Question about Sharp MD-MS702 Personal MiniDisc Player
When I input a disc and hit play I receive an error which says "TOC ERRORa".
I bought a mini disc player sharp IM-DR400E FROM ebay it was new seller only opened for photos going great for 3 weeks now after down loading from pc to mini disc through its usb port it will not work now. TOC says cannot read and shuts down with any disc new pre-recorded disc any idea what problem could be?.
Posted on Jul 07, 2011
  • Sharp Master
  • 17,130 Answers
Possible that the disc is not reading and so the the TOC- table of content error must be referred.
It can be due to a poor head tracking or the failure of the data being read or processed.
Clean the head and use a good disc to be checked once again. If so the optical head can be faulty as it might be getting weaker.
Posted on Nov 19, 2010
After reading toc of my Marant zcd5003 the display is "error" seeking help to find out the cause
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
follow the steps and fix it.
God bless you
May 27, 2013 | Marantz CD5003 CD Player
When I try to play my sharp MD-MT15 midi dish player, it did not play. It say TOC ERRORa. Please some one help me to fix it. Thank you very much!!!
That's an ancient player!
Try using a different disc. Try using the external power supply.
User manual http://www.minidisc.org/part_Sharp_MD-MT15+MT16+MT20.html
Mar 26, 2012 | Audio Players & Recorders
How i can fix TOC ERRORa
Table of Contents errors usually happen if you lose power before the disc is 'finalized' when recording. You cannot unplug the unit before it is done with a disc, or remove it until it is done finalizing. You will see "TOC" flash when you are done recording. When it stops, then you are all set. Try a fresh disc and see if that works.
Toc error
TOC is short for "table of contents". It tells the memory what is on the disc and where...... Does this do this on all cd's?? If so, the disc drive motor is probably at fault. If it's one or two discs, it's probably a scratched or smudge near the center of the disc. CD's play from the inside out.....they start with the TOC.
Sep 13, 2009 | Kenwood KDC-MP332 CD Player
TOC ERRORa
When you FINISH recording, the Minidisc recorder Writes the TOC (Table of Contents) - so you see it flashing TOC or Update when you finish recording - you need to Leave POWER ON and have the unit on for about 30 seconds for it to finish this. IF you don't, the unit doesn't know where to find the files since there is no TOC. Try a Sony home unit - you might get one more shot at it working with that.
Aug 19, 2009 | Sharp MD-MS702 Personal MiniDisc Player
TOC eror
The TOC error is the same error seen on computer disks, TOC is the table of content, this has to be read before the the unit will know the details of tracks etc......
If every disk inserted (not just burned discs) has this error, the laser is faulty or out of alignment. Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 01, 2009 | Kenwood Sirius KDC-MP522 CD Player
E-99 and other times time TOC ERROR shows up.
hi TOC error sounds like its the laser is faulty. you could try a cd cleaning disc. this may cure the problem..
Regards
Mark
www.blueice-electronics.co.uk
Feb 25, 2008 | Kenwood KDC-MP205 CD Player
Toc error
toc error means "table of contents" error... means the player is unable to read the disc at all. May have a dirty focal lense to laser. clean gently with some windex on a cotton wool bud. It may be a faulty spindle motor that spins the disc. the bearings get worn or uneven and do not allow for disc reading to be successful. a check for this is a drop of oil to the bearing. It may then start to read discs, but will still require the motor to be replaced. . Check for the above... but if there is more required, take it to a Kenwood 'Agent... it may need a laser change
Dec 04, 2007 | Kenwood KDC-MP228 CD Player
TOC Error
Burned ones? Or do "real" CDs do it, too? If ALL do, then the laser was damaged or misalligned and will have to be serviced.
Sep 15, 2007 | Kenwood eXcelon KDC-X879 CD Player
What does toc err mean?
TOC is table of contents. Typically if its on a recorded cd try burning a cd from antoher computer and try it, if it works its most likely that your burner or software or ccd's your using are bad. Also is it a MP3 disc your trying to play? If so then you MUST burn it as a MP3 cd. You cant just burn MP3's to a CD and it read them. If this is the case thats why you are getting the TOC error because its not writing to the CD whats on the CD on the TOC area of the disc.
Sep 14, 2007 | Kenwood KDC-MP228 CD Player
Sharp MD-MS702 Personal MiniDisc Player Logo
761 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
