picture and sound but, sound may be delayed and picture might not be the best. Bettter to run through tv first then provide sound to receiver.
Mar 31, 2011 | Pioneer Audio Players & Recorders
Trying to plug in my xbox and can get sound but no picture
Is this the first time you've tried plugging in your Xbox?
Is it Xbox or Xbox 360?
Try plugging it into another TV yet?
I've had a similar problem where I've manually set the resolution of my television on my Xbox. I had it set up for 1080p and then plugged it into my little CRT. The picture was all scrambled and I couldn't do anything. I had to plug it into another TV to fix it. This is the original Xbox by the way.
Check the settings on the Xbox, and if that doesn't work, try swapping out the cables or put it on another TV.
Feb 05, 2010 | Hitachi 57F500 57" Rear Projection...
My xbox has sound but no picture. The TV says NO
try reconnecting the cable to Xbox then TV.
if it still doesent work the xbox output may be corrupt in that case send to microsoft
Jan 22, 2010 | Microsoft Xbox Console
38 '' RCA TV XBOX Model 36V550T, lost the picture
Does it only happen when you use your Xbox?
Try pulling the cable in and out between the TV and Xbox
Dec 05, 2009 | RCA 36V430T 36" TV
We turn the tv and xbox on but there is no picture. We can hear the xbox power up and the tv works otherwise, but no visual for games.
is there sound? check the connections in the back of the tv. if you get red lights on the xbox, then it means a cable is loose some where. check the av swith on the av cord connected to the 360.
Sep 29, 2009 | Microsoft Xbox 360 Console
Have got no picture on my tv xbox 360 is loading
you probably have a broken video or hdmi cable. somtimes the cables can even break at the connections or under the plastic coating, making the video going from your xbox to your tv not work.
Sep 14, 2009 | Microsoft Xbox 360 Console
We have sound but no picture on the xbox 360
The first thing to try is to remove the external hard-drive from your Xbox and see if the picture comes back. If that doesn't work you may have the video resolution of the Xbox set too high for your TV to display. Try reducing the Xbox resolution and see if you can get a picture. There is a switch at the end of the cable where it plugs into the Xbox that says TV and HDTV. Try setting it to TV. If you know someone with another Xbox 360 that you can borrow you can use it to debug your problem. If their Xbox works on your TV try swapping out the cables. You can see if your Xbox works with their cables and if their Xbox works with your cables. You should be able to narrow your problem down to either the Xbox, the cables, or the TV setup.
Jun 06, 2009 | Microsoft Xbox 360 Console
The xbox is on and there is no picture!?!
Make sure the cables are plugged in fully in the back of the tv, the back of the xbox, and make sure the tv is on the correct video input
Mar 18, 2009 | Microsoft Xbox 360 Console
Xbox Picture is Fuzzy, and sound makes picture worse
Your TV. Try it on a friends' TV using the proper cables and whatnot and see if that is the prob. I reckon it would be. Oldarse TV's may not handle the newer signal well..
Craig
http://compusure.org
Aug 20, 2008 | Microsoft Xbox Console
No picture
My xbox 360 elite video port went out on my previous xbox, and on the one i just got. it could be your video port on your xbox or it could be the your tv. Hdmi cords usually dont go out so i dont think it could be that. A way to check if its you xbox would be to try the regular cords that you get with your xbox on the same tv and see if it works. If it doesnt, try the same thing on a different tv. if it doesnt work on that tv either then its your xbox. if it does work, then it must be the other tv.
May 05, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
