Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
Broken pull cord - Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
    Problem Solver:
  • 13 Answers
Replace recoil unit it comes w/pull string
Posted on Nov 06, 2010
Pull cord won't pull on Snapper 6.75 exi
HOW TO Replace a Broken Lawnmower Pull Cord - YouTube
? 5:53
www.youtube.com/watch?v=G02OobT7fII
Oct 4, 2011 - Uploaded by donyboy73 Easy to follow video tutorial on how to repair a broken lawnmower pull cord. The procedure for this lawnmower ...
Sep 21, 2015 | Snapper Garden
I opened the vacuum,i checked the cord and it is in the correct form,not tangle etc..still doesn't work after pluging it the wall out let..help
Possibly a broken wire. It is common for the flexible cable to break at the 3 pin plug end from constantly pulling the cord / plug out of the socket or if its a retractible cord, they get broken where the cord enters the machine rewinder. this happens when the cord is pulled out to its maximum length all the time and eventually cuts through the cord. I would try a new 3 pin plug first.
Apr 13, 2015 | Vacuums
The pull cord on my snowblower wont pull
First thing to find out is if the engine will turn over.. Check the oil level in your engine... if you got lots of oil...then ..pull the spark plug out of the engine...if you can turn the augers on the blower by hand then your engine is not seized... So the only thing left to check is the spring that acts as the recoil of the "pull cord". Usually there are screw holding the cord cover on. Note: You didn't mention if the cord was coiled in the machine or dangling out of the machine.... If it is dangling out..then it will be a broken recoil spring...if it is in could still be broken or perhaps just got pulled out of the locking device. Solutions: Take the cover off.(this is the part that the cord goes into)..then take the cord holding portion off the blower...it can removed once you have all the screw/bolts off. Nowd unwind the coil and make sure that the end is attached to the casing...if it isn't check the end of the spring ...it may be broken...it not broken check the casing where the spring end would be anchored/connected to allow it to coil up into. if either is broken than you have found your trouble... If you don't find anything wrong or if your not sure it is connected properly take the whole assembly to a repair shop...they will tell you if it is okay or not..and this should cost your nothing.... Good luck, I hope I was of some assistance to you.
Feb 23, 2015 | Garden
Ariens 926LE broken pull cord
No you remove the engine cover that the rewind assy is riveted too.
Feb 19, 2014 | Cars & Trucks
I have tried to post my question several times, asking how to change the pull cord on my Poulan 625 series lawn mower, it hasn't posted and I can't seem to get an answer.
did this break at the pull handle? if so you will still be able to re-use the same cord.
you have to first remove the pull mechanizum from the top of the engine. turn it upside down and get the old pull chord off 'If it has broken at the engine end of the cord. You will find the end of the cord inside, remove it with a pair of pin nosed pliers.
If broken at the pull handle remove the broken and of the cord from the back side of the handle. There will be a knot tied in either end. Assuming you still have enough pull cord . Cut the broken end so it is not frayed slip it through the pull handle and tie a simple knot & make it tight with some pliers.
re wind the spring by hand winding the cord back into the spool.
now you need a small zap strap to hold it all in place until you reinstall the pull mechanizum on top of the engine.Once you have done this cut the zap strap off and retrieve it as you do.
Hint* "with only 2 hands" I have used pin nosed vice grips to hold back the spring while I tie it off with zap strap or stiff string.
If the cord if broken at the engine end you will need to line up the cord input with the cord journal and hold in place while you try to feed the cord back through. Hint* use a smaller peice of wire to feed through the opposite direction and wind it around the cord several times so you can pull it through to the inside of the pull mechanizum and tie a knot. Good luck
Oct 12, 2013 | Garden
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
Broken pull cord
How to replace a broken pull cord on a leaf blower.
1) Remove Hex bolts holding plastic leaf blower housing in place with your hex wrench. you may want to cut the cord with scissors and loosen the bolt or screw securing the rope assemble with hex wrench or screwdriver.
2) Remove spring assembly Carefully. (DO NOT REMOVE THE SPRING ONLY REMOVE THE ASSEMBLY)
3) Remove old cord. Notice the direction the pull cord is wound. This is important in the following step
4) Wind new pull cord in the same direction you removed it, as in step 3, Make sure cord secures in the slot provided on pull and assembly.
5) Replace the pull cord pulley and place over spring.(This is the white plastic spool.)
6) Rotate the pull cord assembly 2 or 3 times in the same direction the cord pulls. (wearing safety goggles and work gloves) Reinsert the center screw by securing in in place with your screwdriver.
7) Insert the leaf blower cord into the end of the handle opening. Secure the handle by tying a knot at the bottom of the new cord.
8) Place the pull cord assembly back onto your blower in its designated area then secure by refastening the 4 hex nuts.
9) Replace the housing cover of blower and refasten the hex nuts.(the housing you removed in step 1.)
I hope this was some help to you. Good luck.
Jul 01, 2012 | Homelite Consumer Products Backpack...
The pull cord on my poulan pro weedeater will not
You have a broken recoil spring. Dis-assemble (pull-off) the recoil housing and check for proper dog alingnment, broken spring, or something jammed between recoil sprocket and engine block.
Apr 27, 2010 | Garden
TB144 pull cord does not catch, pulls free--no start
yes exactly what i would do sounds like the springs are either worn or gummed up or just broken on the dog ears
May 11, 2009 | Troy Bilt Tiller/Edger 26cc, Model No....
Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Mar 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
210 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
