Question about Kenwood KDC-MP642U
I have this deck, an 800w Kenwood amp, and a Kenwood Typhoon 12" subwoofer. I have learned all of the function to deal with adjusting the sound settings. However, when using the AUX source and the USB source, I am getting either no subwoofer output, or just amp output in general. In each source all of my settings have been adjusted to how it should sound, but still no output. Anyone with the same issue who solved this? Anything I'm missing? Wiring? Any help would be great because I'd really like to get my personal music library kickin'.
  • 14 Answers
SOURCE: Kenwood kdc-mp528 amp/speaker problem???
This is a common mistake. This problem indicates that you are using the solid blue wire from the head unit to the remote turn-on on the amp. This is a power antenna wire that only receives power when on FM radio. You need to replace this with the Blue & White wire from the head unit (power control wire) to your remote turn-on on your amp. This should solve your issue.
Posted on May 12, 2007
KaeZoo
  • 156 Answers
SOURCE: Audio Output problems
Currently you have the blue wire from your Kenwood head unit connected to the blue wire in the Chrysler wire harness adapter. You need to disconnect this wire, and reconnect it to the blue/white wire coming from your Kenwood head unit instead. You probably already have the remote wire from your subwoofer amp connected there; both wires need to be attached to the blue/white Kenwood remote output. Your LHS is equipped with a factory amp. The blue wire in the Chrysler harness activates the amplifier, but it's connected to your Kenwood's power antenna activation output; therefore it's only being turned on when the tuner is selected.
Posted on Jun 04, 2007
SOURCE: My deck doesnt have aux as a source
I enabled the AUX as a source by pressing and holding the menu button (located to the left of the volume knob) then pressing the control knob up till I found the AUX options and put it on AUX2 so I wouldn't hear the audio feedback.
Posted on Mar 24, 2008
  • 132 Answers
SOURCE: Sub Control
in standby hold menu down and scroll to rear and change it to sub
Posted on Jul 25, 2008
  • 30 Answers
SOURCE: kenwood mp638U sound system problem
try to put the remote of the facory amp to ign power
Posted on Jul 14, 2009
How do i adjust clock on kenwood dpx55md ?
  • To set the clock on your Kenwood DPX55MD deck follow these steps.
  1. Press "FUNCTION" which is the second button to the right directly under the screen.
  2. Now use the toggle joystick to adjust the hours, minutes and am AM or PM.
  3. When you have the time where you want it press "CLKADJ" again and your done.
  • Hope this helps and thank you for choosing FixYa.
Regards, Tony
Jul 13, 2011 | Car Audio & Video
I have a pyle blue wave 12inch 800w subwoofer for a car hook up?
that just means it is dual channel.
if you have a stereo amp just run the left wire to one terminal and the right wire to the other terminal.
if your amp is mono run the wires to the first terminal and then from there to the second set of terminals.
PLEASE NOTE that by doing that you are bridging the speaker if the speaker was 4ohms to start with you just dropped it to 2 ohms so make sure your amp can handle that.
Dec 24, 2009 | Pyle 12" Molded Blue Cone High Power...
I have this same problem
Check the power with a volt meter. The battery power, then the remote power. Also make sure it's grounded properly. bad grounds cause mayhem.
Sep 14, 2009 | Pyle BZDBP212 Car Subwoofer
Subs not programmed into dash...?
It sounds like the input gain on the amplifier needs to be adjusted.
OR if your certain this hasn't changed see if both of your RCA cords (Left and right) are working. I had a similar issue when the mono block AMP was only sending signal from the left channel to the amp which in turn was dropping the input load in half. Its all about isolation.
Simple way to test this is to adjust the L/R balance of your deck all the way left or right and see if the amount of bass changes. If you balance all the way left and you lose your base completely then you know your amp isn't getting signal from the left channel thus if you move it all the way to the right and the bass disappears then the problem is with the right channel.
Jul 05, 2009 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Powering 4 6x9 speakers, need amp
Hi firstof all your deck isnt really putting out 52 watts x4 more like 17-22w rmsx4 ,companies like to throw out some crazy numbers it seems. If your into Kenwood try out a KAC-8404 4-channel on the mids/highs that will put 50 w x4 rms at 4 ohms or if you wanna go a lil louder try the kenwood x600f that will throw 100w rms on each 6x9 at 4 ohms no problem. My system is very similar to yours but running 4 pioneer 5x7's in all the doors and powering it with the 8404 its loud and clean ,fan cooled and no problems at all. My subs are a pair of 15's soundstream t-4's powered by an Alphasonik pma2500a its throwing 800w rms on each sub running in stereo at 2 ohms.It can drown out the mids if i set it that way but my mids /highs cant take as much power as your kenwoods can or else id step up to the x600f too.
May 10, 2009 | Kenwood KFC-6982ie Car Mid-Range Speaker
I wish to know the correct way to connect a Schneider 800w amp Model:spa-9705. What I have is a lead from my deck(marked sub woofer - 1 x red & 1 x black) but at the back of the amp in question it has 4 x...
Hello i_starlin606,
The Schneider SPA-9705 is a 4-channel bridgeable amp. How you intend to use it and what speaker(s) or subwoofer(s) you are connecting to it will determine the appropriate hookup.
If used to drive 4 sets of normal speakers, you would connect your front channels to one set of inputs (usually 1 and 2) and the rear channels to the other set. You would not use the subwoofer outputs coming from the deck.
If used to drive subwoofer(s), you would need two "Y" adapters with a female input side and 2 male outputs. The cables marked "subwoofer" would be plugged into the female "Y" and the male ends would be plugged into the 4 channel inputs on the amp (paired as 1-2 and 3-4). The front and rear preamp outputs on the deck would not be used.
Speaker/subwoofer connections will depend of the number of individual speakers or subs, whether they have single or dual voice coils, and the impedances of the voice coils.
Hope this helps.
May 06, 2009 | Car Audio & Video
Subs sound terrible (Ive tried so many things)
NO it won't be your battery. Sounds more like your deck.
Jan 22, 2009 | Jl Audio 12W3 Car Subwoofer
Amp is on, Subwoofer works, but no sound.
here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
Oct 24, 2006 | Pioneer GM-7200M Car Audio Amplifier
Kenwood KDC-MP642U Logo
50 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
