Question about Belkin (F5D7230-4) Router (587009)
Can not access ip address
I can connect directly from bell south modem to laptop. However, I can not do so with belkin f5d7230-4 router. The problem started when I downloaded upgrade software for my belkin extended and belkin router. At one point, I was able to see the access point settings but not the router settings. Now ican not see anything and can not use my router.
Perhaps I inadvertently changed the IP address since ping does not give me any positive results
Please help
  • Anonymous Jun 24, 2008
    About a week ago I lost connection to the Belkin and the message I keep getting is no ip address can be found. I tried to reset the ip address but this didn't work either.
  • Anonymous Jun 25, 2008
    secure access
  • 106 Answers
Did you try to unplug the power for 30 seconds and plugging it back? you can also bring the router back to factory settings... usually that's accomplished by having the power cord removed, holding the reset button in WHILE plugging the power cord back into the router. Keep the reset button pushed in for atleast 30 seconds! Now you should be able to access the admin page. Keep in mind, any time you move an ethernet (network) cable from the cable modem to the device (pc/laptop/router), you have to unplug the power and plug back again 30 seconds later.
Posted on Jun 15, 2008
Tip
How to Configure Belkin routers for Centurylink, Embarq, Bell sympatico, Bell...
How to Configure Belkin routers without installation CD for Centurylink, Embarq, Bell sympatico, Bell Canada ISPs ?
Configuring Belkin routers without installation CD for Centurylink, Embarq, Bell sympatico, Bell Canada ISPs :
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using an Ethernet cable.
  • Do not connect the modem to the router.
  • Open internet explorer / Firefox / chrome or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router i.e., 192.168.2.1
  • Belkin router setup page (RSP) will be displayed.
Wired Part Configuration:
We need to configure the wired part by following these steps.
Step 1: You need to LOGIN to the router for making any changes. (No login password, just leave it blank and click SUBMIT)
Step 2: Click on LAN settings (found on left side of RSP), change the IP address from 192.168.2.1 to 192.168.40.1 and save changes.
Step 3: Now Connect the DSL Modem to Router in the port named Modem (usually yellow in color) using another Ethernet cable.
***Once you are done that, you need to re-login to RSP by typing the new IP address 192.168.40.1 in the address bar of web browser.
Step 4: Check for the internet status at the top right hand corner of RSP. If it is connected then the wired part is working perfect with the router (wired computers will go online). Need not follow the steps below, directly jump to wireless part configuration.
Step 5: If the Internet Status is not connected then, click on CONNECTION TYPE (found on left side of RSP), it has to be selected as DYNAMIC and click next. It will ask for HOST NAME, leave it blank or you can type anything there and click on APPLY CHANGES.
Step 6: Now check for the internet status at the top right hand corner of belkin RSP. If it says connected then everything for the wired part is configured perfectly. You can go ahead and configure for the wireless part.
If it is not connected then we need to do a network power cycle.
Steps to be followed for performing Network power cycle:
  • Unplug the power cable of both your modem and router.
  • Wait for 30 seconds.
  • Plug back the power cable of the modem and wait until all the lights are lit up in it.
  • Now plug back the power cable to the router and check for the lights in the router.
Modem & Internet lights will be lit and they will be solid (blue/green) in the router; it says that the Internet status is connected. Now you will be able to go online in the wired computers.
If still Modem & Internet lights are not solid in the router; it may be blinking in red/ amber it says that the Internet status is not connected. You will not be able to go online in the wired computers.
In this case you need to connect your computer directly to the modem and check whether you are able to go online. If you are not able to go online, then you need to contact your ISP and fix your issue with internet.
The above method is applicable only for Embarq, century link, Bell Sympatico, Bell Canada ISPs. Because these ISPs will have the IP address same as Belkin routers....
