Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
I have had a repairman look at this refrigerator and he claims there is a slow leak. Can't a new freon line be installed?
    Director Badge:
    Uploaded 100 video answers.
  • KitchenAid Master
  • 488 Answers
Usually it takes too much labor to fix that line, Kitchenaid built in refrigerators have capillary tube which licks at the back by suction line tube. Refrigerator will need ti be moved out from cabinet in most cases. Tech would want to give You a warranty, so they usually would replace the whole sealed system for big money, but most likely it last 10-15 years. If They will fix one pipe, next year You might call him back, leak might be in different pipe, but it will be the same expensive (due to labor). Check my video out. A Year ago found leak at evaporator, explained to customer better to do the whole system, but he wanted only evaporator replaced since its so obvious. Now we will replace the whole system, Evap is ok, heater too, but now, capillary tube + suction line + drain pan heater loop(freon pipe). If You watch video thru till the end, you will see where heater on old evaporator touching evaporator coil in multiple bents.
Posted on Aug 05, 2015
    Guru:
  • 1,524 Answers
Why can't the line be "Brazed" and system evacuated and re-charged ?
Posted on Nov 06, 2010
How come the air cond. is shot- off and on. Car runs great- 125 K should I fix it?
Your year model used freon which can still be obtained thru a licensed AC tech. The older freon gas has been banned from further production and is very expensive. Check with a local repairman and see if they can re-claim the freon , clean your system, install necessary filters and change-over equipment and install a later approved and cheaper refrigerant. !25K on a 1990 Camry is just about broke -in and ready to drive. They are some of the best engineered vehicles I have ever worked on. They also seldom need repairs.......especially the 4-Cyl models. Best Wishes
Sep 02, 2014 | 1990 Toyota Camry
FREZZER WORKS FRIDGE DOES NOT
Same thing happened with our fridge. We had a repairman out to look at it. He took the back panel off the rear of the freezer. There was a large block of ice in one corner of the freezer. Repairman said this was indicative of a Freon leak. The condensation was freezing around where the leak was which was why the block of ice was in one corner rather than all over. Repairman said he could refill the Freon but cost 200 dollars. He also said there was no real way to tell how quickly the Freon was escaping so the fix could last 2 years or 2 weeks, there was no way to tell. Repair company came highly recommended from yelp as well as Angie's List with many high marks for honesty. Repairman suggested buying a new fridge (not from them) for 300 bucks rather than a 200 dollar fix with no way to tell how long it would last.
Aug 15, 2012 | GE GSS25SGMBS Side by Side Refrigerator
My kenmore refrigerator/freezer just leaked freon, and is not working now. My refrigerator is not cooling. I would like to know what to look for to determine the problem. Any help would be greatly...
Well the freon leak is an indication that no matter what you do at this time, the refrigerator will never work unless the leak is fixed. If you do not have the right tools to fix the leak and check the status of the compressor, your best course of action is to call a repairman. If you have any knowledge in refrigeration, you can make this a nice little project.
*First, locate and fix the leak
*Install a servicing valve or line tap valve to vacuum the system
*Charge the system
These are the steps to repairing the refrigerator providing that your compressor is in working order; do not forget to check it.
Dec 18, 2010 | Kenmore Refrigerators
6 Year old GE side by side - freon line corroded and leaked
I am a tech that has worked on many ge ref's and have never seen GE do anthing outside of the units warranty. this is a common problem on ge units
Apr 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer whistles after closing door; new sound after a freon rech
yes sir,your unit is working well right now, at this stage, freezer section is already at the peak of its performance, it creates suction motion as you close the door (frzr). with this, sometimes you can hear whistling sound or most of the time.it is only a sign that the cooling system is working well.as the temperature goes down it happens, to see it, watch the gasket how it behaves during that moment sir.there is a suction sound.blower is also in suction motion because it diverts airflow going to ref section thus creating this behaviour on the gasket and the door as a whole, dont worry sir that is normal, or try to clean the tip of the gasket to reduce the slipping sound.
Mar 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The freezer isn't gettting cold enough to freeze solid and the ice maker isn't making ice because of that too. Repairman says we have a freon leak. Is that a valid response...
possible causes: bad door seals or condensate drain plugged causing evaporator coils (in freezer) to ice up, condenser or evaporator fans not on, condenser coils dirty, compressor not working, or a freon leak. if the back wall of your freezer is frosty or super cold, the coils are iced up. remove the back wall and defrost it with a hair dryer. if the water doesn't drain, unclog the drain tube. check the door seals for gaps. replace if necessary. check the fan in the freezer and the fan in the back. both should come on when the compressor is on. if not, check the fuses on the main board. replace if needed. if all that is fine, and there is no frost, you have a slow leak or a bad compressor. call in a pro or get a new fridge.
Nov 12, 2009 | Amana SXD524VW Side by Side Refrigerator
How can you tell if your coolant has leaked out of your refrigerator?
Freon is a clear gas while at room tempertaure.
You would not see it.
Freon leakage is normally one of the last things to go wrong with a fridge.
You may want a second opinion.
Apr 13, 2009 | Kenmore Refrigerators
Freezer temp increased slowly;ice cream/ice will not freeze
If the repairman is experienced the problem will be resolved. I have recharged refrigerators myself and it is difficult, time consuming ad tedious. Sorry the work needs to be done in your home. If he does not know what he is doing he will cause problems and make excuses for why the refrigerator does not work correctly. Hope you have the best service available for your area. Sea Breeze
Mar 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer side warm had repairman lookat problem said it had small
if you went to the back of your refer,to the compressor and held the high side line[smallest tubing leaving the compressor]it should be very hot almust uncomfortable to hold if you have the proper freon charge.this is while its running off course.God bless,tom
Jan 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Fridge only unit did not cool
How to find and fix freon leak Video. Refrigerator.
Nov 18, 2008 | Refrigerators
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
144 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
