Question about Speed Queen AES68AWF Gas Dryers
I have a speed queen gas dryer model number Aqm499w2 that will not heat up.
Better give technicians a call your problem seems the igniter is busted.
Posted on Jan 30, 2013
  • 1028 Answers
SOURCE: Speed Queen gas dryer won't heat
probably not most likely bad coils on gas valve the 2 black dohickys with wires
Posted on Jul 23, 2008
tzweeb
  • 318 Answers
SOURCE: Speed Queen dryer does not heat...
you have weak gas valkve coils and they will work when cold but after a few cycles they become electrically open and will not allow the gas to flow.
just replace both gas valve coils and that will fix your problem.
Posted on Dec 29, 2008
jumptrout51
  • 3361 Answers
SOURCE: where do you find the thermostat or the fuse on dryer?
Unplug the dryer.
Remove the front panel. Two screws on the bottom left and right about 3 inches from the floor and 3 inches in from the sides.
Lift the panel off.
Remove the 2 screws on the bottom right and left of the door. Pull forward and raise it up to disengage lock tabs. Remove the door switch wires.
Under the top lid you will see 2 screws right and left holding the top on. Remove these and lift the top to the rear of the dryer.
From the floor position, reach in and remove the drum belt from the pulley and tension roller.
Remove the drum from the dryer.
On the bottom left rear of the inside cabinet you will see the heater,fuses and thermostats.
With a volt/ohm meter (vom) set for continuity you can remove at least one wire from each part. Then check for continuity through each part.
If you get no reading the part is bad.
Look for burned/separated wires also.
Reverse the above order to re-install parts.
Good luck.
Posted on Feb 20, 2009
greg_margo
  • 1959 Answers
SOURCE: My speed queen gas dryer drum will not tumble what
Most likely the drive belt is broken. If you pop off the panel at the bottom of the machine, you will probably find a broken belt on the inside. The belt itself isn't very expensive and the overall repair is around $75 to have a repairman out.
Posted on Apr 15, 2009
erpaalai
  • 999 Answers
SOURCE: coin operated speed queen gas dryer works some
Check the coils on the gas valve. Sounds like an intermittent one. Eric
Posted on Jun 20, 2009
Speed queen gas dryer ignites and then goes out
What is the model number of your unit?
Nov 21, 2012 | Speed Queen Dryers
Problem is blowing cold air not heating up,its a speed queen dryer on bottle gas ?.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 14, 2011 | Speed Queen Dryers
I DONT HAVE A GAS DRYER AND I JUST BOUGHT A HEATER ELEMENT JUST DON'T KNOW WHERE TO PUT IT ON MY SPEED QUEEN DRYER
If does vary by model of SpeedQueen dryer,but typically the heat element fit in the bottom or the rear plate the supports the drum..reply with model number and i will tell you where yours goes.
GENE
Sep 04, 2011 | Speed Queen AES68AWF Gas Dryers
My speed queen model# AES68AWF doesnt heat what could it be?
heatman101
Jul 16, 2011 | Speed Queen AES68AWF Dryer
My speed queen dryer model #AES68AWF doesnt heat what could it be?
heatman101';
Jul 16, 2011 | Speed Queen AES68AWF Gas Dryers
Speed Queen gas dryer model #AGM499W. Replaced the igniter but did not fix the problem. Dryer will not heat.
burner may need to be vacuum out or blown out, also could be the thermo coupler. Hope this helps tim
Sep 02, 2010 | Speed Queen AGS28AWF Gas Dryer
My speed queen AGS17AWF isn't getting any heat, a friend said that it could be the ignitor or fuse but I cannot find the fuse on diagrams and I don't know how to get to it based on the diagrams, any help...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 05, 2010 | Speed Queen AGS17AWF Gas Dryer
Dryer does not heat. Electric ignition does not "spark" lighting
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 04, 2010 | Speed Queen AGS28AWF Gas Dryer
My speed queen dryer model st0300 has no spark
The dryers do not spark, but light with a hot surface ignitor. This is often the cause of no heat for gad dryers...
Checkout this tip that I wrote about this problem..
heatman101
Mar 30, 2010 | Dryers
Speed queen commerical dryer
try replacing the gas valve coils. they are cheap
Jul 25, 2008 | Speed Queen CGS68AWF Gas Dryer
Speed Queen AES68AWF Gas Dryers Logo
125 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
danoyachtcap
danoyachtcap
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
