Question about Invacare Pronto M51 Power Wheelchair
Plugged the chair into 220v electricity supply. i just wanted to know if there's a fuse that i can change or a circuit breaker that i can reset, and its location. Best regards, Graham D. Jjoseph
  • 692 Answers
WOW!! Big OOPS huh? You probably blew the charger with that jolt. Does your joystick come on at all? Since the charger is connected to the controller or Power Module I hope you didn't blow that up. If you have a digital voltmeter you can set it to 200 volts dc and plug the leads into the 2 outter holes of the charger port located under the front of the joystick. You should read the battery voltage ot 24 - 30 volts. If you don't get anything at the joystick then you will have to remove the seat to get access to the batteries and check the fuses located on the positive posts of each battery. If those are not blown and you still don't have power to the joystick then I'm afraid you blew the controller cause there's no fuse for it. Sorry but if Medicare paid for your chair then you can call a repair service like Roadrunner Mobility @ 1-800-467-2668 or Repair Xpress @ 1-877-581-3733 to have them fix it for you. I might not mention that you plugged into 220 volts tho. Hope this helps
Posted on Nov 07, 2010
Hello I have a Dewalt D55153 electric air compressor it was cold outside i tried to start it it started for a minute then quit not will not do anything I can not find reset switch?
Check your electrical supply. Try plugging something in the receptacle the compressor is plugged into. If that does not work then start going back to the electrical supply box. If its plugged into a GFI maybe the GFI needs resetting. If not then check your main box and see if you have blown a fuse or circuit breaker. Sometimes when compressors start up cold they pull a lot of hydro.
Dec 23, 2016 | Heating & Cooling
No power
Hi Lawrence, this is AP! Thank you for your post.
I understand you are having trouble with your Frigidaire electric dryer. Without knowing the specific model number there are still some troubleshooting tips I can recommend. Make sure the dryer is plugged into the outlet, and plugged in correctly. Check to see if the house fuse is blown or circuit breaker tripped. If so, replace fuse or re-set circuit breaker. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the dryer may turn but will not heat. Check and replace fuse in fuse box if necessary. If the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer. Circuit requirements are individual 30 amp. branch circuit fused with 30 amp. time delay fuses or circuit breakers. Your dryer requires a power supply of 240 volts to operate. Make sure that the electrical circuit is not overloaded and correct. The dryer must be on a circuit by itself. Overloaded circuits can damage the dryer and possibly cause damage to home. If needed have a Licensed Electrician check to make sure it is on a circuit by itself.
Lastly, the thermal limiter could have tripped or there is an internal problem with the dryer. A thermal limiter automatically turns off the motor (electric dryers only) in the unlikely event of an overheated situation. If this is the case I would recommend contacting an authorized service for repair as this is not a typical DIY project. Contacting an authorized technician can ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds.
You can use the link below if you need assistance in locating an authorized technician in your area. I hope this information proves helpful for you.
http://www.frigidaire.com/Owner-Center/Locate-Service--Parts/
Mar 19, 2014 | Frigidaire Electric Dryer
I have a maytag performa electric dryer with no heat, checked fuses, replaced heat element and thermostat, any ideas
Have you checked to make certain you have the proper voltage where the dryer is plugged in? 220v? A dryer will run on 110v but requires 220v to heat. Could be a problem with the breaker in the breaker box. If you are not familiar with electricity, I suggest you find someone knowledgeable ie professonial
Mar 26, 2011 | Maytag Dryers
I have a F & P Aeron Qantum built-in Oven about 7 years old. It has hardly been used. The top and bottom grills do not come on. The light and air blower does come on. Any ideas?
I am assuming you have an electric unit.......Most likely it is a 220V and is actually 2 110V circuits....there are 2 fuses or circuit breakers that power your unit...replace the fuse or reset the breaker ... what ever applies to you....if the breaker trips or fuse blows again you will need a quilified tech. to assist you further. Please reply.
Feb 19, 2011 | Fisher and Paykel Ovens
The power won't turn on, how can i fix that?
The possible causes for this unusual behavior may be if 1) electrical power cord may not be plugged in or connection or may be loose. To make sure this is not the problem see that the plug fits tightly in wall outlet.
2) House fuse is blown, circuit breaker tripped, or a power outage has occurred. Reset circuit breaker or replace fuse. Do not increase fuse capacity. If problem is a circuit overload, have it corrected by a qualified electrician.
3)Water supply tap is not turned on. Turn on water supply tap.
If all the above methods doesn't work, please call at 1-877-714-7486 to locate your nearest LG service center.
Feb 05, 2011 | LG WM-2277HW Front Load Washer
NO HEAT . I CHANGED THE HEATING ELEMENT,
Check to ensure you have 220v A/C to the dryer.
The dryer will run on 110v but will not heat.
Ck. the dryer cord where it connects to the dryer.
Some times one of the terminals on the cord may have burned up due to a bad connection.
Electric dryers are not sold with power cords since there are several different types of 220V outlets.
You may have a bad house fuse, Circuit breaker or 220V outlet.
Jan 16, 2010 | Dryers
Is there a fuse or circuit breaker i can reset if 220v was put to my washing machine? i was rewiring the breaker panel and got two circuits reversed, the washing machine circuit and the water heater...
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse
Jan 10, 2010 | Washing Machines
My chair just stopped working
You'll need to describe what you were doing when it quit, what kind of chair it is, etc. Right now, try resetting the circuit breaker and see if that helps, also, check to make sure the joystick is tightly plugged in and all other connections are frimly in place.
Jan 01, 2010 | Electric Mobility Invacare Pronto M41...
Maytag MAH5500B FL Washer
Washer Stops
• Plug cord into live electrical outlet.
• Check fuse or reset circuit breaker.
• Close door and push the start/pause pad to start the clothes washer. For your safety,
washer will not tumble or spin unless door is closed.
• This may be a pause or soak period in the cycle. Wait briefly and it may start.
Check screens on inlet hoses at the faucets for obstructions. Clean screens periodically.
If the sreens are colged or even a little sirty it will stop the washer!
Won't fill
• Be sure the door is tightly closed.
• Plug cord into a live electrical outlet. (Tub light should illuminate).
• Press the start/pause pad.!!!!!!!!!!!!!!!!!
• Turn both faucets on fully.
• Straighten inlet hoses.
• Disconnect hoses and clean screens. Hose filter screens may be plugged.
• Open and close the door, then push the start/pause pad.
May be a bad door sensor!!!!!!!
Huuum
Pleae remember to leave a rating
Oct 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
WA71N2 plugged to 220V should be 110V
The Fuse for these model is 110V - 250V, so definitely the machine will still light up for a moment then black out. So if you accidentally plugged it to 220V (if it is 110V) you have to change the whole PCB. Electric current are distributed by PCB which only handles 110V.
I suggest when you change the PCB try to change also the Fuse to 110V only so that next time if by accident it was plugged to 220V you just have to change the Fuse not the PCB.
I
Jul 09, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Invacare Pronto M51 Power Wheelchair Logo
107 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
