Question about Garmin GPS
I have a Garmin 750 GPS. I made a 200 mile roundtrip Wed. The GPS worked fine on the way but showed Low Battery on the return trip. It was plugged into the cigarette ligter the entire way; however on the return trip, I left it off but plugged in. On arrival back home, I turned the GPS back on and it still said Low Battery. I then plugged it into the computer. Same thing. It only stays on long enough to say Garmin and the bla
  • 10,515 Answers
There are 3 ways to charge the battery :-
# AC Wall Charger
# DC Car Charger
# USB Cable to PC (not recommended due to current limitations of various USB ports
The life expectancy of the battery depends upon a couple factors:
# Proper charging voltage
# Number of charging cycles
When the battery is beginning to fail, you will notice that a full charge will not last as long as it used to. When the battery has completely failed, you will only be able to operate your GPS using the AC wall charger or DC car charger. As soon as you disconnect your GPS from a power source, it will go completely dead.
Typical life expectancy of the battery is 2 years (depends on above factors). We recommend having your battery replaced if your battery is older than 2 years.
If you have used all the 3 options to charge and still face the same problem, most probably imternal battery needs replacement.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 06, 2010
When using wire in car, Garmin won't turn on, it starts, shows a low battery sign and shuts down. Was working fine on recent trip. It seems no power is reaching GPS. Nuvi 765T
Most likely the fuse in the charger plug has blown. The plug that goes into the cigarette lighter socket has a ring near the end. On most chargers it's silver but some of them are black. If you unscrew this ring the plug comes apart. Be careful not to lose any parts. You'll see the fuse in there. Replace it and it should be ok.
The other possibility is that the cigarette lighter socket is not working. You can check that easily enough by trying something else in it.
Oct 14, 2010 | Garmin nuvi 765T GPS Receiver
Low battery display comes on when it is turned on then it shuts off its self
If this occurs when running on battery power, then it sounds like you just have a dead/bad battery.
If your GPS works fine when connected to a power source, then leave your GPS plugged in to a power source over-night, and if you still have this problem...
You can check to see if your device was included in a recent battery-related recall here:
https://my.garmin.com/rma/recallLanding.faces
If your unit is not included in the recall and you are (or a friend is) handy, you can buy a replacement on the net and replace it yourself for around $25 (US Dollars):
http://vimeo.com/8387716
(There are other sources for the battery, I do know if the linked company is trustworthy.)
I'm not sure what Garmin charges for this type of service?
Oct 11, 2010 | Garmin nuvi 750 GPS Receiver
The distance for the trip in my favorite is wrong.
Sounds like you might have "off road" selected for your navigation preference. Shortest distance between 2 points is a straight line, or great circle for GPS units. As the crow flies will be shorter than a road route.
Jul 04, 2010 | Garmin nuvi 205W GPS Receiver
When pluggin to the car charger and turn it on. it's a low battery and it keeps turning off. it doesn't charge. garmin nuvi 750.
the battery is defective and needs to be replaced, if the battery is not any good then it won't work even when plugged to an outside power source, that is how this are set up, the battery is not user servicable, u must send it back to Garmin for replacement.
May 26, 2010 | Garmin nuvi 750 GPS Receiver
I have a garmin nuvi 200 and we lost the car charger so we brought a new car charger and it hardly charges and when its plugged in all we get is the garmin screen and there is no way we can use it when its...
I think your battery has failed, you will need to send the GPS back to Garmin for a new battery, the battery is not replaceable by the consumer, it requires special tools, if u don't have them u can destry the GPS
Feb 04, 2010 | Garmin nuvi 200 Car GPS Receiver
Garmin C340 Street Pilot
I had the same problem. Found out that the fuse had blown in the power cord. I bought a new fuse from radio shack and have not had the low battery since.
Mar 25, 2009 | Garmin StreetPilot c340 GPS Receiver
Battery on Nuvi 750
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Jan 19, 2009 | Garmin nuvi 250W GPS Receiver
Will not turn on
Hold the off button (to the left) for 10 seconds... the system will restart and your garmin should work fine!
Sep 13, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Nuvi 200 GPS
We did not have a charger to plug in the GPS to charge, so my husband plugged it into a battery charger. I guess the battery charger was low, so it drained the unit rather than charging it. It was so low it would not come on again. I have an electric charger that adapts the car charger into AC current, so I tried that and the unit came on. Problem solved and the GPS is working again. Thanks for responding.
Jun 20, 2008 | Garmin nuvi 200W GPS
Garmin Nuvi 200W, trip planner
First of all , this is a NUVI 660 FORUM REVIEW not 200.
He was wrong , and a trip planner sir is where you want to go.
Point A to point B .
The small guide show you but the best way to learn it's to play with it.
best regards
Dec 29, 2007 | Garmin Nuvi 660 GPS Receiver
GPS Logo
95 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
