Question about Exercise & Fitness
I calibrated my Keys Encore 1500 treadmill IAW the Owner's Manual, but it didn't work as instructed: There were no number 10 0r 16 appeared in the speed window! The calibration failed, no result. Your attention to my problem is very much appreciated khiet P.S. The control panel has been changed once with a newer panel than the original.
  • 6 Answers
SOURCE: calibration fail message on bowflex treadclimber.....help
Unplug your machine, restart it and try to calibrate it one more time. I had to do this with mine and it did take more than one try to get it to recalibrate again.
Posted on Jul 29, 2009
mendi593
  • 65 Answers
SOURCE: Treadmill is not calibrated with the set speed have to set speed higher that monitor
If this does not help call Treadmill Doctor at 800-750-4766 ext 237
http://www.treadmilldoctor.com/Testing-for-Speed-Problems?utm_source=fixya&utm_medium=cpc&utm_campaign=mendi
Posted on Jul 06, 2012
ercupa190
  • 12223 Answers
SOURCE: how do you calibrate a york treadmill?
yes you must read the instruction manual for software calibration.
or open the hood motor, and read the instruction attached.
or you must call to York supply for customer service and ask them where is located in case that you will not find them.
God bless you
Posted on Jul 13, 2012
mendi593
  • 65 Answers
SOURCE: replaced speed sensor and calibration still fails, says there is no speed senosor
Call Treadmill Doctor at 800-750-4766 and they will walk you thru the install.
http://www.treadmilldoctor.com/?utm_source=fixya&utm_medium=CPC&utm_campaign=Mendi
Posted on Jul 17, 2012
ercupa190
  • 12223 Answers
SOURCE: Nordic Track C1900 when pushing 1mph goes 5mph, calibration POT not lowering
adjust the speed sensor a) test it b) clean it c) tight the plug or connector very well, see the diagram attached.
2) lube the elevation motor , shaft, and gear. and test it for open or defective motor see the diagram attached.
Again RUN the s. calibration for easy diagnose, troubleshooting, and fix it.
God bless you
Posted on Nov 28, 2012
What do Ineed to buy to make my treadmill advance evenly and not slow down and speed up?
you must RUN the software calibration go under the HOOD motor and follow the instruction. or read your owner manual for instruction and fix it.You will get easy diagnostic and fix it.
God bless you
Nov 21, 2013 | Life Fitness 9500HR Next Generation...
I bought a elite saracen treadmill n it says error code 4 what does that mean please n e wun help me pliz
reset the treadmills, follow this steps and fix it. GOD BLESS YOU
However you must RUN the software calibration for fix it. see your owner manual. or download free from www. fitness.manualsonline.com
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
GOD BLESS YOU
Nov 08, 2013 | Exercise & Fitness
My Reebok Z8 Treadmill says 'E-02' on the display screen. It is constantly beeping and fails to work, How can I fix this?
Run the software calibration for easy diagnostic, and fix it. The speed sensor, can be dirty or faulty, test with s.calibration. see the diagram attached.Read you owner manual or go HOOD cover motor and follow the instruction.
Oct 23, 2013 | Exercise & Fitness
When i turn on my reebok treadmill T3.2 the digital display shows confused all are flashing and i can't program it and sometimes it runs and then suddenly it speed down to zero and stop....how can i solve...
Run the software calibration, go to under the HOOD cover Motor,follow the instruction or read the owner manual and follow the steps. or download the manual from. www.fitness.manualsonline.com
God bless you
Jul 31, 2013 | Exercise & Fitness
My treadmill is stuck in incline
please RUN the software calibration for easy diagnose, troubleshooting, and fix it.
see the diagram attached, for troubleshooting too.see the b.diagram
Happy New Year.God bless you
Dec 31, 2012 | Treadmill Doctor Encore 1500 Treadmill...
Speed is off on nautilus exp 1000x treadmill
Please use your calibration software for recalibration your fitness according with your owner manual. See the instruction too below the hood. and proceed for fix it.
Sincerely. Merry Christmas.
ernesto cuadra
managua, nicaragua. c.a
Dec 10, 2011 | Exercise & Fitness
Why does my preco treadmill keep saying calibrating lift?
1) Under cover the main motor or in your instruction manual, there are section for calibration.
2) I recommend that you do it, in accordance with the instructions.
3) If you do not have owner manual go to website: www. precor.com
go to customer service, then parts& manual give your model, etc and download for free. you can go too for free www. iconservice.com with the same procedure.
sincerely.
Good luck, G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA.
Dec 04, 2011 | Precor C954i Commercial Treadmill
Proform Crosstrainer 5.0 Treadmill
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
Jul 15, 2010 | Proform Exercise & Fitness
Treadmill track will not run. It appears that the
under the hood after removing the 3 mtr hood screws in the frt. and the first screw on each side of the foot rails, there is a tech sheet/wire diagram. READ the sheet before making any moves to the controller- have item plugged in, 1 red led light should be lit,if not check on/off switch, if you have read the calibration section on tech sheet and proformed that task- control can be purchased and installed-then you can calibrate per its instructions. Best find a treadmill repairer,remember theres 120 volts there!!!
Jan 07, 2010 | Cadence Exercise & Fitness
Calibration
My name is Mike; I am a service technician for ICON Health & Fitness, the manufacture of the machine mentioned. While my comments on your problem are geared generally to assist, you are welcome to call our customer service line at 18009993756 for specific instructions if needed.
The first thing to do with any incline problems with a treadmill is run “calibration.” Calibration restores all settings (including the incline sensor in this case) to the factory specs. Instructions to run calibration on your individual machine are taped on the underside of the motor hood. See your manual for removal of the hood. While each machine has specific calibration instructions most new models made by ICON will have similar steps to doing it.
To calibrate the incline you will need to press and hold the Stop and Speed + buttons while inserting the safety key or magnet. Then let go of the buttons. This will enter calibration level 1 which lists some machine information and a console memory test. Press the Stop button 1 time. This will enter level 2 of calibration. To calibrate the incline you can press either incline buttons (either the up or down arrows) and your incline should go all the way up and then all the way down. If this works then take the safety key or magnet out; turn the power off, and unplug it for several minutes. (On a side not you will want to turn the power off and unplug your machine whenever you’re not using it.)
If this does not fix the problem then it can be more complicated depending on the model and motor involved. It can range from the console not sending a signal to a loose wire or jammed motor. If this didn’t fix the problem then I would recommend calling in for further assistance.
Sincerely,
Mike
Customer Care
Mar 24, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
136 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
