Question about Black & Decker 3/8" Variable Speed Reversing Drill Kit" [Misc.]
I have a DR250 and I can't get the chuck open
I've run into this from time to time, usually have to fix it with two pairs of channel locks, one on each collar on the chuck. With the drill facing you, hold the inner collar steady and turn the outer collar counter-clockwise.
The chuck should not stick like that under normal circumstances (mine only did it when it got full of sawdust), so there may be a mechanism issue and there is a fair possibility that you will break the chuck doing this repair. That being said, 30 bucks is reasonable for a new one, and it's not doing you much good jammed like that.
Posted on Sep 03, 2012
Valves ticking 1985 suzuki dr250 need adjustment specks
It could be timing chain slap? Do you have good compression?
Mar 27, 2014 | 2001 Suzuki DR-Z 250
Hilti chuck won't turn
inside the chuck you will see a screw, remove the screw and chuck . A small punch with minimum forced with a small hammer to move the chuck dogs toward the end on the chuck . The chuck was opened to far and is a mechanical bind ..
Jun 30, 2012 | Hilti SFH 18A CPC Hammer DrillDriver
How can I replace the keyless chuck on my Dewalt DWD215G?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 16, 2011 | Dewalt DWD215G 12Inch 10AMP Heavy Duty Mid...
How can i remove the chuck from my cordless dewalt power drill
Hello, W/D here.
To remove your chuck, open the jaws of the chuck fully, but don't open them so tight that they lock in the open position. Remove the screw inside the chuck. Spray the inside of the chuck with penetrating oil. Tap around the edge of the chuck, while pulling it away from the motor.
It should come right off, with a little effort.
Best regards, --W/D--
Feb 08, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Hi i have a 93 dr250 motorbike and i am lossing
Hi !
Just get new washer rings for the 2 bolts.
They have hardened and craked with wear and tear and heat. In high heat and pressure the oil becomes very thin and leaks through the cracked washers.
Your problem will be solved.
Regards
Berry
Feb 01, 2010 | Suzuki DR 200 SE Motorcycles
Cordless Drill, Keyless Chuck stuck in full open position.
if chuck is wide open ,look down inside there should be an allen screw or bolt at the bottom of the chuck it should undo anti clocwise and the chuck comes off
Aug 18, 2009 | Dewalt DW056 18 Volt Cordless Impact...
2001 Suzuki DR250
Google it. type in 2001 DR250 review and the review sites usually give all the stock info.
Jun 25, 2009 | 2001 Suzuki DR-Z 250
How to unlock the chuck
this how to get a chuck off a drill.look inside the chuck for a screw. it will be a left handed screw.once you get the screw out put the chuck in a vice . you will need to squeeze it very tight. then put the drill in reverse and pull the trigger.if i wont come off you will need to hit the chuck with a hammer while you are holding the trigger. if you have a bit stuck in the chuck and cant get it out put the chuck in the vice and hit it very hard with a hammer until the chuck falls apart.i work on drills every day ,this is the only way we have found that works
May 30, 2009 | Milwaukee 0612-20 14.4v Cordless Drill Kit...
Brother Intellifax 2800
Pls open cover = Please open cover. Probaly has a jam - Open the cover remove the drum/toner unit and check for jammed piece of paper under of in the drum unit.
Jan 24, 2008 | Brother IntelliFAX 2800 Laser Fax
Black & Decker 3/8" Variable Speed Reversing Drill Kit" [Misc.] Logo
268 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
