1999 Honda VT 750 CD Shadow A.C.E. Deluxe Logo
Anonymous Posted on Nov 06, 2010
I have a 98 Honda Shadow ACE VT750. The battery was replaced in May. I cannot get the battery to hold a charge. The starter fuse was just replaced. The bike will not start without jumper cables and when it does I am able to get it to idle for roughly three to four mins without the jumper cables. The bike will then die. When I try to start with out the jumper cables it makes a repeating "clicking" noise. Prior to this I checked the plugs for spark, drained the gas and replaced. Do you have suggestions??
  • Anonymous Nov 06, 2010
    Ok, thanks for the help. I checked the stator there was continuity between all three connections and no continuity between the connections and ground. Is there a test for the regulator?? I just have a feeling that the battery is not bad.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 26, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
4530
Points
I had the same problem with my 1100 shadow. I charged the battery and it would go maybe 100 miles before it would go dead. I installed a new battery, thinking that was the problem. It still went dead. I then installed a new voltage regulator and checked the stator coil. Stator coil did not demonstrate anything being wrong. The bike would still not show a charge above 12.6 volts. Come to find out the normal charge voltage is suppose to run between 13.2 and 14+ voltage. I still couldn't get it to stayed charged. I finally replaced the stator and I started seeing a charge at 13.6+ voltage. Problem solved with $$$$.
David Belcher
Level 3:
President:
  • Master 1,978 Answers
  • Posted on Nov 06, 2010
David Belcher
Master
Level 3:
President:
Answers
1978
Questions
Helped
1001782
Points
6030
Charge and load test the battery. If the battery sat dead for as little as two weeks , it could be sulfated and no good. If it is a Yuasa battery it only has a 6 month warranty , grab your receipt and race back to the dealer. They will charge and load test it three times . If it does not pass the load test you will get a new battery if it is still under warranty. Grab your voltmeter and unplug the plug with three yellow wires that is coming out of your stator. The three yellow wires coming from the stator should have continuity with each other and no continuity between any of the yellow wires and ground. That is the test for the stator. If the stator is good , the battery is good , then you probably have a bad regulator/rectifier. I suspect you just have a bad battery.
  • David Belcher
    David Belcher Nov 07, 2010
    Have the battery load tested.
    Connect a 0-15 volt DC voltmeter to the battery. Positive lead to the positive terminal and the negative lead to ground. The engine should be warm not hot ( the radiator fan should not be running. Turn the head light dimmer switch to high. Start the motor and rev the motor to 5000 RPM. The voltage should read 14.5 volts. If the voltage is considerably low or way high , you need a voltage regulator/rectifier.
  • Anonymous Nov 07, 2010
    get a bench test done on battery is the fastest solution
2000 Honda 750 Shadow Ace. I need a Wiring Diagram for it please?
Question edited for clarity.
Question moved to model category.
Honda Shadow Wiring Diagrams
TJ Brutal Customs https://support.shoptjbc.com > Collections
Oct 2, 2018 - Honda Shadow Wiring Diagrams. Honda VT600,VLX Wiring Diagram 1988-2007. Honda VT750 ACE Wiring Diagram 1998-2000. Honda VT750 ACE Wiring ...
2001 Honda VT 750 CD Shadow A.C.E. Deluxe will not turn over
Check this rebuild procedure out:
https://www.youtube.com/watch?v=iusCdwyugYE
Why will my 98 honda Shadow Ace 750 battery not charge ?
output regulator blown- blown fuses?.. bad connection.. check voltage to battery while not running and voltage while running- running should be higher- if not the regulator or your alternator/generator is faulty
1helpful
Need a headlamp assembly for '02 shadow VT750 ACE
Your best bet for saving $$ is to hit a motorcycle salvage yard such as:
www.sportwheel.com
If you give them a buzz, they can tell you if they have one and the cost. They also ship.
Top Honda Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Honda Expert? Answer questions, earn points and help others
