Question about Taco 1/2" 006 BC4-TAC Circulator Pump/ Timer /Aquastat
The taco cartridge circulator #006-BC4 was working fine. Then there was a brief power outage, now it is hot to the touch, and circulates hot water to one part of the house, but not to the other 2/3's of the home. What is the problem?
  • Taco Master
  • 43,501 Answers
Here is a tip that I wrote about heating circulator pump problems.
It will give you the information you need to learn about your circulator pump problems and solutions for it.
Heating Circulating Water Pump Problems
heatman101
Posted on Dec 24, 2010
Hot water is not staying hot
Is the control that operates the pump located in the storage tank? If so the pump not be pumping. A few factors might be needed to solve the issue.
Dec 18, 2013 | Taco 006-B4 1/40 HP Bronze Circulator Pump
Taco Pump always on
Hello Melville,
That is a VERY NICE FEATURE designed to
give you INSTANT HOT WATER every-time
you use the faucet...
If it is done well it DOES NOT sound like the water
is running all the time... (big if).
The really wonderful part... HERE in CALIFORNIA
where WE have INFRASTRUCTURE to support
15 MILLION ... and we approximate 40 MILLION thirsty
residents... It is NICE to know A FEW responsible people
like you ARE NOT WASTING Gallons of water at EACH USAGE...
waiting for the water to get warm.
You ALREADY have instant warm water at your finger-tips because of your circulating pump.
On internet
https://www.bing.com/search?q=taco+1%2F2%22+006+bc4-tac&form=EDGEAR&qs=PF&cvid=dc68132e9d6a4f30a8cda2c9fd0f3617&pq=taco+1%2F2%22+006+bc4-tac&cc=US&setlang=en-US&PC=DCTE
Amazon com taco 006
Best price: 3/4 inch TACO
Taco 006 B4 Bronze Circulator Pump 3 4 Inch Sweat Portable Power Water...
Carnac the Magnificent
Mar 30, 2017 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
I cannot figure out why my hot water no longer gets hot. I unplugged my timer 3 years ago and never had a problem. Now, no hot water unless timer is on and circulating.
Best solution is to remove the circulation-system crossover located under sink and see if problem is solved.
After removing crossover piece, try hot water tap.
Another way to check if this is the problem: Turn off cold water shut-off located above water heater. No need to turn off power or gas to water heater. Now, no water should flow when you turn on hot water tap because hot is turned off.
Open hot water side of double handled faucet. If water still comes out the hot side, then crossover is the problem.
After removing Taco crossover, you can still have the problem if a single handled faucet has the same type of crossover issue.
Repeat test to see if water comes out of hot side when water to water heater is shut off.
If water still comes out of hot side, then put ear against each single handled faucet and see which one has sound of moving water. That will narrow down the suspects.
Mar 27, 2011 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
My circulator hums when running vibrating all the pipes
Try cleaning it out with CLR.
The humming is a vibration in the motor or blockage in the line.
If motor is slowed, then it will begin to overheat, and then stop working.
Open following link for other information and links.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 05, 2011 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
My Taco 006 circulation pump quit working. It make a vibrating noise and does not pump. I just bought it a year ago. Can you help.?
Usually when these motors slow down, they get hot and burn out.
You can try taking it off and cleaning with CLR, but normally when they stop working, they do not revive.
I am not sure what the warranty policy is from Taco, or if Taco has a parts list.
I think following link takes you to the Taco website:
You can contact them for warranty/parts information
http://www.taco-hvac.com/en/products/Hot-Link%AE%20Domestic%20Hot%20Water%20Recirculation%20System/products.html?current_category=398
Link below has information on recirculation systems with links to manuals and competitive products
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on pump/timer or any do-it-yourself project.
Jan 10, 2011 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
How often do we have to change our cartridge in our Taco 003 BC4 PNP?
You only need to change it out if the pump quits working..
heatman101
Nov 16, 2010 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
We have a taco timer aquastat that's pretty hot to the touch; and were not getting hot water to the house. Does it need replacing?
The pump has air in it and you need to purge out the air..
heatman101
Aug 20, 2010 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
I have a Taco circulating pump #003-BCY-3 PNP. I don't know how to set the analog timer?
Adjust dial to the correct time. Pivot the white pins out to have the pump work during that time. In other words not just one pin, but all the pins from say 6am to 8am. Was a bit confused the first time I saw this set up as well. Good luck
Aug 17, 2010 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
Taco  1/2" 006 BC4-TAC Circulator Pump/ Timer /Aquastat Logo
1,459 people viewed this question
Top Taco Hardware & Accessories Experts
deton8 von Splosion
Gene Haynes
Are you a Taco Hardware and Accessory Expert? Answer questions, earn points and help others
