Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
What is the coolest setting? One side says cool and the other side says cooler? What number should the frig be set on daily?
  • 4,793 Answers
The lower number is the warmest.
Posted on Nov 06, 2010
What is the coolest temp. for Sanyo SR-LV209f... 5 or 1
On any refrigerator that I have owned, the higher the number the cooler the temperature. Thus 5 would be the coldest temperature setting. If you set it too cold, items will freeze in your refrigerator.
Aug 14, 2015 | Sanyo Refrigerators
Even though i have the frig set at 1 and the freezer at 4, things in my frig are freezing. What could be wrong?
the way that works is if you set the fridge area vent wide open and freezer at 4.
then you have called for most of all the cold air to blow from the freezer in to the cooler area.
this causes the cooler area to be to cold. go the other way with the fresh food setting and give it 48 hrs.
Dec 23, 2010 | GE Adora (DSF25KGTBG) Side by Side...
The water coming out in the shower from a Hansgrohe ThermoBalance I control is a little too hot on the coolest setting.When the center temperature control is turned to the clockwise stop position which...
pull the handle off and there is a black dial you can pull out and readjust on the shaft of the cartridge that will allow you to have cooler and hotter settings. it's black plastic and has little splines on it . the more you go one way the hotter it gets and the same the other way gets cooler
Jul 17, 2009 | Hansgrohe Home
Not cooling,lower part of the frig and freezer gets cold
You may need to set the Fridge side thermostat cooler or there may be a slide switch that allows ou to set the "bias" more toward the fridge side.
Jun 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Domestic 2804 frig in my RV, The freezer works great but the frig part will not cool at all, can you help
All cooling takes place in the freezer. The refrig/fresh food side is a parasite, depending on cold air circulation from the freezer side. The fan in the freezer provides that circulation, and usually the freezer control setting determines how much air is moved into the refrig side.
If the fan is up to speed and the both controls are set in a middle position, the refrig side should be fine. if the problem continues, replace evaporator fan motor or clear the blockage preventing circulation (usually frost build-up from a defective defrost system part or blocked defrost drain).
Jun 13, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
My Jenn-Air frig, model JCD2389G,isn't cooling. It's less than 7 years old. Freezer seems fine. Frig is set at coolest and still is only 55 degrees. Cleaned back of frig, what else do I check? thank you,...
Check the fan located in the freezer compartment.
This fan blows the cold air from the freezer into the fridge and is about 40 dollars for the part. Simple to fix too.
Gary
Jun 05, 2009 | Jenn-Air JCD2389G Side by Side...
Freezer to cold refrigerator not cold enough
sounds like your defrost timer is not working properly . Most fridge/freezers the fridge gets cooled from the cool air from the freezer . But when the defrost timer is not working properly the section between the fridge and freezer freezes up and hence doesnt allow the flow of cool air into the fridge. The defrost timer can be easily replaced.
Jan 28, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Refrigerator side too warm
SHOULD HAVE A AIR DIVERT ER CONTROL TO SEND MORE AIR TO FREEZER AND LESS TO FRIG SIDE TRY TO SENT MORE AIR TO FREEZER SIDE AND LEAVE COLD CONTROL COLD ENOUGH TO ACCOMMODATE THE FREEZER SIDE TO BE COLD ENOUGH
Jan 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
