Color not synchronized,ages has three colors - Televison & Video
  • 8,617 Answers
I will need the model number of your set in order to help you out with the problem.
Posted on Jun 15, 2008
How do I adjust the color contrast on a 1998 GE 19GT320?
one of three things here--if was normal before moved you may have a bad solder connection on the circuit board at the end of the picture tube--happens with age as connections can come loose.
The set MAY have adjustable controls on that board for drives and screens(red, green, and blue) that can be adjusted.
The set may only also have those in a hidden menu.
Considering age of set and cost for a replacement it might be better to replace it if none of above options are something you can try.
Jun 15, 2012 | Televison & Video
I have a magnavox big screen tv that was giving to me. i do not have the manuals with it. when i turn it on. the color is in three demension I cannot get it adjusted where they colors are all together.
hi,
first of all check the tint setting on your TV picture menu.
if not get the correct color then, your telivision is a dlp TV that means it have a color wheel in side. if the synchronization of color wheel is not correct this problem can occur. there is a sensor for counting the rpm of color wheel. also have a black mark on the color wheels rotating portion. the sensor scene this black mark for making count. if there is any dust in that portion it will make difficult to the sensor making the counts. you have to remove the color wheel to clean the same.
ok
Feb 12, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Red colour on presentation not displaying through toshiba make projector
hi,
i think ur projector ha problem with color wheel synchronization. check the color wheel rpm counter sensor. there will be a mark on color wheel for making counts. if dust deposited in there the counting will not become correct. clean the color wheel and re-fix it and test again.
ok
Jan 05, 2011 | Toshiba TDP-MT200 Multimedia Projector
Picture green with color off mo.av-56p575 jvc
That is a common symptom in projection TVs that use tubes or "color guns" As the set ages the emission in the picture tubes (there are three) begins to slowly fade.
This is unfortunately a normal thing for those older projection sets. A set of tubes will last anywhere from 20,000 to 40,000 hours of operation then they are simply worn out. They can be replaced but I don't recommend it due to the age and technology version of your set. The newer type big screens use a different principle. They either are LCD or Plasma these days. The advantage of the LCD (Liquid Crystal Display) is they are very low in power consumption. The disadvantage is that you can never get a true black, only close. On the other hand the Plasma TVs are more consumptive of power but will give a very sharp image with true black levels. The choice is up to you but I suggest you replace your older television.
Zashiban
Jun 04, 2010 | Televison & Video
My tv sceen has a stain that makes anything white look yellow.
The color image is comprised of three colors, Red, Green, and Blue.
All the other colors are mixtures of those colors. The yellow picture indicates that your set is lacking sufficient blue drive.
First of all check to make sure that the tint control is not misadjusted.
The next thing is dependent upon the age of your television. If it's an older set that yellow tint is a sign of an aging picture tube.
If it's a newer set, less than 5 years old, have it analyzed by a electronics technician that is familiar with televisions if he is skilled enough he will know right away if it's the picture tube or not.
Apr 17, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My Sony KP-57WS500 TV has curved horizontal white lines. You only see them when there is something dark on the screen. Any ideas?
You have 3 CRTs inside of your TV that create image. Blue, Green and Red. Looks like one of them need adjustment due aging.
Remove front grille. Than remove center "shielding" piece held by 4-5 screws. Behind this cover you will find little black plastic box that have 6 rotating buttons on it. Take you time to study them. There is three columns and two rows. Columns represent color, rows - "Focus" or "Screen". You need to locate "Screen" row of three rotating buttons. They will be marked "B', "G", and "R" for colors accordingly. Turn on TV let it warm up and try to figure out witch color is dominating others on your screen. Then carefully turn rotating adjuster counterclockwise using Philips screwdriver. Try to muscle-remember original position of screwdriver so you can turn it back to it.
Eventually you will find the right one, you will see lines dissapear when you reduce voltage and reappear when you turn rotating shaft back. Sometimes more than one have to be adjusted.
Try to have all three color to be present and visible but with no over saturating and no horizontal lines.
Put cover and grill back - and that's should do it!
Regards.
Russ.
Apr 06, 2010 | Sony KP-57WS500 57" Rear Projection...
I have 2 light colors in my pool in one of them When I turn them on one just flashes
LIGHT SYNCHRONIZATION If your pool or spa has multiple Hayward ColorLogic LED lights, they may be operated independently, or they can be easily synchronized so they will all display the same colors and shows at the same time. For light synchronization, all lights must be wired to the same switch. Once installed, all lights should be automatically synchronized, however, if they get out of sync, they can be re-synchronized easily. To re-synchronize your lights, turn the switch on, then back off, then wait between 11 and 14 seconds and turn the switch back on. When the lights come back on, they should enter program #1, and be synchronized.
Feb 15, 2010 | Hayward 12v LED Color Logic Pool Light...
Color of the picture is faded/green
Hello Jdillon917,
I understand what you are saying, however the devil is in the details in reference to your problem. Let me explain, DLP Televisions use what is called "Color Wheel Technology". A wheel made up of primary and secondary colors spin at a synchronized rate with the Luminance Video signal and this along with the changing of the mirrors of the DLP processor creates the color that you see on the screen (This is a high level description, but it covers what is happening). Now what you are experiencing can happen if the sync between the signal to the color wheel and the DLP processor is off center, if the color wheel is out of alignment, or if the signal to the DLP is drifting. The bulb "light" is working but something happened to interfere with the sync between the color wheel and the DLP processor. I would suggest getting this looked at by a DLP qualified TV technician, because of the nature of this problem. In addition I would request that you have the technician do a certified alignment after the problem is taken care of.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 19, 2009 | JVC HD-52G786 52" Rear Projection HDTV
LP600 - Grainy picture, very poor quality
Single chip DLP projectors use a spinning color wheel between the lamp and the DMD (mirror chip) to produce colors. If the wheel rotation/synchronization is disturbed, colors will not be displayed correctly.
In my case it looks like the wheel became un-synchronized, probably because the projector was dusty/dirty inside (a light senor is used to detect the wheel position), resulting in a grainy, slightly flickering image.
I simply blew out the components with a can of 'Dust-off' and, using a small tool, rotated the color wheel by hand to make sue it wasn't rubbing or jammed.
I reassembled & started the projector and the image was back to normal.
Jul 19, 2008 | InFocus LP 600 Multimedia Projector
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
