Basically, the code means that the Primary Charge cora is not charging the OPC drum correctly. You may have a bad or dirty corona unit or a old or damage OPC drum or a bad power supply.
OPC means Open Packaging Conventions on a sharp Aquos TV. The Open Packaging Conventions (OPC) is a container-file technology initially created by Microsoft to store a combination of XML and non-XML files.
The SVC E9 error on the 8008 indicates a 'Belt Marker' error.
Basicaly the printer is not detecting the OPC belt rotating.
Check the OPC is not damaged, in particular check the left side of the OPC there should be a black squair that trips the light sensor which detects the OPC belt rotating. Check there is no damage here.
Locate the belt mamarker sensor, and clean it, this is on th left side of the pritner towards the top near the drum cleaner I think. It reflects of the left side of the OPC belt.
Check the OPC belt is turning, there could be a motor / drive problem.
The SVC E9 error indicates a 'BELT MARKER' error.
This means the printer is not detecting the OPC Belt as rotating.
This error can be caused by a damaged OPC belt, you can check this by removing the OPC belt from the printer and look at the OPC belt it should have a smooth green coating if there is damage to this belt it may cause this error.
The error can also be caused by a damaged 'Transfer Belt' when the OPC belt has been removed from the printer look inside the printer where the OPC belt used to be located you should see a black belt towards the back of the printer, if this belt is damaged it can also cause the error.
Ensure the OPCBelt locates in the printer correctly.
If the OPC belt and Transfer belt look to be free from damage and a are located correctly in the printer you may have a faulty belt marker sensor or faulty OPC belt.
You can try substituting the OPC belt for an alternative one if you have this available to see if you can narrow the problem down to the sensor.
OPC is organic photo conductor. Not sure what that means but apparently we need it to be able to print stuff. Yours has run out and you need to buy a new one. Should be about £100 apparently. But I'm having trouble finding anywhere that sells them, most people just seem to sell toner cartridges. The part number is 1710591-001 if that helps. Unfortunately I haven't worked out how to fit it either. Sorry. Good luck! (I hate this printer...)
how would I go about fixing the lazer problem with this issue of OPC Error when I push record. Sometimes when I use a lens cleaner, it will records some cds and then the error shows up again. Any help, Thanks
