Question about LG Monitor
SCreen resolution to bright - LG Monitor
  • 1,179 Answers
You need to decrease the brightness of your screen by using the buttons on you LG monitor. Push the menu button and then navigate to and select brightness. Now use the left or right arrows to either increase or decrease the brightness.
All the best!
damnor01
Posted on Dec 20, 2010
Change brightnes
easy if its touch screen swipe to the right and a little boarder comes then click settings,,brightness and bam you done
or you can do it on your keyboard on the arrow keys(there should be a sign)
or go to settings and click screen resolution,,then brightness
Mar 10, 2015 | Acer Aspire 6930-6771 Laptop
Tip
Laptop screen resolution problem and solution
Laptop Screen Resolution Problems and solution
By hamack4real, fixya Contributor I want to do this! What's This? jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
Laptop screen resolution problems can vary for a variety of reasons. The most common types of problems generally involve some sort of hardware or software issue that causes the display to not work correctly. Correcting a laptop screen resolution problem can be done by making changes to hardware or software settings used by the computer.
    Symptoms
  1. There can be many symptoms to a display problem. Symptoms can include a screen that appears dim or one that is totally black. Other symptoms include odd colors or blotches that appear on the display as well as oversized icons on the desktop. Symptoms can also include icons that are the wrong size on the desktop.
  2. Causes
  3. There can be many causes that can result in different issues affecting the display. Common causes include damage or loose parts. Damage can result when the laptop is dropped or has something fall on top if it. Hinges that are loose are going to cause a problem because the display will not stay in an upright position. Other causes include a bad video driver or an improperly set resolution.
  4. Diagnose
  5. A screen resolution problem will need to be diagnosed to determine what actions to take to resolve the problem. Check the laptop for any loose or broken parts that might need to be repaired. Once that is done, run a test of the video display. Use the video display troubleshooter for Windows XP systems, the help and how-to for Windows Vista systems and the troubleshooting guide for Apple computers.
  6. Solutions
  7. Changing the resolution of the display can be done to fix some types of screen resolution problems. Changing the resolution can fix display problems with some programs as well as websites that have embedded video. Refer to the laptop manual for instructions to access the display settings to change the resolution setting. Updating the video driver might also help to resolve some known issues by the vendor.
  8. Brightness
  9. A dim screen can be corrected by adjusting the brightness of the display. Adjusting the brightness can be done on the keyboard as well as from the display properties. Press the FN key on the keyboard and use the right arrow key to increase the brightness of the display. The brightness settings can also be found as an option in the display settings. Keep in mind a laptop will dim the screen to conserve battery
on Oct 07, 2010 | Computers & Internet
Got a dell d630 laptop has got a fuzzy screen..need help
Hi,you can change your screen brightness in control panel or use brightness key in your laptop keyboard(fn+brightness key)and update graphic card driver if you still have problem check your native lcd resolution and make sure you choose best resolution for your lcd,and at last if your problem doesnt solve may be you have hardware problem with your lcd and your lcd must change,you can go to certified laptop store and ask them to check and repair your problem
kind regards
Apr 17, 2013 | Computers & Internet
Screen is full bright only light data not showing but if i conect monitor on vga port it works
Hello there,
The problem which you are facing, there is only one resolution you need to get the screen replaced of the laptop. That is the only resolution to it.
Happy Computing.
Thanks
Mar 25, 2011 | Acer TravelMate 342T Notebook
I WANT TO CHANGE THE SCREEN RESOLUTION AND BRIGHTNESS ON MY Alba LCD19880 HDF TELEVISION AND HAVE MISPLACED THE USER MANUAL. HOW DO I DO THIS? I AM USING IT AS A COMPUTER MONITOR.
You do not adjust the screen resolution at the monitor, it will adjust itself to what you are feeding it up to the native max resolution. You computer will have to be the one to set.
Nov 02, 2009 | Televison & Video
I can't see all of the screen at one time
The Dell E173FP is one of the cheapest in their line, and is fairly good value for money, the panel only has a Vga input so the image
quality isn't quite as good as it could be with DVI input.
unistall any video card that you have installed. use the VGA output on the back panel.
The monitor maximum resolution in 1280x1024 although it can be run at down to 640x480. When it is at anything but its native resolution the image looks a little distorted and washed out as it is stretched to fit the screen. When at native resolution it has a good picture though, clear and fairly bright, although maybe a little darker than other screens with a brightness rating of only 250cd/m^2, compared to an average brightness of 4-500cd/m^2 on recent panels.
so with say, there is not much you can do to adjust the screen to the best you can and make sure the frequecy is set at 60Hz.
Feb 23, 2009 | Dell E173FP 17" LCD Monitor
Samsung SyncMaster 931BF 19" Monitor. Screen was working fine. But now after raising the resolution past 1280X1024, the screen wouldn't display anything. I tried it on my older monitor, a CRT. It...
This is because your screen is not compatible with any resoultion past 1280 x 1024. Look at your screen's specifications here: http://downloadcenter.samsung.com/content/UM/200602/20060210090838125_BN59-00521A-01Eng.pdf (Page 76 listed as Maximum resolution)
If you want to go past that, you must purchase and/or use a different monitor. Just be sure to look at the Maximum Resolutions BEFORE you purchase a new monitor!
Nov 25, 2008 | Computers & Internet
Screen resolution
HAVE you tried the key Fn along with the key that marked brightness sign togehter
Nov 11, 2008 | IBM Computers & Internet
My screen has dimmed but the cursor remains normal
I think its just like driver problem or you adjust the color in under advance button in the screen and resolution setting
takecare
Apr 28, 2008 | Computers & Internet
Unable to adjust the brightness of display screen
bright ness buttons are indicted witha sun like mark . they r usaly used with fn keys look for that keys
Dec 22, 2007 | Dell Inspiron 9400 Notebook
LG  Monitor Logo
136 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
