I have a pioneer sx1250 receiver when I turn it on the lights come on & the amp seems to be on I can feel the heat from the fins but the radio doesn't come on . when it was working it would take a sec for the radio to come on after I turn the switch on I could hear a click but now I dont hear that click thank's Frank Shown
It may need to have the DC offset readjusted. There are a few folks in the US the will actually repair this unit.
Posted on Jul 16, 2008
How do I connect a mixer to my pioneer receiver
mixer audio leads go in to receiver (you could use the aux in on receiver),then switch receiver to AUX on the front.
you need receiver to recognize the mixer....
Jul 24, 2016 | Pioneer Audio Players & Recorders
I am unable to get in the Illumination mode, on my Radio. I had it set once, when I first installed it.
Pioneer DEH-X6500BT Car Stereo MIXTRAX Demo ...
? 1:30
Sep 1, 2012 - Uploaded by SantaClaritaAutosoun
Brand New 2013 Pioneer DEH-X6500BT Bluetooth car Stereowith MIXTRAX, ... It seems like the cooling fins on the back getreally hot. ... I can't switch mixtrax off, even when off on the system. ... How do you make it change colors like that and can you do it on tuner mode ? ... The stereo is a din size.Missing: single
Jan 05, 2016 | Pioneer deh-x5600hd single din car stereo...
I have a pioneer receiver vsx-5000 it barely has sound I turn the volume up and it still only has a little bit of sound what's the problem
The sound you are hearing is just the pre-amp that is working. It seems the main power amp has failed. A check inside and look at what is on the big heat sink might reveal the cause. If there is something that looks like the image that I posting below then you need to replace it. If separate devices then check the power supply to them or each one.
May 13, 2015 | Pioneer Audio Players & Recorders
Pioneer DEH-P5200HD after I replaced a fuse the subwoofer stoped working. I checked the speaker and the amp. Its the radio that doesnt give signal to the amp. Also I tried turning on and off the sub in the...
It sounds like the remote turn on wire from the radio no longer outputs power. You can try connecting the the remote turn on wire from the amp to the accessory power of the radio. Place a 10 amp fuse in line just in case the issue is the amp.
Sep 07, 2012 | Pioneer DEH-5200HD
I just bought a VSX-820 and it seems to shut down automatically as soon as turn the volume up
Make sure the speaker wires are tight.
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 17, 2011 | Pioneer VSX-1016 Receiver
I have a Pioneer SX1250 receiver it works , but the protect circuit relay kicks off and then back on after a few seconds . I haven't noticed any noises in the audio when it is on and there are no over...
Cool Receiver! I have worked on many of them. Your regulator circuit will need a few zener diodes and possible some caps. It's amazing how good the capacitors are in these though, but the zener diodes fail all the time. I like replacing them all. Larry's Electronics
Apr 22, 2010 | Audio Players & Recorders
Amplifier enable. Where to mount rmt hookup on pioneer deh-1400 (old) so my amp/sub can work!!!
Amp turn on wire should be a blue wire with a white stripe on that pioneer unit. extend that wire out to the amps remote turn on wire input. And once the radio is turned on it will sent a 12volt signl and turn on the amp.
Jun 09, 2009 | Pioneer DEH-1400 CD Player
My pioneer deh-1900 mp will not turn on
did you use a wire harness adapter or did you connect the wires from the radio directly to the wires in the car? do you have a computer safe test light or a digital vom meter? do not use a conventional test light in this car or an analogue meter to check for power
Feb 09, 2008 | Pioneer DEH-1900MP CD Player
Pioneer GM-7300M 800 Watt amp will not power on
This may have a different type of triggered turn on wire. On some of the older Pioneer amps (and maybe some new ones) the trigger wire would SUPPLY B+ TO THE RADIO and when the radio was switched on the amp would sense a current draw on that wire and would then switch on. Unlike most common amps which sense the presence of B+ on the trigger wire supplied by the radio and then turn on. Look in your owners manual to see kind of turn on system you have. If you don't have an owners manual then perhaps you can download one from Pioneer support. good luck
Aug 23, 2007 | Pioneer GM-7200M Car Audio Amplifier
66 people viewed this question
