Question about Kenmore 73952 Gas Dryer
Kenmore dryer doesn't give off heat
My dryer is not giving off heat
  • 9 more comments
  • Anonymous Aug 13, 2008
    kenmore model 110 76902693 gas dyer worked fine 2 days ago. Took out last nights load still damp, no heat, gas connection fine and on. removed front cover looks like no pilot light. Just tumbles no heat!
    tumbles,no heat,new igniter
  • Anonymous Sep 04, 2008
    dryer runs no heat
  • Doris Armstrong Sep 09, 2008
    kenmore dryer is making a clicking sound, won't heat up no flames
  • rj706 Nov 08, 2008
    Dryer is tumbling but not giving off heat. Element is fine.
  • Anonymous Nov 22, 2008
    dryer works, but does not heat up.
  • toddladson01 Dec 06, 2008
    Dryer tumbles but no heat. Elements replaced 1 year ago.
  • jrollo1 Dec 29, 2008
    My Kenmore Gas Dryer Model # 87566110 runs fine, but will not heat up.
  • Amno Dec 30, 2008
    How do you check the Thermal fuse??
  • Mbarreiro57 Jan 26, 2009
    My dryer isn't giving off heat either
  • Amno May 11, 2010
    how do you test the thermal fuse
  • 734 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
onthejob5130
  • 640 Answers
SOURCE: i have a kenmore 80
replace your thermal fuse part number 3390719...if you need help,,im onthejob,,this is gas and not electric...
Posted on Jan 10, 2009
TheMobilian
  • 8220 Answers
SOURCE: kenmore gas dryer is not giving out heat
Check the fuse and control thermostat on the blower housing. They provide power to the gas assembly.
If all of that is good then check the flame sensor. If the flame sensor is open then no power will get to the then the common wire to the coils and ignitor will be open causing no heat. Read more
Posted on Mar 19, 2009
localwonder
  • 6784 Answers
SOURCE: Hello I have a Kenmore gas dryer model#
HI, Check the following to address this issue further.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task. The blower housing should be disassembled, and cleaned in this case.
2. Thermostat(Secondary Cause)- Highly unlikely in your case, but possible
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Posted on Dec 17, 2009
  • 3074 Answers
SOURCE: Kenmore 80 series dryer starts(runs) but will not
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Posted on Nov 07, 2010
  • 314 Answers
SOURCE: kenmore dryer will only work on no heat
The Kenmore H5T is an electric clothes dryer meant for residential use and manufactured by the Kenmore Company, which manufactures a wide variety of appliances for the home, including refrigerators, dishwashers, microwaves, stoves, and clothes washers and dryers. While most Kenmore clothes dryers work well with only basic care and maintenance, certain problems, such as the dryer not heating, occasionally occur. Troubleshooting this issue may solve the problem without the help of a service technician.
instruction
  • Ensure that the dryer is properly connected to a working grounded power supply. Confirm that the power cord is plugged firmly into the dryer and the power outlet. Reset household fuses or circuit breakers if necessary.
  • 2 Remove the lint screen from the bottom front of the dryer. Pull off all lint so that the filter screen is clean, and replace the lint screen in the dryer.
  • Run the dryer for 5 minutes on a normal cycle and hold your hand under the outside exhaust hood to feel for air movement. If there is no air movement, turn off the dryer and unplug the unit. Disconnect the exhaust vent and clean out any possible obstructions, such as excess lint. Reconnect and confirm that the vent is not kinked or crushed and preventing proper heated air flow.
  • Ensure the dryer is not in a room or outside with ambient temperatures below 45 degrees Fahrenheit. The dryer will be unable to heat properly if the ambient temperature is too low.
  • Avoid overloading the dryer with too many clothes, which will limit proper heat and air flow in the dryer. Make sure the dryer is not set on an "Air Only" dry cycle, which does not provide heat.
  • Contact an authorized service technician if the preceding steps do not resolve the problem.
  • Posted on Dec 20, 2010
    Dryer does not heat correctly code F31
    The thermostat which is a round 2 wire control on the blower box on the back of the dryer controls the heat on all dryers. always shut off power when checking any electrical appliance. Clothes dryers are wired with 2 voltages, The 240 volt supply is for the heating element only, while the 120 volt supply gives power to the timer and motor that spins the drum and powers any lights and switches. If the heating element is coming on, try replacing the thermostat. As always unplug the dryer first.
    Dec 05, 2013 | Kenmore Dryers
    My dryer kenmore elite 11074972300 doesn't heat
    I had this problem with one of my dryers and it turned out that the heating element was broken. It is a repair man that you need now I'm afraid.
    Nov 04, 2012 | Dryers
    Hello, I have a Kenmore Dryer 90 series... We are in a Town house on and the Dryer is on the 2nd floor and the vent goes up vertical for about 12 ft with a 45 then to the roof... my dryer gives off heat...
    To check the thermal fuse - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.
    To check the thermal cut-out - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
    To check the thermostats for continuity - - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
    To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
    More than likely it is the heating element.Remove the front lower panel.While the dryer is running look inside at the bottom,if the element is getting hot you will be able to see it.If the element is not hot,replace it.
    May 13, 2011 | Dryers
    Kenmore 80 series dryer starts(runs) but will not give off any heat?
    Nov 07, 2010 | Kenmore 65924 Electric Dryer
    My gas dryer runs but no heat.
    Most gas dryers use a surface-type ignitor, a ceramic element with traces that glow to ignite the gas and yours has failed. BTW, it's helpful to give model numbers so we don't have to guess.
    Aug 27, 2009 | Kenmore Dryers
    No heat in my stack-pak kenmore dryer. The element is ok and there are no broken cables/wires. 220 does come in to the unit and show up at the componets.
    There is a thermal relay switch that is blown. Replace it.
    Model number please and I will give you the part number.
    May 23, 2009 | Kenmore Dryers
    Dryer wil not spin
    Hope this info helps, ps don't forget to give me a rating thanks!!
    For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
    Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
    If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
    . Use your ohm meter to test the thermostats. All should show continuity.
    Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
    In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
    May 08, 2009 | Dryers
    My Dryer Will Not Warm Up Or Heat Up At All!!!
    May 05, 2009 | Dryers
    My dryer run but it isnt giving any heat
    Need someone to check the temperature. high limit switch or the elements. I will help someone from here search and find problem. Let me know, Thanks, Sea Breeze
    Mar 19, 2009 | Kenmore Dryers
    Kenmore gas dryer is not giving out heat
    Mar 19, 2009 | Kenmore 73952 Gas Dryer
    Kenmore 73952 Gas Dryer Logo
    1,664 people viewed this question
    Top Kenmore Dryers Experts
    Dan Webster
    Dan Webster
    Sal DeAngelo
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
