Question about Hotpoint Dryers
Hi there, I have to rplace the teardrop bearing at the rear of my dryer. It has been a while since I removed the damaged kit. The istructions did not show the orientaion of the bearing, i.e does the collar go into the rear panel or sit proud outside. Daft question I know but your help would be much appreciated. Many thanks in advance Craig
  • fergoyle Nov 09, 2010
    thanks for your response,
    I didnt word my question very well.
    The teardrop bearing has a raised collar which logically would fit into the rear panel ,from the rear, rather than sitting proud of it.
    I wanted to check that my logic was sound
    Manty thanks in advance
  • Hotpoint Master
  • 3,463 Answers
Hi
The bearing actually sits outside of the the rear panel, so that you can actually see the tear drop shape of the bearing when viewed from the rear.
Hope this answers your question, if you need any more info, then please e-mail.
Cheers.
Posted on Nov 06, 2010
Why is it now squealing when in spin mode
If your dryer is the kind with rotating drums, might be a bearing. You should disassemble it and check if can be replaced
Dryer Repair Replacing the Drum Bearing GE Part WE3M26
Dryer Repair Replacing the Rear Drum Bearing Assembly Frigidaire Part...
Dryer Repair Replacing the Rear Drum Bearing Kit Part 1 GE Part WE25M40
GE Dryer Repair Noisy or Screeching Rear Drum Bearing WE25M40
you can fine more youtube video tutoriala looking in google for terms
Youtube DRUM DRYER
Sep 02, 2015 | Dryers
How do i remove the top and front panal to replace the rear bearing kit
If it is Frigidaire here is a link: http://gomestic.com/do-it-yourself/how-to-replace-a-frigidaire-dryer-rear-drum-bearing/
If it is some other brand a model number will be most useful. I do not know what you know. So please tell your model Thanks
Mar 14, 2015 | Dryers
Hotpoint condenser dryer noisy
hi if you push inside top at back of drum u will feel if lift if so yes u need bearing just ask for rear bearing for your model more than likely teardrop bearing
Nov 14, 2012 | Hotpoint Dryers
Constant squeaking when running model # DNSR473EWOWW
You will need to replace the rear drum bearing,a fairly common concern on these models. you should also inspect the front bearing surface the drum rides on for wear since replacement of the rear bearing requires removal of the drum anyway, when ordering the rear bearing kit make sure it comes with the special high temp grease that is used on the rear bearing. Good Luck
Aug 14, 2010 | GE Dryers
GE electric dryer (model #: DRSR483ED2WW) sounds like grinding metal when dryer starts/runs
you need to replace the rear drum bearing by removing the front panel lower screws and then remove the top cover and lean back and secure so as not to break wires to control panel,then remove drum belt,lift out drum and replace with bearing kit
Feb 01, 2010 | Dryers
Hotpoint tumble dryer making a banging noise, is
This could be a simple fix or more of a major task, so if you think you can have a go then great, first find tools and torch, empty any clothes, unplug from the power supply,disconnect vent if any, place unit on a table or bench then remove the back check for large quantities of fluff and dust, clean as much as possible, see if drive belt is secure and not damaged if this is not the case then the drum bearings may be worn, try to move the drum up and down, try the same thing from inside the door, as these dryers tend to wear front bearings quicker than rear ones, if excessive wear and you are confident, remove the drive belt and tensioner take note of the layout, remove supporting bracket at rear of drum taking careful note of where any nuts bolts are from, withdraw the drum you should now have access to all the bearings which are usually like a special plastic runners or ring, contact local supplier stating make and model number ask for a bearing kit, replace bearings and rebuild machine, all this could take up a few hours to a few days so ensure you can manage without a working dryer.............good luck
Nov 19, 2009 | Hotpoint Dryers
Dryer make a squeeling noise when going, how do I fix and get the back off the dryer
Nothing could be easier to work on than these beautys. After unplugging the machine start by popping the top so you can get to the screws holding the front panel on. As pictured gently push the springclips in on each side about 2 or 3 inchs from each end to release the top: top%20removal.jpg Pop that top with a putty knife. After removing the 2 phillips screws holding the front to the frame (near the top on each side) and taking the wires loose from the door switch, lift the front panel out yer way.
Remove the rear hatch and take the idler loose. Then you can get the drum out. Grab the belt and yank upwards on the drum and remove it out the front.
INSPECTING THE DRYER Look for broken glides on the front panel: 5303937139.jpg?height=147&width=200 5303937139 glide kit $24 The rear drum has a big trailer ball type mount that holds it into place, over time the plastic bearing wears out and the support under it squeals, (it is telling you serious stuff is going to happen) The metal mount under the by now thin, failed, and gone bye-bye plastic bearing, will eat into the ball and cut it off causing the drum to fall into the heater element AND break the belt. YIKES! NOT GOOD! a%20frigidaire%20dryer%20bearing%20failure.jpg?height=150&width=200
Failed bearing with missing ball
The kit (5303281153) comes with everything you need to repair the bearing. It is about $25 bucks or less. With the drum removed and the bearing inspected you want to take a gander at the heating element. If the element is broken, there is no need to buy the whole pan for $100. You can get a restring kit for about $25. Just remember to evenly space the new wire so it will not burn out quickly. Remove all lint from the dryer and the drum. This is the main killer of a heater element. Lint on it causes a hot spot. gibsonfrig%20elec%20coil.jpg 5300622032 Restring kit $25 The fuse mounts on the rear wall of the dryer in the upper right hand corner. If it blows the dryer will not run. Clean out the vent and any lint in the dryer or the fuse will continue to blow. gibson%20rear%20wall.jpg 134120900 Fuse $12 The belt part # is 5303281154 $10 The Idler is part # 131863007 $12 For routing info see Belt routing above on anotha page my friend. LOL Or better yet how about the repair manual? Here is a newer repair manual. The innards of the dryer is the same as always but the newer models have a thermister and assorted goodies: ELECTROLUX REPAIR MANUAL
Oct 24, 2009 | Frigidaire FDE336RE Dryer
How to remove the drum from the front and replace the drum support cup kit.
Release the top by pushing in the clips with a putty knife at the front right and front left of the dryer. Once you release the top you can remove it by disonnecting the ground wire at the rear of the top panel. Remove screws that secure the front panel to the dryer. Once all the screws are removed give the front panel a tug to pop it from the clips. Unhook the wiring harness and remove the front panel. By now you can see the drum. Remove the belt from the motor and idler wheel pulley. Yoy will need to get to the rear of the dryer and remove a grill (lower left corner).to gain access to the pulleys. Once the belt is removed, grasp the drum at the rear and give it a quick **** upward to release the drum from the rear bearing. The drum can now be removed through the front.
If you are replacing the rear bearing, consider also replacing the front plastic glides/slide that are located at the top of the door.
May 23, 2009 | Frigidaire FDE647RF Dryer
Hotpoint bearing lubricant?
No lubricant is req'd..The rear drum bearing is already impregnated with lubricant.
Dec 13, 2008 | Hotpoint NWXR473EV Dryer
Kenmore/Whirlpool 417.99170120 Laundry Center
5303281153 comlete rear bearing kit, should come complete with insrtuction's
Mar 10, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
