Question about Maytag Refrigerators
I have an older side by side model and the fridgerator side is not working but the freezer side is working fine.... not sure what to do?
    Guru:
  • 1,524 Answers
Try putting it into defrost. If an older model that uses a electro-mechanical timer it can be located in the control panel or behind kickplate. Use a flat blade screwdriver.
Posted on Nov 06, 2010
I have samsung model rfg237acrs the fridgerator is fine but the freezer is not cold
Had this problem with my recent Samsung fridge and I have a leak in my sealed system. They have a five year warrenty so your best luck is calling them. Check your manual for manufactory warrenties. For my situation has resulted in a refund of my purchase price. They also do exchanges too. Best of luck
Mar 01, 2013 | Samsung RFG297AAPN (285 cu ft) French Door...
Fridgerator not cold and freezer not freezing
You will need to clean the condensor coil. It is usually under the refrigerator on newer models and in the rear on older models. All you need to do is use a vacuum to clean it. Also try to leave some room behind the refrigerator, do not keep it too close to the wall. It needs to circulate the warm air it extracts.
Jul 15, 2012 | Roper Refrigerators
The fridgerator won't get cool. Freezer works just fine. But the fridgerator stopped working. The model number is LSC27931ST
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | LG Refrigerators
My maytag fridgerator has suddenly stopped getting cold. My freezer is fine and stays cold. Troubleshooting it did not work. Please help.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it'll be the control.
Jul 30, 2011 | Maytag MBF 2256 Bottom Freezer...
The temperature of the fridge has risen to 11/12 degrees & wont come down? Freezer works fine! Any answers please
Don't know the make and model of your fridge, but most fridges have only one evap coil located in the freezer. The fridgerator compartment is cooled by a fan to blow air from the coil back into the fridgerator section. Check that the fan is working and the vents in the fridgerator are not blocked. Often the problem might be that the defrost circuit is not functioning causing ice to build up on the evap coil thus block the air flow to the fridge. If you seen any ice build up in freezer or refrigerator that could be the problem. If that is the case, then you need to have the defrost circuit troubleshot, typical failures are the heater itself or the defrost timer if you have an older model. Hope this helps you.
Oct 08, 2010 | Refrigerators
Not Cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
gfad
Jun 13, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Fridgerator not cooling
I have the same problem. Freezer is okay, but refrigerator is not cooling.
Mar 24, 2009 | Frigidaire FRS26R4A Side by Side...
Fridgerator part is not cooling anymore
You may need a recharge. check the condenser to see if its cold to the touch. if the condenser has pressure and is kinda cold, the charges is fine but, if its warm, you should recharge the unit.
Mar 13, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Frost on back wall of freezer, side by side, wont freeze
It's most likely a defrost issue. One or more of your defrost components have failed. Defrost components are defrost thermostat, defrost heater, and defrost timer or board depending on model
Nov 21, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is fine. Fridgerator portion does not cool .
The most likely cause is a bad evaperator fan motor. It is mounted in the freezer section. It blows the air up to the ref section. Open the freezer door and listen to see if you hear any fan noise.
Nov 21, 2008 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
