The Ruhlatec encoder strip came off of my dell 926 all-in-one printer. The strip is still in perfect condition as no visible breaks can be found and the everything on the strip seems intact. How do i reattach this sencoder strip? The ink cartridges have no idea where to go without it. Thanks
aomcopier
  • 22 Answers
SOURCE: Lexmark 5150 All in One Printer - Encoder Strip
I hope this helps. There is usually a spring that holds the encoder strip on either or both ends. The have a hole that the spring is inserted in. The hole brakes and the encoder strip comes off. If you have all the parts including the spring you can modify the encoder strip by cutting a piece of strong tape to fit over where the strip was broken. I use packing tape. Poke a hole in it and reinstall encoder strip. You should also be able to buy a new strip but I am not sure. I also would go to an electronic store and find a tool to help. Buy a spring hook. It is designed to help push on and pull off springs and they only should cost a couple bucks USA. I hope this helps, Bill
Posted on Apr 01, 2007
WhIzAtIt
  • 136 Answers
SOURCE: Lexmark 6170 encoder strip reattach help needed
There is a spot where the strip goes through and it MUST be in this slot. It might be just a slot or it could be a hole it goes through. On all inkjets the strip will ALWAYS be straight and not pushed either frontward or backward, if it is, its not where is should be.
Posted on Sep 14, 2007
Cindy Jo
  • 74 Answers
SOURCE: Encoder Strip
What is the question? Where should you put the numerical strip of ownership? Let me know and I will send you in the right direction.
Cynthia Charczenko
Posted on Jan 15, 2008
damanpreet_c
  • 69 Answers
SOURCE: encoder strip
It is not possible for you to hook the encoder strip back to print, its kind of a Hooks on both ends which is holding it, even if you are able to put it back, it will not work,
I would refer you to a local computer tech, however I'll suggest you to get a new printer, coz tech might charge lot more than what the price of new printer
Posted on Nov 07, 2008
All Office
  • 58 Answers
SOURCE: How to get the plastic strip back in my dell 926
This is a "carriage timing belt" or in tech term's an "encoder strip". It reads the cartridge carriage when it moves left to right for positioning. Is either of the ends split or broken? If so, you are out of luck trying to reinstall it. I would recommend replacing your printer since this isn't a very expensive one. Just find a electronic waste disposal facility (or local E-waster drive at your nearest school, etc) or check with your city or state and find out where you can drop it off. Good luck.
Posted on Jan 03, 2009
Error message clear carrier jam, when I opened the top of the Dell Photo 926 a long clear strip fell out, What do I do to fix this.
The long clear strip is the encoder strip that the cartridge carriage reads to know where it is in the printer. It should not have just fallen out. There should be a small hole at each end of the strip to attach it to points in the printer. If one of those holes is broken you might as well get a new printer. Paying someone to buy a new encoder strip and install it will most likely cost more than the machine itself.
Sep 28, 2010 | Dell 926 All-In-One InkJet Printer
I need an encoder strip.dell will not answer any of my email requests.know where i could get one
hi ., it s not easy to get an encoder strip that actually fits with a dell printer .
in case the strip is in good condition , and only is hanging loose ..u can try to fit it with ur own hands . on either side .,
the model 926 is a very old printer , and so honestly ..the money he would want to spend buying a encoder strip ....u can actually get a new printer with new warranty +new carts + tech support ..
good luck .
Jul 23, 2009 | Dell 926 All-In-One InkJet Printer
Jan 03, 2009 | Dell 926 All-In-One InkJet Printer
Dell 922 printer jam
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} When printer does not have visible paper jam and printer is showing error paper jam
Check if the Encoder Strip is Broken or Missing
1.Power down the printer and unplug the power.
2.Slide the cartridge carrier inside the printer a couple of inches to the left.
3.Locate the encoder strip (Figure 1) on the right-side of the cartridge carrier encoder strip
Note:
The encoder strip is a plastic strip with small markings over its entire length. The strip may appear to be translucent.
Reposition the Encoder Strip
1. Remove the power cord from the printer.
2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
3. Gently slide the ink cartridge carrier to the middle of the printer.
4. Gently move the top part of the printer belt to the right.
5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
8. Once the encoder strip has been re-seated, close the scanner lid.
9. Re-connect the power cord to the printer.
Reseat the Dell Printer Power Adapter.
If your printer has a momentary loss of communication with your computer, it may be necessary to reset the printer to re-establish communication. You can reset a printer by unplugging the printer power cord from the electrical outlet and from the back of the printer for 10 seconds then reattaching the cord at both ends.
Check with manufacturer if printer is still covered under warranty...
If yes then get it replaced.....or else get a new printer
Jul 31, 2008 | Dell 922 All-In-One InkJet Printer
Lexmark 1200 all in one printer
Go to www.lexmark.com and click on the drivers and downloads button to find the driver for your model.
handiman518
Jan 15, 2008 | Lexmark X1270 All-In-One InkJet Printer
Carrier jam
This fixed the problem for me : found it on the Dell support website:
  5. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
    new_note.jpg Note: There is a small slot on the back of the ink cartridge carrier, into which the encoder strip fits.
Jan 04, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924
What do you call the encoding strip? Do you means the contact strip on the back of the cartridge? If so buy a new cartridge. If you mean part of the printer-did you put it back correctly- if still in trouble-take a look at www.fixyourownprinter.com. If no luck there try the Dell Tech support team If still out of luck Buy a new printer-
Jul 09, 2007 | Dell 924 All-in-One InkJet Printer
187 people viewed this question
k24674
Marvin
Marvin