If nothing works then you need to contact your ISP and ask them to bridge the modem...Bridging the modem disables NAT in the modem and allows you to get a public IP in the modem.
click here to configure wireless part...
on May 09, 2010 | Computers & Internet
My belkin N1 router when i plug it in it just flashes the security light and wont connect to the internet
You will need to double-check your security settings. Apparently, the modem is trying to tell you there's a problem regarding this.
The easiest way to be able to access the router settings in this case, will be to provide a direct connection between your PC and the Belkin router (using a network cable) and then type in that address.
If the address still doesn't work, double check the router's IP address by opening the Command Prompt (it's under Programs -> Accessories) and typing in "ipconfig", then hitting Enter. The IP-address you're looking for is listed under "default gateway".
(Also, make sure your computer isn't using a fixed IP, set it up so it's dynamically assigned an address by the Belkin router.)
Jan 20, 2011 | Belkin N1 Wireless-N Wireless Router
The globe light is blinking. We can connect to Belkin but page not found comes up. The message that comes up says IP address does not match. We have 3 laptops, and none of them are allowing us to have...
  • Connect your computer directly to your cable or DSL modem. If you see a log-in screen for your Internet Service Provider, make a note of the user name and password.
  • Unplug your router and your cable or DSL modem.
  • Plug your modem to your Belkin router's "WAN" port. Connect your computer to one of your Belkin router's numbered ports.
  • Turn on in your modem and wait 10 seconds. Plug in your router and restart your computer.
  • Select "Start," then "Control Panel" and then "Network Connections." Right-click "Local Area Connection" to bring up your network connection properties.
  • Click "Internet Protocol (TCP/IP)," then "Obtain an IP Address Automatically" and then "Obtain DNS Server Addresses Automatically."
  • Open your web browser. If you are prompted for a user name and password, enter the information you recorded in Step 1
  • Dec 29, 2010 | Belkin F5D8236-4 Router
    Is there any case that the port from belkin router
    This may happen due to double NAT issue.... the DSL modem might give an IP address in the range of belkin route....that is 192.168.2.X check for the ip address when the computer is directly connected to the DSL modem... now check for the IP adress when the Belkin alone is connected to the computer.... if they both give an IP adress like this 192.168.2.X......(X can be any value) then you will face the above issue..... in that case you can login to router and change the IP address of belkin router from 192.168.2.X to 192.168.15.X this will resolve the issue
    Apr 15, 2010 | Belkin (F5D7230-4) Router (587009)
    Reset my belkin router now i can't connect to
    if you truly reset your router then you may have to reconfigure it. If your belkin router is also your dsl modem or cable modem then you will have to call your ISP provider and get your user id and password to start with.
    I have a feeling this device does double as your modem since you now cannot connect. Most routers will work as a router right out of the box. However if your modem is seperate then it may expect your router to have a different subnet for its IP address then the default. Try plugging your computer directly into the modem if that is the case. If it works then just reset the routers IP address to be on the same subnet.
    Mar 09, 2010 | Belkin (F5D7231-4) Wireless Router
    Belkin N router and linksys ip cam
    You need to connect the camera directly to your computer and have it manually assign an IP Address on your computer so you could access the camera on the first hand.After that you need to range the IP Address of the camera accordingly to the IP Address of your network.
    May 05, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
    Belkin Wireless N router/Embarq 660 modem/No internet
    Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
    Apr 15, 2009 | Belkin (F5D8231-4) Wireless Router...
    Belkin wireless problem
    If you are connected straight from the modem, your router will not have internet access, only if your modem is connected to the router you will be able to go online wireless. connect your modem to the router nad router to the desktop, so that you can access both wired and wireless connection
    Aug 12, 2008 | Belkin (F5D9230-4) Wireless Router...
    Belkin wireless G router conection problem
    login to teh router and disable the fire wall and enable QOS under QOS u can upstream ur band width for the LAPTOP MAC address>and restart the router and laptop if u r not using wire less then turn off the SSID broad cast also rate me solved if its helps thx
    Nov 16, 2007 | Belkin (F5D5231-4) Router
    Belkin (F5D7230-4) Router (587009) Logo
    80 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
