Question about LG WM-2277HW Front Load Washer
LG WM2277HW washer LE error
Thanks for the post that starts this way:
"I am really glad I stumbled on this site- It enabled me to fix my 3 year old LG WM2277HW washer that had the motor errors described here (LE error,..."
Can you send me the jpg image/pictures of that you tried to post? It is too small to read. Thanks!
dlf@mit.edu
I was also having the LE error problem. I tried removing the unpumped water , tried re-running the load etc....... then I decided to try something else.... just like we have to restart our computers, I thought about resetting the washer so to speak......not sure if it is fixed, I am going to try running another load, but, I UNPLUGGED THE WASHER, LET IT SIT FOR ABOUT 10 SECONDS, THEN PLUGGED BACK IN.... AND THE WASHER WENT THROUGH A CYCLE AND FINISHED.
Posted on Dec 18, 2008
Great fix it. I saved alot on money today!!!! Only the $20 part. Thanks again.............
Posted on Jan 23, 2009
  • 9 Answers
Here are some larger versions that should be more readable:
Posted on Jun 16, 2008
I have a LG front load washer model #59WD1653 LG WM2277HW I keep getting an error message of LE I have misplaced my Manuel. What does that mean
Google is not your friend, but can still be helpful.
https://www.manualslib.com/manual/409239/Lg-Wm2277hw.html
May 30, 2017 | LG Washing Machines
I have a Lg WM2277HW front load washer. I replaced P/N 6501KW2002 (hall sensor), unfortunately still recieving error code LE. I even ran normal wash cycle no spin and 3 rinse and spins w/ no spin to...
Make sure hall sensor is snapped in to correct location and is secure. Take a look at repair videos from repairclinic.com or appliancepartspros.com for guidance. And the error code is "LE" for sure not "tE" which is sometimes confused between the two.
Apr 29, 2017 | LG WM2277H Front Load Washer
"LG Tromm WM2277HW will not
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Mar 27, 2011 | LG WM-2277HW Front Load Washer
LG Washer Model #wm2277hw
It is a motor error
• The connector in the LEAD WIRE ASSEMBLY is not connected to the connnector of STATOR ASSEMBLY Reconnect or repair the connector • The hall sensor is out of order/defective. Replace the STATOR ASSEMBLY
Apr 19, 2010 | LG WM-2277HW Front Load Washer
LG front load washer WM2277HW. ''LE'' Error code
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Jul 03, 2009 | LG Washing Machines
LG TROMM displays LE
LE stands for Load Error,
Jun 21, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LE display
Hi again,
Any developments with the LG washer?
Jul 13, 2008 | LG WM-2277HW Front Load Washer
LG Washer LE Error
Yes this is the same Hall sensor as in the WM 2277
You can Order them HERE and have them within a few days.
Easy fix
Jun 14, 2008 | LG WM-2277HW Front Load Washer
LG Tromm WM2277HW will not spin both directions, LE error.
Short answer: The post+images by “chem-prof” on Jan 10, 2008 and the post with part instruction by “wolfster” on Dec 04, 2007 solved the problem!!! You guys are the best!!!
Long answer: We purchased the LG WM2277HW three and a half years ago. We have been VERY happy with the results. Last Thursday we got the LE error code after placing a single sofa cover in for a quick cycle. I’m not sure if this is what caused the part to go bad or it’s just the fact that this part might have a “time limit” so LG can make more money on service… (sounds like my Volvo!!!). Anyways, after freaking out for five very long minutes, I Googled the phrase “LG Tromm WM2277HW will not spin” and got directly to this page (WAHOO, FixYa.com!!! You guys are great too!!!). Read the instructions posted by “chem-prof” and “wolfster”. Following “wolfster” I went to download the user manual and exploded diagram from http://136.166.4.200/contents/Laundry/WM2277.htm, then I went to http://www.mcminone.com/ and typed “P/N 6501KW2002A” in the search. Got the “sensor assembly” part for $17.50 + $22.50 (2nd day air UPS). Make sure to note “Please send me a UPS tracking info” in the comments field. Got the UPS tracing e-mail from mcminone.com and waited…. Tuesday was my delivery day (Ohio to Florida). On 5pm got the part by UPS. At 5:15pm it was all assembled and first cycle was started to run!!! Now it’s my 3rd cycle and the baby LG WM2277HW is spinning like usual!!!
OK, now let me tell you, the images by chem-prof are great, but I found that if you take the three screws that attach the electric cords to the drambase it will actually make your life easier and it you will not need to disconnect one of the cords/plug, only the small one that attaches to the “sensor assembly”. See my image for the process:
A. Take off the 4 screws for the metal covering
B. Take center large screw (#2 on my list, it was a mistake…), this will not be as easy unless you have someone else to hold the dram from the front… but it’s doable after all, I did it!
C. Take off the magnets covering, this may require some shifting left and right, while pulling to the back (placing it back is not that easy, indeed watch your fingers when placing it back!)
D. Disconnect the cords attachment screws (#1 on my list)
E. Take the 6 screws of the motor (looks like a circle with orange cords around it!) (#3) and place the motor on a towel on the floor
F. Take off the plastic part (“sensor assembly”) from the motor
G. Place the new plastic part (“sensor assembly”) on the motor
-- Redo steps E to A backwards… voualla! You’re done!
H. Take your wife and the kids to a fancy restaurant for all the $$$ you saved!
Nov 17, 2007 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
1,392 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
