Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag FAV 6800 leaks while filling
Our washer is leaking while it fills up. It appears that something has happened where the hose shoots water into the lid. The seal along the bottom of the upper hood that goes all the way around the tank is torn, the plastic tray on top of the tank is worn, and when it is filling we can see a mist of water spraying out the top behind the lid. The seal really doesn't look like it does much in this area and we cannot figure out how the worn peice could be the problem, but the hose doesn't appear to be miss aligned either. Not sure what to do.
  • clover491 Apr 17, 2009
    I have the same problem, but all the seals are fine. When the water is filling, there is some obstruction at the lid that causes the water to travel back into the back of the machine and leak to the floor. My best guesses are a problem with the detergent dispenser the water travels through or the alignment of the water dispenser valve. Does anybody have an idea of what this might most likely be? Thanks
I was finally able to fix our leak. Noticed that when closed the back of the lid bent down a little toward the middle.  That was enough obstruct the water shooting into the lid causing it to spray out of the top a little and leak out the back alot.  Took the lid off, bent it back, and now it works!
Posted on Apr 17, 2009
  • 96 Answers
If the hose is not misaligned then the seals at least have to be replaced. Also, make sure there is no water coming in from the detergent box connection.
either
Posted on Jun 17, 2008
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
Water leaks when washer is filling up
The hoses are locted in the back do not open the top you may need to just replace the hoses,check intake selenoid
Jul 05, 2010 | Maytag MAV7580E Top Load Washer
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
During the fill cycle, the washer leaks water?
I've repaired leaks from bad rubber washers on the fill hoses as well as loose hose clamps on the back of the fill solenoids that run into the tub. Check closely.
Jun 27, 2009 | Maytag Washing Machines
Maytag washer leaking between cycles or if stopped during fill
lift the top up on the washer and see if the fill hose is crack or broke,hose on right side
Jun 18, 2009 | Whirlpool LSN1000LW Top Load Washer
My Whirlpool ultimate care is leaking under,I did check the hoses and they are okey. What could be the problem?.
Can you describe where the leak may becoming from? For example, near the front, from under the washer, or near the back.
If you notice a pool of water coming from under the washer near the FRONT, this is commonly caused by a leaking water pump. Since these pumps are sealed units and are considered non-serviceable, it must be replaced. They cannot be resealed or "fixed".
If the leak appears to be leaking from under the washer near the CENTER of the tub, either the tub seal is leaking or the air dome hose may have come loose. If the tub seal is leaking, it also must be replaced. If the air dome hose comes loose, however, the washer will never fill up all the way and will continuously run. This will cause a flood rather than a drip.
If the leak is coming from the REAR of the washer, this can be caused by cracked fill hoses, loose fill hose connections, a leaking drain hose, or a fill valve hose leaking.
Since you said you checked your hoses, I suspect a water pump, or something loose. Can you please confirm your symptoms and let me know?
Apr 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag Neptune leaks several hrs. AFTER I finish using it.
Check the easy stuff first, fill hoses tight?- drain hose cracked?
Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
if that is checked then ---------------
t leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Apr 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer
Many of the maytag toploaders have a rubber fill hose at the top of the outer drum.
Sometimes if the machine is fully loaded (or overloaded), during the spin cycle if clothes are above the top of the drum they can actually knock the rubber flange of the hose out of the drum. Then when the machine fills with water, it will dump it down the outside of the tub and it will appear that the water is leaking from the top and side of the drum... Fix it by snapping the fill hose flange back into the hole in the top part of the drum... let me know how you do or need more help...
Mar 23, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
I have purchased a Maytag washer mtw6300tqo and it leaked from the first day it arrived. It does not leak DURING the cycles but leaks profusely a few hours later. I have had service techs look at it and...
Is there water inside the tub after it starts leaking? If so the valve that lets the water into the machine could have a bad seal and overfilling the machine with water when it is not being used. Or one of your water hose seals could be leaking. Make sure the hoses are tight. Beyond that there is nothing to cause a profuse amount of water when the machine is not being used.
Apr 26, 2008 | Maytag Dependable Care LAT9206
Maytag Neptune FAV6800AW Top Load Washer Logo
231 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
