Question about Nuova Simonelli Oscar Coffee Maker, Espresso Machine
I have had the professional model for 4 years, and still can't get good creme with my espresso. I've tried packing it as tightly as possible, using different/finer grinds and brands and the handle is tightened all the way, but am wondering if something is wrong with the machine? I can achieve the desired creme from machines by other brands. The milk steamer is great. Please advise if you can.. Thanks, Jen
    President:
  • 2,777 Answers
It does sound like the water dispensing mechanism is having troubles or just operates differently than the machines you are having better luck with. All of these machines are quite different, some will produce better creme than others just based on manufacturing style. It's hard to say for sure if it really is having problems, but it sounds like it may very well be. If with other machines you are able to get your desired result if you are able to use the exact same grind and tightness of packing the grounds then I would think it may be actually having the water dispenser problems as indicated above. It may be possible to repair the machine but it will not be inexpensive by any means. If you have other machines that give you the desired result I would definitely stick with those, and I would recommend you just sell this one as it's not really "defective" it just isn't producing the result as desired.
So to restate I would just sell this machine as it is... and go with one that you are having the desired results with, rather than attempt repairing something that may not be "broken" but is just how this machine produces the creme.
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
Posted on Nov 06, 2010
My nespresso c190 makes coffee watery
Have you decalcified the machine? They need descaling about once every year - 18 months, and one MUST use the Nespresso Descaling Pack, which is designed for all Nespresso machines. I can't understand why the capsule holder is tight, unless you have used so-called "Nespresso Compatible" capsules, which can cause this. The machines are designed for use only with genuine Nespresso capsules.
Feb 28, 2015 | Nespresso C190 Espresso Machine
What do you put in it to clean it/ is it creme of tartar?
I've used 2 TBSP of vinegar in a full pot of water for years. Run it through once, then run plain water for a 2nd pot and it's clean.
Apr 01, 2011 | Cuisinart PRC-12 12-Cup Coffee Maker
Tv picture disappear
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Mar 30, 2010 | Tvone TV-207 Television
Water leaking onto counter
From experience in your model and also other espresso machines there are many possible points that you may have the leak. The pump, boiler, volumetric dozer, water/steam valve are connected together with Teflon pipes and supports at the ends with the clips and one "o" ring. In one of this point the clip can slip out so the Teflon hose to be loose and so the leak. There are also some cases if the machine is more that 2-3 years one of the above parts to leak itself due to tearing out and it might need to be replaced.
So you need to remove first the top panel and then the side panel and work the machine with extra safety since we have power wires and with visual check to find the point of leak.
If it is just the Teflon pipe and clip slip out the secure it back again, if it one of the part you can try to tight up and if the leak insist then you need to replace it.
Feb 28, 2010 | Saeco Royal Professional Espresso Machine
Tv just quit working
Sep 11, 2009 | Emerson TS1997 19" TV
Tv rca model numberf36649 tv turns on then it
Sep 07, 2009 | RCA 36V430T 36" TV
Rescan tv channels
Jun 12, 2009 | Hitachi 36SDX88B TV
Tv display says heat run
Mar 04, 2009 | Curtis-Mathis CM19011 TV
Saeco Vienna No creme' and can't lessen amt. of water in shot
Hi
Have you taken apart the brew unit lately? If so you did not put it back together correctly. Sounds like you have lost the crystal ball or you installed the spring upside down, in the brew head.
Feb 05, 2009 | Saeco Vienna De Luxe Espresso Machine
Open Questions:
Nuova Simonelli Oscar Coffee Maker, Espresso Machine Logo
42 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
