Question about Garden
Since the Sunbeam Outdoor Products wnet out of business in Portland TN I am unable to get the 2 spiders that hold the legs together for my round top table can you suggest where to go
Need plastic leg caps (part No. 06006995) for Sunbeam lawn chairs another number "magic Mod 230"
Posted on Apr 08, 2011
Avid outdoor screen gazebo instructions for set up #2086
Start with # 4 poles. There are 4. Attach a #A to each, and then attach #3 to the other end of the 3A. These are the 4 legs.
There are 6 #2 and 3 #2A. Attach a #2 to 2A, and then #2 to the other end of the 2A. These 3 are the top ridge pole and the 2 side poles.
I believe there are 4 #1 and 4#1B. Attach a 1 and 1B together. Do this 3 more times. These are the gable poles.
You have 2 connectors that say gable and gable. These are for the top pole and 2 gable poles. You have 4 connectors that say gable and leg. Put the leg poles.....in the "leg" hole, the gable pole in the.....gable hole, and the side pole in the remaining hole. That shoule do it. It's easier to put the top together first, and then get 4 people to raise it onto the leg poles. Yes, the leg poles angle out, not straight down. How's that?
Sep 17, 2011 | Garden
I lost instructions for my Avid Outdoors screen gazebo model #2086 13'x9'. Any help is appreciated
avid outdoor doesn't offer instructions...can someone please post instructions for some of these...it would really be helpful...its crazy that some of these boxes dont come with instructions?!
Jul 18, 2011 | Garden
How to put on a dog harness
1. Big loop round chest.
2. Little loop round neck
3. Part with no metal ring between front legs,
4. Part with metal ring goes on top, between shoulders, for lead to clip onto.
Mar 07, 2010 | Scott 's Adjustable Harness 1''
Belt broken on my wdt1085 washing machine.
take off back plate to washer, wrap belt round motor and spider (6 legged wheel above the motor) and turn the spider thats it
Jun 23, 2009 | Zanussi F1045W Front Load Washer
Kenmore 70 series won't spin
If the washer makes a noise from the front bottom center, when not agitating and not spinning, the motor/gearbox coupling has broken.
closed2a0a669.jpg open7976f3d.jpg It is designed to break, if the load gets enough that the motor may be damaged and is simple (enough) to replace
whirlpoool 285753, parts common to whirlpool roper ge kenmore and about a dozen other brands.
dissassembly instructions vary slightly between models but close enough, some have 2 clips some 3
  • remove screws under trims
  • raise control panel and flip it over backwards
    (note: do not dislodge air tube from level selector)
  • remove brass retainer clips at rear corners
    (note: position for reinstall)
  • remove lid switch connector
  • remove lid and body
the motor and gearbox are now exposed
  • undo bolt(s) holding spring clips to pump,
  • remove spring clips holding pump to motor(note position for reinstall)
  • unto bolt(s) holding spring clips to motor
  • remove spring clips holding motor to gearbox
  • there will be a plastic 3 legged 'spider' on the gearbox, and one on the motor, and a rubber ring with 6 holes that match the positions of the legs
  • remove the ring and spiders
  • take the ring and spiders to the local parts guy and get replacement,
    (Note the local parts guy will have the replacement, it is common to ge, whirlpool, roper, kenmore, new maytag, frigidaire and many others.)
  • use a piece of dowel, to hammer the center of the spider to the input shaft of the gearbox and the motor shaft,
    (note dont hit the legs they break.)
    (note: new spiders have metal center hubs, this is a common failure and the replacements have been strengthened)
  • turn gearbox shaft 1 leg up 2 legs down
  • turn motor shaft 2 legs up 1 leg down
  • insert new rubber ring over gearbox spider
  • insert motor into rubber ring
reinstall springclips
pump
pump springclips
body
control panel
in reverse order to above
gearbox coupling ~$17.00
time ~25 minutes, but I do 3-4/month
Oct 26, 2008 | Kenmore 22422 Top Load Washer
Does not spin
there is a coupling between the motor and gearbox, that fails.
it is a simple repair, and well worth trying
remove cabinet
  • pop off edge trims from control console
  • remove screwss from under edge trim
  • slide console forward and up ~1inch
  • flip the console over the back of the washer, the hinges are plastic and a little fragile
  • remove brass clips holding cabint inplace remember how they fit
  • lift cabinet ~1inch and remove forward
repair coupling
  • motor gearboxpump is at front bottom center
  • remove lock screw from clip holding pump to motor
  • remove two spring clips
  • pull pump off motor and swing sideways on hoses, tie off to left with a string
  • remove lock screw from clip holding motor to gearbox
  • pull motor off rubber coupling
  • pull nylon spider off gearbox shaft
  • pull nylon spider off motor shaft
  • install new spiders to shafts. Use a hammer to strike a wooden dowel on the center of the spider, dont hit the legs of the spider they break off
    Note the new coupling spiders have metal centers to stop further breakage, common fault
  • turn gearbox spider 1 leg up two legs down
    turn motor spider , 2 leg up 1 leg down so the spiders will interlock
  • install new rubber coupling on gearbox spider, install motor on coupling.
reassemble all clips and screws in reverse order
reassemble case in reverse order
on reassemble ensure plastic level sensing hose is not dislodged from water level switch body
takes longer to type than to do the repair
at parts store "Kenmore gearbox coupling" will get the correct part
Sep 07, 2008 | Kenmore 23822 Top Load Washer
Roper top load washing machine
madindian1
jcf73
It is not the timer, it is a gearbox drive coupling, whirlpoool 285753, parts common to whirlpool roper ge and about a dozen other brands.
  • remove trims from ends of control panel
  • remove scres under trims
pump
pump springclips
body
control panel
Sep 01, 2008 | Roper RAS8445KQ Top Load Washer
Kenmore 90 series agitator problem.
usually it is a gearbox drive coupling, designed to break on exceptional loads
pump
pump springclips
body
control panel
Jul 13, 2008 | Roper RAS8445KQ Top Load Washer
Garden Logo
179 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
