I've deleted all of my sent, inbox, and draft messages and my phone keeps saying "memory full." It wont let me send or receive text messages at all. I've tried removing the battery and putting it back in, but that still doesn't help and I keep getting the same message. Please let me know of any solutions!!! Thanks!
Go to settings, applications, manage applications, click on an app in the list, click on Force Stop, click on Clear Data, you will receive a warning, proceed anyway. Repeat these steps for each app, then reboot the phone. Worked for me.
Have u tried deleting other media like pics, videos, sounds............that can also occupy space.Maybe ur phone is so full of that media tht it does not have enough space left........how much of memory space does ur phone have?.............and have u inserted any memory card into it?
Does it show signal bars on the screen and are you able to make/receive
calls? If not then that is why. AT&T does not guarantee in building
service. If you do have signal and it is working other than text, then
check your message center number in the device:
From the standby screen, press Menu.
Press Messaging.
Scroll to and select Settings.
Scroll to and select Text Message.
Enter appropriate Message Center Number, then press Done. The message
center number that should be there is +13123149810 (and the + sign does
need to be in front of it)
SOURCE: Message memory gets full though the capacity is 500.
yes... i am also getting same problem.
total SMS memory is 500 ie 200 for inbox , 200 for sentbox, 50 outbox and 50 for drafts. your my folder SMS's are still considering in inbox. that should not be more than 200.
thanks
kuldeep chanchal
SOURCE: nokia n95 saves messages in inbox, drafts and sent etc..
This is very easy to deal with.
Firstly Backup your phone contents.
goto menu -> settings -> general -> restore factory settings.
use code 12345
Fixed.
if that fails then turn your phone off and press and hold
*, 3 and the Green call button while you power up your phone.
this is a hard reset and will format the contents of your phone memory, if problems persist after this then format you memory card too. and hard reset again.
SOURCE: How do I delete text messages from Inbox on Motorola V220?
first press menu, select messages, then press menu button again, scroll down to cleanup messages, select, then scroll down to which box you want to delete and select. done!
SOURCE: sms memory full del some sms
Am not able to open message box from my samsung star phone as it says initialising..please help :)
my phone keeps saying memory low but i only have two messages in it help
No my media was not full I still had like 16 MB of memory available and only using 2 MB. I brought it to verizon and they fixed it for me by changing like 1 or 2 settings, but I'm not sure wich ones.Thanks for attempting to help though! :)
Recently i have only been able to have about 20 messages in my inbox before its saying its full, before this i could have over 400 messages before it got full, i went into the carphone warehouse where i bought the phone and they said i would need to put a memory card in the phone which i did and the problem is still there???
i have a v3 razr and i have maybe 8 messages in my inbox and outbox and like i deleted some pictures and ringtones and it still says memory is low! and sometimes doesnt let me read any til i delete them and then they all delete and i dont get them
my phone keeps sayingj the memory is full and i only have like 10 texts in my inbox. i don't know how to fix it. and it just started doing it out of the blue. i have a motorola rokr.
When i get a text message my phone doesn't let me even open it, it says "incoming message rejected due to full memory, please erase oldest messages." and i erased all my messages (inbox, sent, drafts) and i erased most of my pictures, and all my sounds and i'm still having the same problem. then when i try to send a message it says "memory full" i don't know what to do. can someone help me?
Phone showing memory full will not receive text messages
I have the EXACT problem.....I have deleted EVERYTHING on my phone...contacts.sounds.pictures.videos.messages. I have the Motokrazr K1 and its being so retarded. I cant get any messages or send any PLEASE HELP ME
It says memory full even though all memory is deleted!
Whenever I try to send a text, it says that my memory is full and to delete my messages. But my inbox and outbox are both empty. I even brought it back to where I bought it; he wiped the phone clean and it STILL says it. I just do not understand why it is doing this. If anyone can help, that would be great...
keeps saying memory full even though all my messages are deleted
my 128 mb mmc is locked, thats why i bought 1 gb mmc to my phone and when i inserted in and reciving a message it says memory full please some of the data in the phone, there is no data in my phone to delete
Go to settings, applications, manage applications, click on an app, click on Force Stop, then click on Clear Data. You will receive a warning, proceed anyway. Repeat this for all the apps. Reboot the phone. Worked for me.
