Question about Marklin Toys
I never used my new Marklin Locomotive Model 18478 bought in 1979. For the first time I tried to use it on my Marklin tracks. The wheels spark a little on the tracks but the engine does not run the Locomotive.
  • 3 more comments
  • drakewill220 Nov 07, 2010
    My father passed away and gave me the train.
    I am sorry, but I can't seem to locate the brushes. When you say the end opposite the gear box, I assume you mean the front of the loco, but where specificially are the two brushes? Are they under the carriage where the four little swivel wheels are? Not quite sure. I have a picture of the loco if that would help. This loco has three main wheels and on each end a set of swivel wheels. Thank you
    I read your comments about cleaning the brushes; however, when you say that the brushes are located opposite end of the gear, do you mean the front of the train. And if so, under the carriage or where exactly are the two brushes. I have not been able to locate them. I attached a picture of the loco for your aid. Thank you so much.
    Thanks, Shiela65 (nice name). I found the carbon brushes, but they appear very clean; especially given that the loco had been boxed all these years. Could it be that a Marklin needs is own special type of transformer, or any other ideas. Thank you
  • drakewill220 Nov 08, 2010
    Sorry, but no batteries in the Locomotive. I did notice; however, that one of the wires seems to have been crimped, which may have broken the wire inside its protective sheath. Is there a way to send a picture.
  • Anonymous Mar 21, 2014
    Need help on the installation of the marklin signals 700 series with a relay
  • 2,973 Answers
What made you think of the loco now after not using it (even as new) for over 31 years? Anyway, better late than never.
It seems that due to disuse there is a collection of dirt or whatever between the carbon brushes and the rotor connectors preventing the brushes to make contact with the rotor. Clean this area. The brushes are on the end other than the pulley or gear end. Two brushes would have one wire connected to each. pull the brushes up and clean the brush and the rotor by rotating it.
Posted on Nov 07, 2010
  • 1 more comment
  • Rinoo Kumari Nov 07, 2010
    I am sorry to hear of your father.
    The motor has two ends. One is attached to the traction end that moves the loco. The other eand has two wires going into it. This is the one I am referring to.
    It must be running on batteries. A train after all. Has to cover the distance. So batteries are a must. And a charger. On the charger you would find written the voltage it works on. See if it matches your country's voltage requirement. if yes, charge the battery, if no then replace the charger.
  • Rinoo Kumari Nov 08, 2010
    Replace this wire please.
Why does my new locomotive have no forward and very little reverse speed?
Mine had switch on the bottom (reset)of the locomotive and the track had to be perfectly connected to complete the curciut and properly grounded
Jul 25, 2015 | Crafts & Hobbies
Locomotive moves then stops
If your locomotive continuously starts then stops, when prodded with hand/finger repeats process. Then most likely, first check your electric connection for a loose connection. If everything looks ok, check wheels on locomotive for dirty wheels, then check track for dirty track.
Nov 10, 2013 | Kato N Scale, Amtrak P42 Superliner Train...
I bought a marklin steam locomotive where the wheels are frozen up or not moving at all. Any help ? Ho can repair it. Thanks
If the wheels don't move even when you try to "slide" them with your fingers, the possible problem is with the motor brushes: with a pair of tweezers gently push the springs that hold the brushes (there is one cooper brush and a carbon brush, on the motor). Remove the brushes and replace them by new ones (available from any Marklin dealer). Notice that there are 2 brush models - for old motors and new motors (these ones use 2 carbon brushes instead). Hope this helps. Best!
Oct 08, 2013 | Walthers Marklin "Veolia Transport" Class...
Strasburg steam locomotive receives power, but does not move.
Try cleaning the track AND wheels with an INK ERASER. Put the engine on the track and help it along. It could just be tight from sitting in the box. I live about 8 miles from the Strasburg railroad and have 2 relatives working there. We have ALL experienced the same thing on4 different sets. It isn't just the Strasburg sets that do this, it's most of the new toys. Your Strasburg cars might not connect to other train sets. Their car couplings are different, just like on their real trains.
Dec 13, 2012 | Toys
Why is the locomotive sparking while going on the track
The train gets it's power from the track. the spark, as long as it is small, is normal. it just means the wheels left the track for a second
Nov 10, 2011 | Lionel The Polar Express Train Set
I have three older marklin locomotives that are experiencing the same problem. As power is applied they start to chatter more and more loudly and will not run at full power. Sometimes they do this...
Probably the springs of the inverter unit are broken or too old. If you replace them by new Marklin springs, it shoud work. Notice that they must be the correct Marklin springs: any other springd probably won't work because their tension is not the correct one.
Best!
Jan 06, 2011 | Walthers Marklin "Veolia Transport" Class...
I have a Lionel 2055 post war train that I have not used in many years. I am setting it up around the Xmas tree. It ran well on the carpet when I tested it out but not around the tree on the hardwood...
Check to see if you picked up any fibers on the wheels or axles from your carpet running. Also check to be sure the pilot truck can swing freely from side to side and is not bent. There is also a light coil spring on the front truck pivot pin. Be sure that the spring is there and is not damaged. Another thing to check is the drawbar between the locomotive and tender. Your front wheels may be getting lifted off the track because the rear of the locomotive is getting pressed down. This a soft carpet may compensate for this but not a hard surface. Run your train at a speed where it derails and look closely at the locomotive to see if the rear is being pressed down.
May 23, 2017 | Lionel Toys
Kato locomotive doesnt run. Goes for a short time with spray of contact cleaner then stops
That means that your track is dirty. Your locomotive is picking up dirt from the track, which builds up. on the wheels. Use a track cleaner NOT alcohol... the alcohol does leave a residue on the track after it dries.
Jan 10, 2010 | Kato N Scale, Amtrak P42 Superliner Train...
Toys Logo
163 people viewed this question
Top Marklin Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Marklin Toy Expert? Answer questions, earn points and help others
